Question about Samsung RS2534 Side by Side Refrigerator
Beeping while door is closed
Every once in awhile my refrigerator will make the beeping noise as if the door was open, but everything is shut tight. It doesn't happen at regular intervals, but it has done it every day for the past four days. Everything else seems to be working fine, but the beeping can get annoying.
  • 2 more comments
  • Karen Walker Jul 13, 2007
    Nothing on the control panel lights up when it is beeping. We changed the filter a couple weeks ago, so it's not that. I have checked to see if the light turns off when the door shuts and it does. I haven't heard it beep for the past two days, so maybe whatever it is solved itself?
  • pfirmst Jun 14, 2008
    I have just bought a Samsung RM25KGRS1/XSA 4 door fridge, it randomly starts beeping, after several days running, the LCD display panel shows zero's for all the temperature settings and flashes. After switching the power off and on, the fridge shows high temperatures, if we are unfortunate not to catch this behaviour early enough, we have to discard the food, the fridge, after the power cycle, returns to its correct running temperature and runs again for several days before repeating the process.
  • Anonymous Mar 24, 2014
    This happens several times a day. Once reset, the refrigerator works fine. The control panel is blank when the unit is shut down.
  • Anonymous Mar 28, 2014
    French door Kitchenaid doors are shut but beeps...how to turn off or fix
  • 20 Answers
Does this unit have a light in the freezer or fridge section that turns on when the corresponding door is opened? If it does, take a peek between the door frame and the seal around the door( while the door is closed) by sliding a thin plastic fork or knife and see if the light is on.If the light is on while it is beeping then you know that the light switch is defective.
Posted on Jul 13, 2007
    Novelist:
  • 159 Answers
Thats hard to say what the problem is. I would need to know if there is anything on the control panel that also is lighting up while the beeping is going on. If you can find that iut it would be a big help in finding what your problem may be. Feel free to get back to me if you can find that out.
Posted on Jul 12, 2007
GE Quiet Power 3 won't start when door is closed.
What is the exact model number? This may be an issue with the cables that connect the door to the power supply.
Apr 06, 2018 | GE Dishwashers
E240B Fridge Freezer door open alarm goes even when door closed.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Dec 22, 2016 | Fisher Refrigerators
Hi, I have a kenmore elite deep chest freezer. Model 253.16582105. can't stop the beeping, even after replacing the 9 volt battery.
Mar 26, 2016 | Kenmore Refrigerators
Beeper will not shut off
Hello David, I appreciate your post!
Based off my understanding your Frigidaire refrigerator will not stop beeping. Is it beeping due to no power or the door being opened for too long? Is it displaying an error code? Where is the noise coming from? Once you have provided me with some additional information I can further assist you. -Matt
Jan 02, 2016 | Frigidaire Ffsc2323le 23 Cu. Ft. Counter...
How to stop occasional five beeps?
Here is a good link on this subject:
If it is cooling OK, try unplugging and leave it for 5 minutes but if the beeping returns and everything is normal, it could be a problem with the control board...
similar issue no freezer:
Jan 02, 2015 | Frigidaire Refrigerators
Frigidaire FFHS2612LS4 wont stop beeping
Hey Brandon, this is JK. Thank you for your post. I understand that your refrigerator is beeping none stop. When the door(s) have been opened for longer than 10 minutes, an audio alarm sounds and the interior lights shut off. This protects the liner from melting due to the heat produced by the light bulbs. The alarm will sound every two minutes until the doors are closed. Once the doors are closed, the alarm will reset. The refrigerator will also beep on some models to inform the user that the door has been left open and the cool air is escaping. Check to make certain that the gaskets on both doors have no gaps and that the appliance is maintaining the desired temperature. If all of these suggestions pan out and the problem still persist, think about what may have happened prior to this occurrence. For instance, did you notice any error codes, odors, or other strange functions prior to this issue? If you are still having these issues and can think of anything in particular, please feel free to reconnect.
Hope this helps!
Mar 10, 2014 | Frigidaire FRS3R5EMB Side by Side...
Miele fridge keeps beeping
Door is open (shut it)
or
seal on door is broken ( replace it)
or
temperature dropped too low ( reduce it)
or
door was lett open too long (reset alarm)
- after ffix
press alarm buttons once to switch of beeps
Oct 20, 2013 | Miele KFN8862SD Bottom Freezer...
Fisher paykel refrigerator fault model E521T
I had the same problem, constant beeping. I removed the fan, tested it with a 12v power supply, worked fine. The beeping and flashing on the control unit was still happening though. I read online that the door reed switches can play up, so i decided to test this. I took a regular household magnet, the type you use to hold the kids drawings up on the fridge and held it against the door reed switch. Beeping stopped, fans kicked in, everything started working!!!! So I concluded that either my reed switch is not being tripped when the door shuts or possibly a reed switch problem? maybe not as sensitive as perhaps it should be..? either way my next port of call will be look at the seals around the door, are they stopping the door from shutting properly? I thought for a temporary measure you could get a strip magnet and put it inside the reed switch housing. It just means your door wont trigger the internal light when opening...
Jan 19, 2013 | Fisher and Paykel Active Smart E522B...
Beeping & not cooling
Hi Hope, usually when the door(s) have been opened for longer than 10 minutes, an audio alarm sounds and the interior lights shut OFF. This protects the liner from melting due to the heat produced by the light bulbs. The alarm will sound every two minutes until the doors are closed. Once the doors are closed, the alarm is reset.
If the alarm keeps on going off after the doors have been closed and unit has been reset, I recommend contacting a professional technician so they can diagnose and repair your refrigerator.
Sep 10, 2012 | Frigidaire FRS3R5EMB Side by Side...
When the door closes there is a loud motor noise. When the door is open, the noise stops.
The noise is the recirculating fan, it shuts off when the door is open so heat doesn't rush in, I would locate the area and remove the cover to it and locate the fan and see if something (debris, trash and or insulation has made its way on it.
Apr 20, 2011 | LG LRBN20510WW Bottom Freezer Refrigerator
Samsung RS2534 Side by Side Refrigerator Logo
1,066 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
