Question about Maytag Dryers
I HAVE A MAYTAG MODEL MEDC400VW0 DRYER. THE HEATING ELEMENT STAYS ON WHEN I OPEN THE DOOR. mOTOR STOPS BUT HEATING ELEMENT STAYS ON UNTIL TIMER IS TURNED TO OFF
  • 94 Answers
SOURCE: Kenmore Dryer Model 11063102101
Probably the timer is defective and needs replacing.
Posted on Oct 07, 2007
  • 27 Answers
SOURCE: Heating element stays on after door is opened
possibly something grounding the element to the housing. what brand of dryer do you have? GE/Hotpoint dryers are good at allowing things like underwires from a bra to get into the element area and ground out the element. or possibly the element has broken and the broken end has fallen against the housing. hope this helps
Posted on Nov 02, 2007
  • 7 Answers
SOURCE: Maytag dryer heating element does not turn off when tumbling stop
your timer is bad,the cost of a timer is close to a new dryer.
Posted on Jan 21, 2009
localwonder
  • 6784 Answers
SOURCE: Heating element stays on when dryer is off.
I would advise to inspect the high limit thermostat. this device may be defective. this will cause the element to continue to operate when the unit is off as well. If the thermostat is operating correctly, replace the timer.
Posted on Aug 12, 2009
meBNme
  • 334 Answers
SOURCE: my maytag dryer heating element gets hot but motor will not run
Sounds like you have something shorted out.
The element issue could be a contact fused shut.
With both problems I would be looking for wires melted together, or a relay/sequencer welded shut melted etc.
You do have a potential fire hazzard here. If after removing the panel you cannot locate the problem, do not run the unit.
Posted on Oct 20, 2009
Mde3500 Electric Dryer will not heat
it sounds like the door switch itself is good but has a poor connection after the switch. That would explain why the momentary light flashes. The heating element will not start unless the door switch is sending a constant closed signal. Check your wiring & control board.
May 02, 2014 | Maytag Dryers
When door is open during drying cycle, dryer continues to heat up.
no,it sounds like the heating element is touching metal and as long as the timer is sending power until it goes to off it will keep heating.change out the element
May 21, 2012 | Maytag Atlantis MDE7400AY Electric Dryer
I have a MEDC400VWG drier.Woked fine yesterday. Put clothes in it today. Pushed start button. nothing happened. Smelled somthing getting hot. opened drier. Heating coils lit up. (with door open). Turned...
Sounds as if the motor centrifugal switch is stuck. Check to see if lint built up around switch or centrifugal mechanism on motor shaft. Rap switch with the handle of a screw driver hard but don't break it .
Nov 01, 2010 | Maytag PYE3300 Dryer
Need help! If there is time left on the timer and I open the dryer door, the dryer tumbler stops as it should. BUT, my dryer heating element stays on and never turns off unless I unplug the dryer or turn...
Either the centrifugal switch on the drive motor is stuck in the ON position or the heating element is broken and shorted out on the heater canister.
You did not post a model number.
Therefore I can not assist in accessing these parts.
All dryers are made differently.
Appliance model numbers are a must.
Aug 14, 2010 | Dryers
Aug 12, 2009 | Maytag PYE2300AY Electric Dryer
Dryer element stays warm
If it heats w/ the timer in off position whenever plugged in the the element is shorting to ground, its most likely due to either a broken coil or a cracked insulator. If heating w/ timer set for drying but motor is not running, the heat circuit thru the centrifugal/start switch on the motor is stuck closed.
May 16, 2009 | Maytag MDE2600 Electric Dryer
Jan 21, 2009 | Dryers
Whirlpool Electric Dryer Model LER8858EQ1 TYPE NO. 180-0
Based on the information that you provided, if you open the door in mid-cycle and the motor shuts off, but the element stays on, this will stop the air flow through the dryer and the element. The element temperature will rise drastically because it is not being cooled. Subsequently, to prevent a fire, the thermal fuse will open, shutting the element, and in some cases the motor, down.
A heating element gets its power from the timer, through the cycling thermostat(s),and to 1 side of the element.
When the motor starts, power is passed through the centrifugal switch in the motor, through the hi-limit thermostat and the thermal fuse to the other side of the element.
There is no ground wiring involved in the heat side of the dryer.
1. An element can stay on because it has broken and fell against the metal tube where it picks up a ground. Solution is to replace the element.
2. The centrifugal switch mounted on or in the motor can fail to open when the motor stops and allow current to flow through it
until the points in the timer open up, breaking the circuit.
Below is a link that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jun 23, 2008 | Whirlpool LER5636P Electric Dryer
Dryers Logo
50 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
