How to enter bios setup of toshiba satellie L600-25R
  • 826 Answers
Follow the given links to get your answers...
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/bulletin.jsp?soid=627009
Posted on Jan 17, 2013
  • 5 Answers
SOURCE: toshiba bios setup
When you just switch on the computer look out for the first screen(before windows even starts up).and try to quickly read usually it will tell you what button to press.depending on the make its usually f12 or del but first check what your model says.
Posted on Mar 09, 2009
  • 13433 Answers
SOURCE: reset bios password in satellite 1135
I have a solution here right here next to me on how to reset it. but I'm not going to post it on this public board. email?
Posted on May 27, 2009
remove the power cable, batter and the cmos battery from the computer, wait a couple of minutes and reassemble. The bios with the password will be reset.
Posted on Oct 10, 2009
fixtor
  • 68 Answers
SOURCE: what is the key to enter bios setup in a Toshiba
you can enter system setup in a toshiba system by pressing the esc key or the F1 key on the startup screen.
Posted on Jan 31, 2010
  • 693 Answers
SOURCE: how to enter bios setup
1. Enter BIOS Setup
1. Press the Esc key while powering on the computer.
2. Press the F1 key, when prompted.
2. Change the Virtualization Technology option
The Virtualization Technology option is in the OTHERS configuration pane on the right-hand side of page 1 of the BIOS system setup.
1. Press the O key to select the OTHERS pane, and use the down arrow key to move down and select the Virtualization Technology setting.
2. Set it to Disabled.
3. Change the Configuration option
The CONFIGURATION option is on the upper left-hand corner of page 2 of the BIOS system setup.
1. Press the PgDn key to go to the second system setup page.
2. Press the O key to select the Device Config setting and change it to All Devices.
4. Change the Display option
The DISPLAY configuration option is on the bottom left-hand side of page 2 of the BIOS system setup.
1. Press the D key to select the Power On Display setting and change it to LCD+Analog RGB.
5. Save the changes by pressing the End key and then the Y key to. Be sure not to press the Home key -- which restores the default BIOS settings.
Posted on Aug 14, 2011
Vga setup of tososhiba satellie P6100
You can download the video and device drivers for your model laptop from the Toshiba WEB site from their download page. Make sure you enter the model of your laptop so you can get the correct drivers. Please click on this link: - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
Nov 03, 2012 | Toshiba Satellite 4010CDS Notebook
How to do i enter bios setup in toshiba 5205-s705
Hold down the F1 key, then, while continuing to hold it down, press the power switch. the system will turn on, then prompt you to check system and press F2 (thats from memory, it maybe F1 again) to enter BIOS.
With many Toshibas you can hold down any key to do this, as it simply generates a keyboard error, prompting the same message.
Hope this info helps.
May 19, 2012 | Toshiba Satellite 5205-S705 Notebook
When I turn the laptop on I see the Toshiba screen for just a second and then it instantly goes to this lovely black screen that says password= How this got there I have know idea. Can anyone help?
Dear beanbean,
This "lovely black screen" is a BIOS password screen. This shows up because somebody has set a boot-up password in the BIOS Setup. If you're lucky, the BIOS Setup is still unprotected, and you can access it as follows:
When you turn it on, look for something that says "Press [button] to enter Setup" or "Press [button] to enter Setup Utilities." Press the corresponding button on your keyboard, and you should enter BIOS Setup.
Now two things can happen. Either you are permitted to access Setup, or you are prompted for the password.
If you can access Setup, navigate to the Security tab and clear all set passwords.If not... then you can either reset BIOS by unplugging the computer, taking off the back, and removing the CMOS Battery (unrecommended), or you can call Toshiba support and ask for the master password (Most manufacturers have a master password, which will allow you to access Setup and remove the boot-up password)
Hope this helps,Ericthecmh
Sep 13, 2011 | Toshiba Satellite A105 Notebook
I can't enter in setup
Hi,How to enter setup page or the BIOS page
Brand : Toshiba - MOdel : Portege, Satellite, Tecra, EquiumPress F1 or Esc after powering on the computer to access BIOS.
Model: Toshiba Equium.Press F12 after powering on the computer to access BIOS
Apr 19, 2011 | Toshiba Satellite A45-S150 Notebook
How do i clear cmos baterry on my toshiba satillite A205?
Start your computer, and enter BIOS SETUP.
Select "Load BIOS Defaults".
Save & Exit from BIOS SETUP.
Aug 29, 2010 | Toshiba Satellite A100-S8111TD Notebook
Black screen with a enter pass word
The BIOS password is removed by the BIOS configuration, you need the BIOS password to get into the BIOS configuration.But if you do not have the BIOS password then you need to construct this dongle device.
TOSHIBA BIOS PASSWORD DONGLE
You can build a dongle that plugs into the printer port.Purchase a 25 pin male D sub connector and solder insulated wires to the various pins as listed below. The pins are numbered on the connector
http://www.tilman.de/sonstiges/toshiba/dongle1.jpg this is a picture of the finished dongle
Wire the pins as follows :-1-5-10, 2-11, 3-17, 4-12, 6-16, 7-13, 8-14, 9-15
Plug the finished dongle in the printer port and power up the laptop. The password will be reset, go into the BIOS configuration to check the BIOS password, you may have to disable the BIOS password..
OR there are other places that will sell you a "Key" for a price.
OR you can provide "Proof of Ownership" to Toshiba, and they will sell you a "Code" to remove the Anti-Tamper, Anti-theft, protection.
Apr 07, 2010 | Toshiba Satellite A135-S2276 Notebook
Is there any way to reboot toshiba satellie a55-s106 without cd?
You can buy a flash drive and load the cd onto it using another computer, if this is a option in your bios, then this will work.
In your bios, it is called Removable Media, start your computer and press F10 (or another key depending on your system setup), go to the boot sequence tab and move "media" to the top. save and exit. Restart and enjoy!
Aug 02, 2009 | Toshiba Satellite A55-S106 Notebook
Reset bios password in satellite 1135
May 30, 2009 | Toshiba Satellite 1135-S155 Notebook
May 27, 2009 | Toshiba Satellite 1135-S155 Notebook
Computers & Internet Logo
116 people viewed this question
David Payne
David Payne
