Question about Onkyo TX-8511 Receiver
Onkyo TX-8511 right side speaker channel not working
I have a 4 yr. old TX-8511, right side speaker channel is not working. I can swope the speaker cables and that does not help.
ctf1800
  • 4402 Answers
SOURCE: Onkyo Tx-SR55
did you swap the left from speaker with the left front?
if still crackels after that them you have bad left output.
Posted on Jan 09, 2008
lynchms
  • 93 Answers
SOURCE: Powered Or Unpowered Subwoofers For Onkyo TX-8511
Greg- Powered subs are better than non-powered subs (also known as passive subs), anyway I see the TX-8511 has no sub pre-out on the back panel, so you need to decide what sub you will use and run from the receivers left and right speakers output into a subwoofers speaker in from speakers then back out to speakers, look at the back of a subwoofer and you will see like 4 sets of speaker hookups 2 in and 2 out, what this does is takes the low end or bass and drops the signal to the subwoofer then takes the mids and highs out to your left and right speakers, unless your regular left and right stereo speakers have large woofers a sub is the way to go.
Posted on Jan 28, 2009
Gurudristi
  • 98 Answers
SOURCE: I just hooked up my old Onkyo TX-8511 receiver to
Just check your speaker cabling again. Make sure that all of them are seated properly, none is touching each other or the body of receiver. Rewire if necessary..
Are you using banana plugs for connecting speaker or just directly. Some times even a little tiny wire touching the receiver could trigger the protect mode. Be careful, since protect mode is sometimes not fast enough and it could blown a few trasistors in the power circuit.
Otherwise, do your bose speakers play out load on other systems?
Posted on Mar 09, 2009
gokomets
  • 120 Answers
SOURCE: I must have hit some buttons on the remote
Reverse left and right speakers at back of unit
to verify if a speaker/wire problem. Also check
all functions for same problem!
Posted on Apr 12, 2010
  • 1525 Answers
SOURCE: Onkyo TX-DS696. No right channel speaker sound
hello there 2 transistor 1 for the right channel and 1 for the left first thing 2 do is a visual check in good light check for any burn't part or any bulging capacitors if everythink looks ok then check underneath the board for dry joints if then you will need a mulitmeter to start testing components
regards
shasun
Posted on May 15, 2010
Testimonial: "Thanks - i'm gonna hv to take in in for the experts as i couldnt see anything visually."
My speaker "B" channel has gone out. Is this an
Maybe I'm misunderstanding the problem...
One speaker? Why would you have one speaker attached to A or B? A and B represent speaker pairs and are driven by the same two amps.
It's also not clear if you're saying the speaker is failing or the channel. You CAN swap them to find out.
Either way, the amps are common to both speaker pair connections so if only the B pair isn't working at worst you have a switch problem.
Jul 01, 2011 | Onkyo TX-8511 Receiver
Hi, I have a TX-8511 Onkyo. The left channel is silent. It's not the speakers or the wiring - checked and swapped. Using 8 ohm speakers and switch is set to 8 ohms. Does the same thing on both A & B -...
hello 1 of the transistor could be dry jointed if joint ok then you may a leak on the transistor also check the capacitor around the transistor for bulging all the best
regards
shaun
Sep 13, 2010 | Onkyo TX-SV373 Receiver
I must have hit some buttons on the remote unintentionally - all of a sudden I lost the sound out of the left speakers on my Onkyo TX-8511
Jan 30, 2010 | Onkyo TX-8511 Receiver
I just hooked up my old Onkyo TX-8511 receiver to my bose speakers, which is also hooked up to a subwolfer. When I turn the volume up the system goes into protect mode. Any solutions.
Mar 08, 2009 | Onkyo TX-8511 Receiver
Onkyo tx8511. Receiver working fine, power went out
Is channel B switch turned on? If so turn it off .
Feb 27, 2009 | Onkyo TX-8511 Receiver
Jan 28, 2009 | Onkyo TX-8511 Receiver
T.v.
If you have a VCR it is easy. Just plug RCA cables into audio out right and audio out left (on VCR) and other ends into VCR audio in right and left at rear of your receiver. If there are two sets of video audio inputs, push button on front of receiver to agree with where you plugged cables in. (ie. Video 1 and video 2)
Dec 18, 2007 | Onkyo TX-8511 Receiver
Onkyo TX-8511 Receiver Logo
83 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
