Nintendo Wii Console
Problem for Nintendo Wii Console
Wii will not CDs anymore
By eddy1 on Jul 11, 2007
Hi All - My son put 2 cd inside the console and I got them out, but now it won't load any CDs. It just makes a load clicking noise, but won't take the CD. Any ideas?
Thanks,
Eddy
Same Problem
Sep 30, 2008
-   now do i open the console
-   Guest
Aug 07, 2008
-   i have the same, but i didnt do anything to mine i played a gamecube game last night and this morning i put a cd in and it just clicks quietly -   Guest
May 26, 2008
-   Ive tried putting 3 different CDs in my Wii console and the Wii will not accept any of them. It just makes clicking noises. -   andrewti
May 26, 2008
-   everytime i put in a disc it will not read it or sometimes it even falls out!! HELP!!!!!!!!!!! -   Guest
Jan 11, 2008
-   My Wii just stopped taking CDs after it stopped reading them after i was changing games!!!-   Guest
Best Solution
posted on Jul 27, 2007
Helpful)
esadun
Rank: Apprentice
Rating: 90%, 14 votes
continuous clicking could be a few gear-related issues:
-if the pinion gear is slipping against the rack for the disc-load mechanism, you can try to re-align the rack (hopefully it was just forced out of place and can be clicked back). i would suspect this if the noise is relatively quiet and very fast.
-if something is jamming the load mechanism, like the rack is stuck, the pinion gear may be clicking over the teeth of the rack. i would suspect this if the noise is loud and slower.
Either way, you'd probably need to open the console. )=.
Was this helpful?
Yes
No
Solution #2
posted on Jul 13, 2007
Somewhat Helpful)
Daniel9
Rank: Guru
Rating: 87%, 301 votes
Clicking sound is normal, but do they stop or continue? my Wii make some clicking sound when loading up but then its stops.
What I suggest is to see if your son damaged the discs and not the console, try to clean them or try them in a different console to see if they work. If they work in a different console that's means your son broke something when entering the 2 discs... and it need to be repaired.
Here are some instructions of how to clean your discs:
1. Use a soft, slightly damp cotton cloth (use water only). Clean the disc from center towards the edges. do not use a circular motion % DO NOT use paper.
2. Make sure the game is dry, then re-insert it and see if the error occurs again.
3. If you make the game working after cleaning it but still have some problems that might mean that the disc is damage and you should try to replace it.
Like I wrote before if cleaning doesn't work or it works in another console, you should repair it.
P.S please use you user name from the beginning Eddy1
Was this helpful?
Yes
No
Solution #3
posted on Jul 11, 2007
Somewhat Helpful)
davin
Rank: Guide
Rating: 70%, 21 votes
hoy about you take out the 2 cds
Was this helpful?
Yes
No
Solution #4
posted on Sep 29, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
rsfgsfgsdfg
Popular Solutions for Nintendo Wii Console
Questions and Unsolved Problems for Nintendo Wii Console
Do you recommend Nintendo Wii Console?
Answer
Answer
I cannot get past the language menu. I have a home theater system and tried hooking to it and also... (More)
Answer
wii worked perfectly , then child has inserted 2 disks at once, dont know how either together or by... (More)
Answer
why is the wii stuck on press "A" button, but does nothing when you push it
Answer
While playing Madden 08 playing in the same file when switching from rookie to pro the game freezes... (More)
Answer
for nintendo wii what channel should the tv be set to? i do not have a remote, so i can only choose... (More)
8 Other Users Have The Same Problem - Continued
Comment by gsmith, posted on Dec 25, 2007
mine is new for christmas and won't take a cd in. Any ideas?
Comment by TIle Lady, posted on Dec 25, 2007
My Daughter forced the disc it. It would not read nor eject. We finally got the disc out but it will not grab a disc when inserting. The machine makes a noise like it is trying to grab it but it doesn't.
Comment by Guest, posted on Nov 10, 2007
same here, it will suck in a dvd click really fast/loud then spit it out.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Video Game... Experts
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
