Question about Northwest Territory Full Size Air Bed - KMART CORPORATION
Lost valve or air hole cover for air mattress
I can figure out which way the deflate valve turns to open and let the air out of the mattress
You don't say what kind of mattress you have but if it is a Thermarest you turn the valve counter clockwise to release the air. After opening the valve you then need to roll and compress the mattress to force the air out, starting at the end opposite the valve. Once you have rolled all the way to the valve end, close the valve (turn clockwise) to prevent the pad from re-inflating itself.
Jul 05, 2017 | Camping, Backpacking & Hiking
Need a replacement valve cap for an Embark Queen air mattress
I went to dirt cheap yesterday and purchased a Embark Air Mattress and once I got it home I discovered that the mattress didn't have a valve cap. I want to know if you could replace the cap without any cost? If you would like to send me one here is my address P.O. Box 282 Blue Mountain Miss 38610 Thanks for your help
Feb 16, 2014 | Embark Queen Pillow Top Double High Air...
I have lost the cap to my Quest queen air mattress. How can I get a reeplacement?
You can find a pair of Boston valve caps by Kwik-Tek on Amazon for $5. I don't know for sure for you, but I've never met a boston valve that these don't fit.
Jun 01, 2013 | Camping, Backpacking & Hiking
How do I deflate my air mattress?
Some pumps come with a deflate setting so make sure to check that first. If not, you need to unscrew the cap off the valve and listen to hear that air is escaping. Then remove your shoes and walk up and down the surface of the mattress. Once you have done this a few times, you will be able to roll up the mattress from the end opposite the valve.
Jul 31, 2012 | Camping, Backpacking & Hiking
I just found a small hole in my air mattress. How do I properly fix it?
When you bought your air mattress you will have most likely received a patch kit. If not, you can purchase one at most stores selling mattresses/camping gear. Simply follow the instructions on the patch kit - make sure to cut a patch slightly larger than the size of the hole. Allow 24 for the glue to dry before re-inflating your air mattress.
Can I use my air mattress outdoors?
Yes you can. Most air mattresses are designed for outdoor use. I would suggest placing the mattress on a tarp while sleeping to avoid puncture holes from twigs and stones on the ground.
Jul 25, 2012 | Furniture
What is an air mattress?
An air mattress is an inflatable mattress generally made of PVC vinyl plastic or urethane plastic. These mattresses are great from easy storage and transportation. They are either inflated by blowing air into a valve or by using an electrically powered foot pedal.
What can I use to repair a small hole in my coleman air mattress?
Hi rh57...
I will recommend that you use some contact cement, and a piece of thin plastic like a plastic drop cloth, shower curtain, etc.
Cut the plastic piece that will be using as your patch about 1" X 1" square.
Locate the hole in the air mattress, deflate air mattress, apply contact cement lightly to the air mattress approximatly 1" X 1" and the piece of thin plastic material you will be using as the patch over both entire surfaces of the patch and mattress...let it all dry about 20 mins.
After it is dry then apply the patch to the hole in the mattress, apply a weight to the top of the patch, let sit about half an hour and you are done
Hole fixed
Please take time to rate me thumbs up
Sep 14, 2011 | Garden
I cannot find a manual for a blue magic super pump
See the instructions near the bottom of this web page: (picture at the top of pasted instuctions on th link)
http://www.abcwaterbed.com/pump2.htm
  1. IMPORTANT! - Unplug waterbed heater for safety
  2. Remove cap and seal and put aside in safe place.
  3. Remove any excess air from mattress - slide forearm or broom handle from the head of the bed toward the fill hole to move air pocket
  4. Attach the heavy duty hose to the hose valve coupling, connect to the waterbed mattress and other end to the pump intake side. Be sure to include O-rings. Gently push the coupling deep into the mattress.
  5. Attach garden hose to the discharge side of the pump, this hose goes to a tub, or a deep sink.
  6. Plug in the pump. When it starts it should have a low whirring sound, not a high whiny one. If water is not pumping immediately unplug the motor and check hose connections for tightness, verify there is no air in the mattress.
  7. As the pump removes the water, be sure the hose valve coupling at the mattress is pushed down in the mattress to maintain suction. Heavy phone books or other like items will help maintain proper position deep in the mattress.
  8. Keep pumping the water out and continuing to maintain the hose valve coupling position low in the mattress so it can keep pumping.
  9. Do not leave the pump or the area until finished. A dry pump can burn up.
  10. When the mattress is part way empty, you can place pillows under it at the head to help the water run downhill towards the hose valve coupling.
  11. Continue pumping until water flow stops or pump changes sound. The more water you get out, the easier your mattress will be to handle.
  12. If you are satisfied you have got as much water out as you can, remove the hose valve coupling and quickly replace the mattress seal and screw the cap on.
  13. If the mattress is to be stored for a period of time, pour in a large bottle of waterbed conditioner into the mattress before you cap and seal the mattress.
  14. We recommend rolling up the mattress from the head to the foot and carefully sliding one end into a wardrobe box. Another wardrobe box can be worked over the top of the mattress. Work one box into the other and seal both ends and tape the boxes together in the middle. You can now safely move the mattress.
  15. If you don't get enough water out, the fiber layers can easily slide out of position during moving and you may not be able to get them back into position when you fill the bed.
Nov 18, 2010 | Magic Pool & Spa
Northwest Territory Full Size Air Bed - KMART CORPORATION Logo
91 people viewed this question
Top Northwest Territory Rock & Ice Climbing Experts
Makenzie Floyd
Level 1 Expert
RatanbssBD
Level 1 Expert
Are you a Northwest Territory Rock and Ice Climbing Expert? Answer questions, earn points and help others
