Question about Toshiba 42HP95 Television
TV will not come on.
I disconnected the Seine module, and the TV showed perfectly. I was in the middle of programming the channels, there was a loud pop, and needless to say...the TV went black. If I disconnect, then reconnect the power; the green ready light will come on, then the fans for about 3 seconds and then the whole thing shuts down. The green light is then replaced by a red flashing light. I have tried to isolate the ysus and zsus to no avail. The same thing happens. I see no obvious blown capacitors.
    Problem Solver:
  • 5 Answers
Might not be the exact same problem as you - I simply turned the TV off one night and it never went back on. Just had the LED red light in front flashing. Was about to give up hope and kick it to the curb when I decided to try the Solution posted by CheapTech: http://www.fixya.com/support/t101749-tv_turned_itself_off_turn_back
It WORKED. Plain and simple, it worked.
Posted on Feb 20, 2009
I have a toshiba 37LX96 that has the yellow blinking light
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Type in the brand name "Toshiba", in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 05, 2015 | Toshiba Televison & Video
How to replace Seine Module Board
After a LOT of screw removal, AFTER disconnecting the power cord, I did EXACTLY as they said and simply removed the plug PJ36A, just as told. Then I vacummed out all the dust!
Before putting the cover back on, I plugged up power, being SURE to only touch the power cord and the TV turned right on! :)
Removed the power cord, put in all the screws, reconnected the power cord and 'good as new'. :)
Thanks a bunch guys!!
Mar 14, 2012 | Televison & Video
Cannot get the cable to show on this tv
If the TV is connected to a cable box using 1 solid cable (RF ANT) your needs to be on either channel 3 or 4.
If the TV is connected to a cable box using 2 or 3 RCA cables, your TV needs to be on AV 1, 2 or 3.
If the TV is connected directly to the cable, go to MENU set the TV to cable and program channels.
Good luck
N Sabre
Nov 07, 2009 | Quasar SP-3234 TV
Toshiba 50hp95 will not respond and has flashing red power light. It seems many people have this problem, what's the solution? We have tried all the Toshiba suggestions.
My 50hp95 had the same problem; the red power light is flashing and the tv will not turn on. I unplug the power and plug it back in and the TV clicks, but the power light continues to flash red. My problem was a bad Seine module which you can bypass if you do not need to watch HD off air programming. Since I get my HD from the cable, I can bypass it. All you need to do is remove the back panel from the TV (unplug the TV first) and on the main circuit board unplug the white connector labeled PJ63A. The main circuit board is the one in the center of the TV and the PJ63A connector is the bottom white connector on the left side of the main circuit board (the label is printed in white on the circuit board under the connector). Once I plugged the TV back in it worked immediately.
Sep 09, 2009 | Toshiba 50HP95 50 in. Plasma Television
Quazar Model VHQ520/VHQ540 cannot record after inst Digital Conv
You need to set the vcr to channel 3 or 4 (whatever channel the digital converter box is set to broadcast on) to record a program. The digital converter box has to be set to the channel you want to record the show from.
Apr 09, 2009 | Quasar VHQ400 VHS VCR
32 inch tv goes from normal sound during program to extreme loud
May be a defect but, if you notice the sound changes with different channels or movies or HD or Standard, look for a volume limiter control button in the menu setup under audio control. Sometimes the menu has a control that you can turn on to limit different volume levels during the shows origination.
Mar 12, 2009 | Televison & Video
Large Black Box Showing up in middle of screen.
Try and turn off the closed captioning. I had the same problem and it turned out that the closed captioning was on t1 instead of OFF. Hope this helps!!!!
Feb 19, 2009 | Zenith C27A24T 27" TV
How to bypass seine card? 50hpx95
Turn off set, unplug power. Remove back cover. On brown circuit board left of center, unplug connector PJ63A. Plug in power, but don't electrocute yourself! If you no longer get the continuously blinking red light, hit the power button. If it comes on, the SEINE module is bad and must be replaced.
Dec 13, 2008 | Toshiba 50HPX95 50 in. Plasma HDTV
Power ligh blinking no picture no sound
I had the same problem, it is usually the SEINE module. this unit is about 350 to 400 and they only come refurbished. You can bypass this module which is what I did and it worked sweet, and I have 2 hpx 95s they were both the same problem. This module is for HD off air only so if you are using that then you need a new one if you have cable or satellite save the money and remove the back of the TV and disconnect the module. Give the TV about 3-4 mins to reboot and HELLO TV.
Oct 21, 2008 | Toshiba 50HPX95 50 in. Plasma HDTV
Red light flashing. TV wont start.
Bypass the SEINE module if you know how. If you use off air HD you will have to get a new module.
Sep 26, 2008 | Toshiba 50HPX95 50 in. Plasma HDTV
Televison & Video Logo
415 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
