Question about Makita 10" Compound Miter Saw LS1040
Makita ls1214f brake not working - Makita 10" Compound Miter Saw LS1040
Makita LS1216 is not sliding well, what do I do to make it slide better?
First, look underneath to ensure the lock mechanism is not dragging creating your trouble.
Second, wipe down the rails with thinner to remove any rosin from the wood - clean up any rust with a scotchbrite pad and spray down with 100% pure silicone spray (DO NOT use WD40 or the like - it will attract sawdust & debris and make the problem worse) If the problem continues you should replace the pillow bearing (not a job for the faint of heart I will warn you).
Best of luck
Aug 06, 2014 | Makita LS1214F { Disc. 12" Dual Slide Comp...
Makita LS 1212F brake
The brake on these saws is a controlled by the switch; it allows power to only one side of the field when you release the switch thus pulling the motor to a stop. In order to get your brake working again you have to replace the switch with Makita part number 651923-1, Switch TG70B. You can put in a generic switch that fits but the blade will spin slowly to a stop every time you release the switch, which you may have now.
Jun 29, 2012 | Saws
Which bolts do i loosen to adjust the 45% angle of my blade? Ive already squared up my blade by using a square and laid it down on the deck and squared the back rail like that> but how do i square...
To adjust the bevel, (blade angle), loosen the black lever at the back of the unit, tilt the blade housing using the handle (this may require a fair bit of force) until the arrow on the scale is at 45 degrees then tighten the black lever.
Dec 26, 2010 | Makita LS1214F 15 Amp 12 Inch Dual Bevel...
Switch wiring for makita cut off saw
go to makita.com enter yr model # in the search bar, down load a parts breakdown, it should b there
Aug 07, 2010 | Makita 2703 10" Table Saw, Electric Brake
MAKITA #2703 table saw 10'' to rise and lower blade it
i would say the table is twisted then, strip it down first and if you need to "bend!" it back so it works
Mar 27, 2010 | Makita 2703 10" Table Saw, Electric Brake
New uc3520a chainsaw will not work
240VAC European Model
From the Makita manual:
If the saw does not start when the ON/OFF switch (1) is actuated, it will be necessary to release the chain brake.
- Pull the hand guard (6) firmly in the direction of the arrow until you feel it catch.
electric motor does not function
no power supply
cable defective
chain brake actuated
Mains fuse blown
HTH
Lou
If these don't work return it, maybe it is defective. Test the new one in the store.
Oct 18, 2009 | Makita UC3530A 14" Electric Chain Saw
Makita Saw blade brake doesn't work.
If the model number is right it could be a couple things, I would try and blow the motor housing and area surrounding it with compressed air. Second I would FIRST unplug the saw and remove the brushes and check the condition, if they appear burnt I would replace them, if there is dirt or worn brushes it could cause a problem but before I got deeper into this tool I would recommend checking the date of purchase and seeing if it is still covered under warranty. This a fairly new model for them. If not let me know and I will look at a schematic for this and try and help more in depth.
May 03, 2009 | Makita 10" Miter Saw LS1030N
Makita table saw switch wiring
i need the owner/operator manual for a makita table saw model 12711 please tell me what steps to take to get one
Mar 01, 2009 | Makita Saws
Makita 10" Compound Miter Saw LS1040 Logo
70 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
