Question about GE Refrigerators
Refrigerator fell over on me
I opened the door and the whole refrigerator fell forward, trapping me under it. It hung over me at a 45 degree angle suspended from the wall by the cord. The glass vases and other objects on top, as welll as all the glass bowls inside fell out and broke on the floor around me, trapping me. I was able to push enough glass away to move after two or three hours on my face, with my arms trapped under me.
    Habit-Forming:
    New Friend:
  • 53 Answers
Get a good lawyer!!!!
Posted on Aug 03, 2017
SolutionGuy
  • 331 Answers
SOURCE: The bottomw freezer door on our Amana refrigerator won't open
Let it thaw, just like you're doing. Afterward, the door will open. You might be able to speed the process with hot water and a turkey baster. Beginning at the top of the door, take the business end of the baster and stick it between the door gasket and frame and squeeze. 'Course this will make a mess, but you won't lose the food that's in the freezer, right?
Write back and let me know what you find when you get the door open. Like was there a slab of ice on the freezer floor? Frost build up on the wall? Stuff like that. It'll help me figure out what caused this.
Another thing, when you write back, include the model number and manufacturer number (These are listed on a sticker inside the fridge). With those numbers, I can look up a door handle for you.
SG
Posted on Mar 27, 2009
SOURCE: Refrigerator won't fit thru door.
I ran into the same problem when I moved into my old house. the door way was to small, so I had to take both doors off the refrigerator to get it through the doorway. But I found out when I moved out of the house, that I was able to open both doors and wiggle it through the doorway. It was a hassle but it was alot easier that removing the doors. Good luck.
Posted on Apr 20, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Frost inside and ice on floor of freezer
The water can only come from 2 places, the drain is blocked or the ice maker is over filling.The temps are too good to have any other things going wrong. Let me know, Thanks, Sea Breeze
Posted on May 19, 2009
SOURCE: Refrigerator door fell off.
Fridge fell off in my hand. I understand the idea of how it works on a lower and higher metal pivot. The pivot closest to floor seems to be missing a washer, screw or nut. I need an illus of what may be a missing part. Then an idea of how the door is lifted onto said pivot- With Ease!!
Posted on Jan 17, 2010
SOURCE: ice maker trap door, ice will not come out, gets clogged in door
why does ice cube door builds up with ice
Posted on Feb 05, 2010
Dyson 35 fell over and the trap door that opens to let you empty the dust fell off .
Very hot water to soften it a little. Put the one part in at an angle and then move it to level as the pegs drop in.
Nov 20, 2016 | Refrigerators
How do you get the bobbin plate out of husqvarna long arm
I'M NOT SURE OF THE TYPE OF SEWING MACHINE MACHINE MODEL YOU'RE USING BUT HERE WE GO: SOME MACHINES THAT HAVE THEM ON THE END WILL SLIDE TO THE END. THEN YOU CAN BEST RELEASE IT BY SLIDING IT TO A 45 DEGREE ANGLE AS YOU CONTINUE TO PULL. THERE ARE SPRINGS UNDERNEATH TO KEEP IT FROM RATTLING OR MOVING FROM YOUR CLOTH MOVEMENT. NOW, ANOTHER ONE IS DIRECTLY UNDER THE NEEDLE AND MOVED TO A 45 DEGREE ANGLE WHILE YOU CONTINUE TO PULL FORWARD AND MOVE THE ANGLE TURN AS THE SPRING RELEASES. THESE SPRINGS MUST BE PUSHED DOWNWARDS WITH A HARD, THIN OBJECT TO PUT THEM BACK. THE THIRD ONE SCREWS. JUST TURN THEM AND THE PLATE WILL COME OUT.
May 26, 2014 | Bernina Artista 180
I have th lg dlgx3002w dryer. the garments get hung up in the lint filter and tears the garment. the edge of the filter is slightly melted. what causes this and how can i keep this from happening again?
I had the same problem. My LG dryer lint trap did the same thing and I ordered another one for replacement. The new lint trap is not rounded on the batton on the corner below where it got bent up and snagged your clothes. The new one is cut at a slight 45 degree angle. I believe that LG changed the design a little so clothes won't get hung up on that edge. Go to this site and you will see a picture of the replacement part. http://www.appliancepartspros.com/lg-dryer-lint-filter-adq56656401-ap4457244.html
Feb 06, 2011 | LG DLE5977 Electric Dryer
Is there a way to adjust the refrigerator door so it will stop at a 45 degree angle rather than swinging on back?
check the level of the fridge. If you adj.till it is level the door will stay wherever you stop it. Usually they are adjusted till the door falls shut if started so the door is not left open
Oct 28, 2010 | KitchenAid Superba KSRG25FK Side by Side...
How to remove an oven door on a Kenmore self-cleaning oven
To remove door open to a 45 degree angle or till it opens at an angle not 90 degrees then pull the door up at that anglr off the hhinges.
Sep 14, 2009 | Kenmore Kitchen Ranges
Refrigerator Fell While Moving
Probably none. Electrical connections are in wireing harness and only moving parts are the fans and these parts should not have been damaged.
Aug 08, 2009 | Refrigerators
1999 saturn 3 door. Driver door hinge part # 21170657 removed old piece one nut on door two on frame. removed plastic whell well cover to get to back to install new part but can't find access.
I just replaced my hinge on the passenger side, I will assume you took the old one out by pushing it forward ( it then fell to the floor area and you retrieved it. The new one should align close to the opening and you will need to pull it through with needle nose pliers You will have to practice aligning the threads into the openings. I started on a 45 degree angle, it took me 5 tries before it lined up for the nuts.
Dec 20, 2008 | 2002 Saturn SC
Opening door wider than 45 degree angle
Does your door hit a wall behind it?
I have seen this situation the fridge had to be rolled or pulled out far enough that the door then can be swung open more and for the door bins had to be taken off to get the crisper out.
But if you have a Sub Zero that can be a problem!
How did it turn out?
Huum
Sep 08, 2008 | Sub-Zero 650 / O Bottom Freezer...
Oven stops after a few seconds
I like the information you give.
If the unit will work with the control Panel at a 45 degree angle it tells me you have a loose connection. The 45 degree angle puts enough pressure on the connection to keep it completed. With the Control Panel in it's normal position, the loose connection Heats and Opens the connection. After it cools connection is again made until it Heats up again. Remember Expansion, Contraction. I do not believe you have a Magnetron issue!! A Magnetron does not know if the Control Panel is at an angle.
Can you hear a slight "Click" when the unit shuts down? If so this is a relay opening. When you say you replaced the Control Board. Was this the Control Panel PC Board, or was it the Cook-Relay Control Board? A Door Switch not making solid contact can do this. Is your Door latching down solid? Check for loose connections, not open LOOSE.
Jan 27, 2008 | GE JVM1650 1000 Watts Microwave Oven
Open the modem door
The modem door does not open beyond a 45 degree angle to the base unit. Damage to the modem door will occur if forced open beyond a 45 degree angle.Open the manual for additional details.
Sep 14, 2005 | NEC MobilePro 900 Handheld
Refrigerators Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
