Question about Panasonic Televison & Video
Aim tv lcd alcd32s stuck on usb screen - no remote to fix
46 LCD tv iLo USB block out
Please press SOURCE key on remote control. Select the desired input option from the list on the screen.
Apr 16, 2015 | LG 32LG30 32 in. LCD HDTV
My toshiba tv is stuck on initial setup menu, language selection. original remote is not working
Hi,, today i got the solution for the problem 'Tv Stuck On Language Screen"
I have Skyworth Lcd and it was stuck on Language screen 4 days back, i've tried every sigle App and Different Universal Remotes and buttons on Tv but nothing was working except a single App named "SURE UNIVERSAL REMOTE FOR TV"
i suggest if someone face this Language screen stucking problem and no buttons and remotes are working then you should download this App on your Cell phone and select your tv and you'll surely be able to restore your Tv.
Feb 10, 2013 | Toshiba 40RV525U 40 in. LCD TV
TCL Blue Screen "No Media"
I HAVE FOUND THE ANSWER!!!! I just bought an TCL TV last night and was given the wrong remote. Screen was stuck on "no media" screen BUT I noticed that when I turn the tv on and keep pressing the menu button, the menu screen would pop up for a half second before the no media screen popped up again. So I knew it was able to access it. SO, it took a few try's and with no exact method I turned the tv on, waited til I saw the TCL logo and then simultaneously pressed the menu and channel up button repeatedly. It will open the menu for you and allow you to move between the input channels!!!! It WILL take a few tries to catch it but it worked!!! Your welcome!!!!
Dec 29, 2012 | Televison & Video
Lost remote for emerson lc320em8 32 in. lcd tv, how can i adjust the screen mode to get full screen without the remote?
Hello
It is immpossible to set its screen resolution or screen size, without it remote control. Try to get one original remote control, from the authorised service center for Emerson at your town, or buy a universal remote control, which have setup codes for Emerson TV with it. OK.
Feb 09, 2012 | Emerson LC320EM8 32 in. LCD TV
Remote does not respond to any function, tv is on and cannot change chanel or anything, frozen
you need to check the battery contact with the battery terminal make sure that the terminal is clean.
check open the cover of your remote and check the solder of the battery terminal from the pcb board use a soldering iron resolder it.
using your cellphone camera test the infra red emmision of your remote control aim the camera to the infra red of your remote.you must see at the screen of the camera that the infra red is lit when any button is pressed..if not the infra red is busted.
using your cellphone camera again to test the infra red emmision of your TV. Aim the camera to the infra red of your TV.you must see at the screen of the camera that the infra red is illuminating.if not the infra red sensor of the TV is busted.
Jun 21, 2011 | Universal Remote Control MX-3000 LCD...
1. My printer displayed "USB Device Not
https://www.Abctay.com is an online shop ,
We sell television and electrical accessories,all kinds of TV power supply board, logic board, TV LED screen,
TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc.
Jul 06, 2017 | HP Photosmart Premium C309A All-In-One...
I have problems with my LCD HAIER TV. I put my USB and now i cant return to TV Mode. What i should do?
There should be a button on your remote that says "TV/USB". Try clicking it, that should take you to a blue screen that says No Signal, click Input, and you should be able to access your cable from the list of Input sources. This happened to me today, very annoying and unnecessarily confusing, especially since most buttons you press result in a screen that reads "Not Available." Urrgghhh.
Feb 12, 2010 | Haier HL42E LCD TV
Logitech Harmony 670 remote stuck on Safe Mode. How do I get out?
1. Remove the batteries. While holding the 2 button down, connect the USB cable. The remote will boot into normal mode. Did this fix the problem? If no, please continue to troubleshoot.
ANSWER:
2. Update the firmware. Update the configuration. Did this fix the problem? If no, please continue to troubleshoot.
ANSWER:
3. There could be a stuck button on the remote causing the symptom. Remove the batteries from the remote. Push in, and massage each button ensuring it is not stuck down. Replace the batteries and Update the firmware. Update the configuration. Did this fix the problem? If no, please continue to troubleshoot.
ANSWER:
4. Remove the batteries from the remote. Manually place the remote into `Safe Mode` by holding off and plug in the USB. Upgrade the firmware in the remote. Update the configuration. Did this fix the problem? If no, please e-mail us back for further information about your issue.
ANSWER:
FIRMWARE:
1. Log into the Logitech Harmony Remote Software on your computer
2. Click on the Downloads button at the top-right corner of your screen
3. Click on the Firmware button. Follow the onscreen instructions to upgrade the firmware on your Harmony remote
4. Once the firmware upgrade is complete, click on the Update Remote button
5. Test your remote.
Jan 31, 2010 | Logitech Harmony 670 LCD Remote Control
Olevia 437-S11 stuck in standby mode
My classroom TV seems to be stuck in standby mode. Blue light is on but TV won't turn on either by push button or remote.
Oct 24, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Televison & Video Logo
494 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
