Question about Whirlpool GI6FDRXXY
Ice formed in floor of bottom freezer compartment preventing the freezer door from closing. The door ajar warning light came on. I cleaned out ice, and the freezer door closes. However, the door ajar
Frost had formed inside the freezer too.
4 Suggested Answers
  • 531 Answers
SOURCE: Ice maker door dumps ice on floor.
you have to call service
Posted on Apr 02, 2009
aasc
  • 1606 Answers
SOURCE: The ice door does not close so ice has formed
Remove the top freezer hinge cover and disconnect the plug there . This removes power to the door . Between the grill and the lower portion of the dispensor cover , at the inside bottom , use a butter knife and push down and inward , to force the lower portion of the cover out slightly . Do this on both sides , being careful due to plastic tabs can break , Once bottom is out , lift the dispensor cover upward to disenguage top plastic tabs . Unplug the cover from the plugin . Remove the 2 screws holding the dispensor housing and slide outward . This gives you access to the door flap , flap spring and pin . You will be able to see the problem .
Posted on Sep 06, 2009
arikrom
  • 528 Answers
SOURCE: 3 1/2 year old whirlpool side by side has frost
hi ,
your freezer cabinet need to get all out and open the back wall.
  1. you have 2 element that can be check one is the heating element , two is the thermostat.
  2. you need a volt meter to check them.
  3. if the frost is all over the coils then one of the element i told you before, is bad
  4. if the frost is in one area not all over then you got gas leak.
  5. good luck
  6. 911servicetoday.com
Posted on Jan 04, 2010
How to fix kitchenaid kbfc42fts bottom freezer builds up ice and leaks on floor
The drain line is clogged go around the back of machine take off back cover and you will see a drain line coming through the floor and at the end of it is a rubber grommet.The rubber grommet is clogged up just take it off and throw it out and then turn off machine for 24 hrs with doors open to melt out all the ice
Aug 08, 2014 | KitchenAid KBFC42FTS 42" Bottom Mount...
Kenmore side by side. Noticed water dripping out
please do not use hot water.........only clean drain hole with copper wire with very small cloth on
end.sounds like you left door open? adjust feet to allow door to close itself..if left ajar.
fully defrost.clean drain hole.adjust feet. switch on ...
this freezer works best full....
Feb 04, 2010 | Refrigerators
ICE GATHERS AROUND THE DOOR OF THE FREEZER COMPARTMENT
very possible the door seal is bad. Take a dollar bill and close it up in the door and see if has some resistance when you pull it out if not the seal needs replacing.
Jan 24, 2010 | Amana ABB1927DE Bottom Freezer...
Ice build up
Same repair as water leak on floor. unplug, remove back inside panel of freezer, clean out drain hole.
Jan 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Frigidaire, ice on floor of freexer
check to see if the defrost drain is not frozrn over or stopped up
this is the only way that water can get into the freezer
frost could and melt but dont think that i would check the drain at the bottom of the rear freezer panel if you see ice it is stopped up for sure
if all is clear there go to the ice maker, have had some that are overfilling and runnig over the ice maker into the bottom of the freezer
Jun 23, 2008 | Refrigerators
Flat ice forms at the bottom of the freezer compartment
check your freezer door see if it (ajar) what you can do if you can unplug unit clar drain with hot water then get apiece of shave wire hook on the defrost heater and put in drain line 1/8 in the drain line put back wall back together and plug unit in
Apr 07, 2008 | GE Profile 21.6 cu. ft. Side-by-Side...
Ice at the bottom of the freezer
It sounds like the freezer has leaking door seals and air is getting in to the freezer compartment. Your temperatures are set about right. Regards
Oct 02, 2007 | LG LRFD22850 Bottom Freezer Refrigerator...
Ice Sheet on floor of freezer
Check nothing is holding the door ajar, and that the door seals are closing properly all the way round. The abnormal thing about abnormal ice buildup isn't the fact that it's frozen - it's the fact that the water is getting in. The only way water is going to get in without you noticing it is in the form of moist air - and the biggest, most regularly disturbed way in for moist air is the door and its seal. A.
Feb 24, 2007 | Hotpoint HSS25GFP Side by Side...
Whirlpool GI6FDRXXY Logo
67 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
