Question about Hagen 40 Watt Aqua-Glo Fluorescent Bulb
My aqua glo bulb keeps flashing on and off ,,whats wrong
Need a replacement ballast for glo double 54 inch T5 HO aquarium light
Hagen has a massive website and they sell parts for virtually everything they make.
This is one page from their Canadian site listing ballasts for their lights.
http://ca-en.hagen.com/SearchProduct/ProductPageSearch?page=1&resultsPerPage=25&keyword=ballasts
Jan 10, 2014 | Hagen Glo T5 HO Electronic Ballast for T5...
Need bulb DFC for Bell & Howell Model 256
what kind of lamp do I need for a Bell & Howell projector model 256?
I bought this projector but doesn't come with the bulb.
Aug 19, 2012 | Hagen Power Glo Mini Light Bulb
One of the oven pilot lights goes out frequently on a vulcan Model VG60-59
That particular socket may have a bad bulb contact or some loose wiring, which causes the bulb to blow. Unplug the lighting part of the range, remove the bulb and with a flash light inspect the interior of the bulb holder. If it appears corroded or dirty, clean it with a Q Tip sprayed lightly with WD40. Also, gently shake the holder if you can, to determine if it is loose. If it's loose, it should be replaced. Also, when you replace bulbs, make sure you are using ones that are designated as Appliance Bulbs. They can withstand heat and cold better than regular household bulbs.
Hope this helped you solve the problem.
Mar 22, 2011 | Dyna-Glo (PPH16-LP) Utility Heater
Nikon Coolpix S220 flash not working
Dear Sir, possible causes for the flash does not work is in the following order: Xenon tube drained, open coil trigger, circuit oscilator wrong.
In all cases you must use a specialized service.
Greetings
Mar 04, 2011 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
I HAVE A RAINSOFT UV AIR FILTER IN MY AIR DUCT WHERE DO I GET REPLACEMENT BULBS, AND WHAT IS THE PROPER BULB AND SIZE?
Cleanwater also has them. Clean them with rubbing alcohol, do not let your fingers touch the bulbs. And check your 24V ac adapter. If it starts going you will get a power light but the other lights will come and go. I have one and the bulbs are nearing the end of life, not a cheap fix.
http://www.cleanwaterstore.com/O1002250-p-clearwater-tech-parts.html
Jan 02, 2010 | Air Purifiers
Piloy light will not light , can light with match but will not stay burning
If you have a thermocouple on it, it is faulty.It is a copper lead that runs along side of the pilot tube. When working right, the gas filled bulb produces what we call Milivolts. These volts are what keeps the pilot on at the gas valve.Replace this pilot thermocouple or generator, and you will be good.
Good Luck, Shastalaker7
Nov 05, 2009 | Dyna-Glo RMC-8001SS Heater
My emachines lcd flatscreen monitor is flashing
No. You have a bad capacitor/s on the monitor's power board suggest replacing with new ones. Here is what a blown capacitor looks like. If you are comfortable fixing this yourself, good, you will save money this way. If it isn't a bad cap then it is probably a bad IC.
65daaa1.jpeg Notice the two round things side by side. The one on the left is blown.
l l
BAD
Jul 05, 2009 | E-Machines eMachines Desktop PC
Hagen 40 Watt Aqua-Glo Fluorescent Bulb Logo
70 people viewed this question
Top Hagen Fish Experts
Tom Chichester
Steve Dearman
Level 1 Expert
Karen J Gray
Karen J Gray
Are you a Hagen Fish Expert? Answer questions, earn points and help others
