Question about Medical
CHANGING INK IN ECG MACHINE - Medical
How to load paper
How to load paper - Fixya
www.fixya.com > Forum > EKG/ECG Machines
39 mins ago - How to load paper - EKG/ECG Machines question. ... Machines. Open Question ... Aug 30, 2012 ' Schiller Cardiovit At 2 Light Ecg Machine.
Loading paper into the MAC 1200 ecg machine - Fixya
www.fixya.com/.../t4590309-loading_paper_into_mac_1200_ecg_mach...
Apr 19, 2010 - loading paper into the MAC 1200 ecg machine how to load the paperinto the machine? ... Ge Medical Systems Ge Marquette Mac 1200 question.
Contec ECG Monitor & pulse oximeter Ekg printed sheet ...
www.hcuck.com/search/p1207318-contec_ecg.../ekg_printed_sheet
Question about Ge Medical Systems EKG/ECG Machines ... Open the . ... ...ekg-manual The paper is is backwards, there are 4 ways to load paper BUT only 1 ...
Electrocardiograph (EKG / ECG) Questions and Answers
Dec 21, 2015 | Medical
The ekg machine light of filter is flickering and when printing only prints one line out of three appears as if no ink
HI,
Here i added a link which will help you to rectify the problem. Its seems to be the battery of your ECG machine is faulty.
Schiller AT 1 Support
Jun 25, 2012 | Schiller Welch Allyn Cardiovit At 2...
My ECG machine is not functioning because of open signal is alert all the time when i was start up the ECG machine
hi,
You have to check the patient cable of your machine . If any one of it lead is oppen then it will indicate open signal.
ok
Aug 05, 2011 | Life Science Bionet Cardiocare 2000 12...
We have a Marquette Mac 6 ECG machine it will stays on through the start up then the display reads; battery is 0/50 aborting. Do I just need a new battery or is there another problem?
hi,
You have to change the battery of you ecg machine. Because even if the power is connected the ecg machine works on battery. If the battery is low the machine will go OFF after booting.
ok
Apr 21, 2011 | Ge Medical Systems Ge Marquette Mac 1200...
When doing an ECG the low battery signal comes up and the tracing is not completed, despite being turned off and plugged into power for long periods.
hi,
u have to change the battery of ur machine. its a 9.6v battery pack.
before replacing the battery check is it gettigig the correct changing voltage . for checking that remove battery and connect the power and check the voltage at the battery connector on the machine . it should be about 10.5v. if it ok replace the battery
ok
Jan 05, 2011 | Life Science Fukuda Denshi Cardimax Fx7102...
Just ordered a schiller at1 ekg machine, just realized it is 3 channel, does it have a 1 channel mode where just one tracing will print?
hi,
u can make it single channel one by changing its setup. it will print single trace in the same paper. when u select this option it use more paper than the three trace.
ok
Dec 06, 2010 | Schiller Cardiovit At 1 Ecg Machine
Service mode password of bpl cardiart 8408 ecg machine
Hi I want to keep the ECG MACHINE BPL CARDIART IN DEFAULT MODE BUT DONT HAVE PASSWORD. WHAT SHOULD I DO.
Sep 10, 2010 | Ecg Medical
My machine needs the ink changed? how do I do this
There is no ink in that model, it is a thermal printer. You might have the wrong paper or a bad print head or a bad print roller. To test this. Get some thermal paper (You will know it is thermal if you expose it to a heat source and it turns black) and some electrical tape. But a small strip of electrical tape on the print roller. Then do a test sheet. if it prints out darker where you have the electrical tape on the roller it means you need a new roller or possibly a new paper tray cover. You are not getting enough pressure where the two make contact. if you get nothing you need a new print head. We can help with this, 800 989 4909, ask for Jeff
Oct 15, 2009 | Schiller Cardiovit At 1 Ecg Machine
MALFUNCTIONING LEAD ON ECG MACHINE
U may have problem with thorax electrode.
Apr 09, 2009 | Invacare Medical
Medical Logo
49 people viewed this question
Top Medical Experts
Electro Med Services...
Rhonda Webster
Rhonda Webster
Are you a Medical Expert? Answer questions, earn points and help others
