Question about Samsung Televison & Video
How can i turn my samsung ps42a456p2d off standby
When i switch my tv off it is always in standby. is there a way to turn it off completely without switching off at mains
SOURCE: olevia 26" flat screen
screen suddenly shut off. blue light in the right hand corner stays on but there is no picture
Posted on Jan 20, 2009
  • 41 Answers
SOURCE: tv stuck on standby
Power supply probably needs to be replaced if you don't even hear the relay click after the power is switched on.
Posted on Mar 30, 2009
SOURCE: WONT TURN ON
Most likely, the problem is a defective Main Processor Board. This is the board with the antenna, RCA and HDMI plugs. You cant repair or replace component parts on this board, so dont even try. You must replace the complete board. The TV says Sylvania, but it is a bloody Funia TV. Several years ago this foreign company bought out broke-azzz Sylvania . They are still carrying the Sylvania name since Sylvania was a popular TV name in the 70s. Every electronic company in the USA is now owned by the Chinese, so call Funai and order the part from them. Dont be surprise if they dont have a clue what the heck you asking for. America and all electronics have gone to the puddles. Do you know why? GREED.
Posted on Jun 10, 2009
  • 304 Answers
SOURCE: samsung tv model no LE40R74BDXIXEU TV IS USUALLY
First the main bd controls the "Turn on" sequences". When you press the Power on button the Main bd sends a "Turn on" signal to the Power supply. The clicking you hear is the Power on relay ativating. If the tv does not turn on and the relay keeps clicking then you might have a bad Main bd or there is s shorted board somewhere else in the set. The Power supply can also be bad. Have a trained Samsung tech troubleshoot the set.
Posted on Jul 17, 2009
cschindle725
  • 67 Answers
SOURCE: the red light standby is on but the tv will not
Your power supply board needs to be REPAIRED not REPLACED, replacing the board will just make the problem happen again in two years or less, if you can use a screwdriver you can send me the board and I will repair it for less than it would cost you to do it yourself ($50) with the correct components. Email for further instructions! Cory Schindler cschindler24@yahoo.com
Posted on May 30, 2010
Samsung TV not turning ON. My email address is prk Please help... Much appreciated.
Its power supply I will tell you how to fix you need to get few things first
Jan 29, 2016 | Samsung Televison & Video
Tv stuck on standby
The internal power supply may have failed.
Nov 04, 2013 | Televison & Video
Samsung le32r74bd When I turn the tv off by the button the standby light comes on as it is in standby and I can turn it back on again with the remote control. How do I turn it off properly without it...
You need to check the output voltages of the power supply to see which one goes off. It may be due to short circuits some where in the panel board.if otherwise power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem....
Sep 16, 2011 | Samsung Televison & Video
I cannot get a picture on the screen of my tv. I have my tv hooked up to a digital cable box. The "source" for the tv has always been the "HDMI 1". For some reason that i do not...
Hi
Firstly and would remove all the leads from your TV and check them. If after checking your HDMI leads etc... and its still the same then i would reset the TV to the original Samsung settings. This is completed on your remote control by the following........
Turn your tv to standby, on the remote when in standby press the keys on the remote in the following order........ INFO.........MENU..........MUTE.........POWER ON.
You will now notice the picture comes on with the engineers settings in the background. With the direction keys on the remote scroll down to number 12 (RESET) Then press OK or the right direction key, Your tv will switch off and load the Samsung factory settings. Switch the TV back on and go through the setup procedure.Once completed then try your HDMI again.
If it is still failing then there is a strong possibility that your Eeprom IC on your main AV Board is corrupt and needs replacing. This should only be attempted if you have good soldering skills as they are Surface mounted and very small.
My advise if your skills are not that good is just to replace the main AV board (Scart Board) these usually sell for around £50 but WILL solve your problem.
I have gone trough everything i know here that would cure the fault, most times one of the above three will cure this, but im afraid other times its just time for a new AV board.
Hope iv helped some people out here.
Any comments or thumbs up appreciated.
Nov 16, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Screeen
If it's a big tv it can just take a little while to power up, I've found that pushing channel up button switches on tv quicker but I've no idea why.
Unless you want to save power you should only be switching tv to standby, there will still be a light on the tv somewhere, blue or red it varies. TV's turn on much faster from standby than completely off.
Jul 23, 2009 | Samsung HLS4666WX 46" HDTV
I have just bought a new wide screen Samsung TV but I can't work out how to switch it off completely. It always goes into standby mode
Have you tried pressing the standby button, and then the on/off button afterwards? Sometimes they need combinations of buttons, to work. It happened to me. I dont know if it will, but i hope this helps! :-)
Jul 24, 2008 | Samsung Televison & Video
Samsung HCN436w 43in rptv
try disconnecting the convergence board and see if it will turn on without this board connected - if it turns on then you likely needs to fix or replace the convergence board
Jun 19, 2008 | Samsung HCN436W 43" Rear Projection...
Televison & Video Logo
148 people viewed this question
Jerry Greenberg
Jerry Greenberg
