Mp7500 error sc-547 - Office Equipment & Supplies
5 Suggested Answers
SOURCE: sc 547-00 error code
Call a tech. Fuser error, can only be reset in service mode after the problem is fixed
Posted on Mar 31, 2009
  • 990 Answers
SOURCE: I have lanier 5218 which
Hello sir; Let's do a reset procedure; press "clear mode" enter 107 then press "clear/stop" key for 3 second, then select copy sp, enter 5810 to reset.
Posted on Aug 29, 2009
SOURCE: ERROR SC 547
Zero cross signals are not detected within a certain period within 500 ms after the main power switch has been turned on.
Possible Causes
• Power supply board defective
• Noise on the ac power line
Try conect the copier in other side.
Disconnect all the household-electric of the place.
Posted on Mar 27, 2010
Daniel S
  • 4323 Answers
SOURCE: How can I reset a
Hi
Error code sc 547 means "Zero cross signal malfunction". This error appears due to a faulty power supply. This error code may also appear if the input board is defective or the BIC Unit is defective. Turn off the printer and unplug the printer for 30-40 minutes and check if the error still appears. If you see he error still appearing then try and rest it using the following reset method--
To reset the SC code by entering SP5810 and select 1.
Now hold down the photo mode key and the # key at the same time for at least 3 second.
Then turn the machine off and on again.
If the same issue still appears, you'll need to check and replace the Power supply or the Input (IOCC) boardt.
Hope it helps...
Posted on Oct 11, 2010
Ricoh mp7500 error sc 550
hello
replace the web and run from the service mode ( yellow c , 1,0,7, red c push from 5 second)
sp1902 001 # must to do ' 0 '
restart and thats it
Dec 14, 2013 | Office Equipment & Supplies
How can I reset a SC 547 error on a Ricoh Aficio SPC 811 DN? I've already replaced the fixing unit.
Hi
Hope it helps...
Oct 11, 2010 | Ricoh Aficio 150 Copier
Ricoh aficio 1085 sc 547
Thie is a fuser error code enter service mode to reset. -Carl
Jun 09, 2010 | Ricoh Office Equipment & Supplies
Error code facsimile error red wrench sc547 ricoh aficio 180
there may be a problem with your electric supply(wall outlet) , wrong voltage or power supply bad
Jan 07, 2010 | Ricoh Office Equipment & Supplies
I have a nashuatec D445 and it is indicating an error code CS 547-00 what can i do to solve this problem?Please help.
Press 'Function Clear', 1, 0, 7, then press and hold 'Clear/Stop' button for 3 secands. Machine displays SP Mode. Now turn MAIN power switch off for 5 seconds. Turn MAIN power switch back on. This should reset SC 547 code. (Main power switch is located on the left side of the copier)
Dec 15, 2009 | Ricoh Aficio 450 Copier
Error code, SC 547 on a Ricoh Aficio 1075
have you tried sc reset through the service mode and then turn off .. you can get to this by pressing yellow clear button then 107 then hold down the cancel stop button..wait for the screen to change then go to mode 5 and you need to arrow down to sp 5 810 sc reset execute turn off the copier and try turning on to see if it clears.. if not the ac board maybe defective caused by a power surge or static down the line..
Aug 05, 2009 | Office Equipment & Supplies
Sc 547-00 error code
Mar 28, 2009 | Gestetner Office Equipment & Supplies
470 people viewed this question
jasbo
jasbo
