Question about Maytag Bravos MVWB700V Top Load Washer
Mvwb700vq0 POS, blew drain pump, fried the harness wire at the pump, now I get an f-51 and an f-41 and I replaced the MPS. Now they tell me the main control is fried, has any one else had this problem?
  • Maytag Master
  • 17,129 Answers
You must have some lines shorted, wires interconnected, water in the panel or fault in connectors because there is too much damage due to the electrical/electronic section that UNLESS it is double checked a new board should not blow off again and cause a heavy loss to you. Request for consensus and estimate
Posted on Jan 17, 2013
Whirlpool duet code f33
The F33 error means that the washer control unit didn't get the expected response from the drain pump drive during a self-test (before starting the washer cycle). This is usually a wiring issue. Unplug the washer and drain out any water in the unit. Remove the clothing and pull the washer out so that you can reach the access panel. Take a look at the wiring between the drain pump and the CCU (control unit) DP2 connector. Make sure that all of the wiring harnesses are connected. Look for any broken wires or ones that are detached from the wiring harness. With an multimeter, check for continuity in these wires. If there are any broken wires, replace the wiring (Main Harness).
If the wiring is okay, check if the drain pump filter is clogged with a foreign object. Disassemble the drain pump and check if the impeller is intact and on its shaft. Replace the pump if the impeller is damaged. Reconnect the power to the washer and check if the error recurs.
I hope this helps. If you add a comment with the model number, I may be able to provide more information on the parts.
May 22, 2015 | Whirlpool Washing Machines
My 04 suzuki katana 750 has a battery draining problem
You definitely hooked something up wrong. Get a wiring diagram for the exact bike you have and try again. Oh, the regulator is probably fried. Sorry.
Apr 03, 2014 | 2004 Suzuki GSX 750 F (Katana)
Frigidaire plef398dca
Hello Bill Robbins - From what you are describing it sounds like a wiring failure or a communication break failure between the power board and UIB has occurred. Error code F5, typically indicates that the EOC will need replacing. A certified technician will need to test the wiring harness between the ESC, UIB and EOC.
Jan 21, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
My front load washer is making noise and wont drain its spinning just not draining water
several pos solutions.coins or debri in pump.chk drain pipe to undersink drain is not blocked /ie cooking fat from used plates ,frying pans ect. or pump could be defective, happy hunting
Dec 30, 2012 | Washing Machines
My son accidentally the pos and neg speaker wires together and the fuses blew on the amp and now the power light wont come on at all do you think the amp is damaged?
If I had to guess by touching the positive and the negative terminals together it probably fried up the transistors. While back I did the same to my amp and poof amp no longer worked. Took the amp apart to find the transistors fried up. Ordered them from the manufacturer but never installed them, ended up buying a new amp. Mainly, replacing the amp doesn't mean it would fix the problem....
Feb 22, 2011 | Kenwood KAC-9102D Car Audio Amplifier
I accidently put my battery in my car wrong way have changed it back after starting my car now the central lock/heater/inside light eletric windows dont work until i start the car
u blew ur fuse look the fuses under dash replace the ones u blew n u more likely blew 1/2/3-4 under dash to check them u sent back current thru live wires n grounded wires that arent suposse to have juice going thru to etc. u may even zap ur altnator the few times ive crisscrossed them i fried altnator or fuse but thats what fuses are meant for to much of one or another current to it zaps cuts off electricity going to so it dont zap it protects the main area from being fried so easily
Aug 31, 2010 | Mitsubishi Lancer Cars & Trucks
Wiring harness to radio
I have a naxa nx-690 and can you tell how the wires goes on the harness because I pull the harness real hard and some of the wires came out of the harness plug
Dec 05, 2009 | Naxa Electronics NX-690
My friends lil brother tried to jumpstart a car with the bike, well in the process he got the pos. and neg. cables mixed up when he connected them to the battery. i think he fried the wiring harness. the...
Hi and welcome to FixYa,
To address the "...bike is dead...", initially:
  • externally charge the battery;
  • chec/replace the 30 Amps main fuse located at the starter relay;
  • to locate the starter relay, follow the big cable from the battery's + terminal;
  • if the fuse blows,. disconnect the regulator and replace the fuse to try again.
Postback results of initial tests.
Good luck and thank you for asking FixYa.
Jul 10, 2009 | 2004 Suzuki GSX 750 F (Katana)
Fuse keeps blowing out in my maytag washing machine
the power surge probably shorted out something in the main wire harness or fried your motor. remove the screws from the control panel and look for any wires that are discolored, charred or disconnected. in the event you do't find it there trace the wiring thru the cabinet looking for the same thing. if you don't find that, replace the motor
Nov 16, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Bravos MVWB700V Top Load Washer Logo
50 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
