Question about Bosch 1590EVSK 6.4 Amp Top Handle Jigsaw
How to replace base plate on 1590evs bosch jigsaw
Replace base plate
    New Friend:
Loosen the base clamp lever on the side of the housing and rotate the thumb wheel under the motor housing. The base will come off.
Posted on Dec 09, 2017
3 Suggested Answers
  • 19 Answers
SOURCE: DROPPED MY BOSCH 1590EVSK JIGSAW,
The socket-head screw that holds the sole plate on is also the alignment screw. Loosen it a little and the sole plate will swivel left and right. There are graduation marks on the base to help with alignment but I always use a square to verify the alignment. Tighten the screw and check again that it didn't move and you are ready to go.
Posted on Feb 24, 2011
  • 19 Answers
SOURCE: foot plate and locking level fell out bosch
You can go to Bosch's web site and download the manual and a nice exploded view of the tool. Here is the link.
http://www.boschtools.com/Service/ProductServices/Pages/ManualsandDiagramsResults.aspx?type=both&modelNum=1590EVSK
Does any one out there know how to put a blade in a Bosch 1581VS jig saw?
video here
How to Replace a Bosch Jigsaw Blade - YouTube
? 1:30
https://www.youtube.com/watch?v=YzpExustLD0
Sep 8, 2011 - Uploaded by toolsandmachinery
Mike will show you the simplicity of changing a blade with the Bosch twist-lock Jigsaw
here is the manual for the 1584
Bosch 1584VS Manuals
Apr 19, 2017 | Bosch Saws
How replace shoe clamping piece on Bosch 1590evs jigsaw
At the rear of where the tool body attaches to the base you will find a black thumb knob (#823). Flip the shoe release lever (#828) open then loosen the thumbscrew until the base comes off - the lever will then slide right out. Bosch 1590EVS 0601511739 Top Handle Jig Saw Parts
Jan 12, 2017 | Bosch Saws
Replacing base plate
The base plate for your saw is held in place by a screw that goes through a plate that fits into the raised part of the baseplate with the elongated holes. The nut that holds the screw in place is sandwiched in the base of the two housing halves. The raised part of the base plate and elongated holes are what allow you to tilt the base plate.
Jun 16, 2012 | Saws
NIKON D40 SQ BASE PLATE UNIT
Aperture issue is related to SQ Base Unit and this part must be replaced. I found this vendor on ebay ;
http://www.ebay.co.uk/itm/NIKON-D40-D40x-D60-SQ-SEQUENCE-APERTURE-CONTROL-MOTOR-BASE-PLATE-UNIT-GENUINE-/330808880495?pt=Digital_Camera_Accessories&hash=item4d05beed6f#shId
Feb 23, 2012 | Nikon D40 6.1MP Digital SLR Camera Digital...
Manual for bosh pneumatic jigsaw need to rebuild a jigsaw
finally found it. go to "ereplacementparts.com" and on the left side click on Bosch tools. type in the number0607561118 and you can download a parts schematic for this tool. If I have helped you in anyway would you please vote accordingly and thank you.
Feb 11, 2011 | Bosch 7561118 Orbital Action Jig Saw...
I have an old bosch 158IVS uh, what do you call a little reciprocating saw? jigsaw? anyways i can't for the life of me figure out how to change the blade. i've undone every screw. opened up the motor...
well the sawzaw will be drastically different from the jigsaw, but the jigsaw will have either a round twist lock that needs to be turned a little to remove the blade, or two screws that hold a flat plate that clamp the blade. and as for the sawzaw, it will be a twist lock, or a latch lock, the latch lock will look like a lever that needs lifted to remove the blade, and the twist lock is the same as the jigsaw.
Dec 30, 2010 | Saws
DROPPED MY BOSCH 1590EVSK JIGSAW, REPLACED BENT BASE, BUT BLADE IS STILL NOT PERPENDICULAR TO BASE. CAN'T SEE ANY ADJUSTMENT METHOD TO ALIGN BLADE PERPENDICULAR TO BASE PLATE. HELP
Aug 20, 2010 | Bosch 1590EVSK 6.4 Amp Top Handle Jigsaw
How to replace belt on a eureka boss vacuum
if you look on the base plate you should see a diagram of how to do it,but if yours don't have a diagram then remove the screws from the base plate it should be three or four they have arrows next to them. take the base plate off and remove the brush roller and the old belt off being sure to put on bear floor then put the belt on the drive shaft put the brushroller in left side first
Jun 28, 2010 | Eureka 4870SZX BOSS SMARTVAC PET LOVER...
Recently purchased a Bosch GST 135 jigsaw but after using it for a short time the front metal plate got rather warm. Is this normal?
Depends what do you mean by "rather".
If it can be kept a hand on it, it may be normal, as the knife is getting rather warmer, when used 1 - 2 minutes.
After 1-2 min you should let it rest for about 3-5 min.
Jun 15, 2010 | Bosch Saws
Broken belt i need a replacement belt for eureka altima bagless vacuum
Eureka says size U BELT... NO!! I have tried this numerous times. I finally took off a belt from an old vac. and it works !!! dirt devil size 5 belt is the way to go!!
May 08, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
Bosch 1590EVSK 6.4 Amp Top Handle Jigsaw Logo
716 people viewed this question
Top Bosch Saws Experts
Tim Venetis
Craig Butler
Craig Butler
Are you a Bosch Saw Expert? Answer questions, earn points and help others
