Instructions manual for everglow PTE4 Kerosene Heater
Need manual
tbugger
  • 232 Answers
SOURCE: Transformer for a 70k kerosene heater
try www.reddyparts.com
Posted on Oct 30, 2008
SOURCE: Dyna-Glo RMC95C6 Kerosene Heater
I have uploaded the manual for all to use here.
Posted on Nov 22, 2008
  • 16 Answers
SOURCE: Where can I find an Owner's manual for an Everglow
First you need to get the shell off the unit, and get down to the main burner area. There should be 4 wing nuts holding the wick tower down to the fuel tank. These must be removed, and the wick and the adjuster apparatus removed up and over the top of the center tower. Having a towel or old rag handy to set the unit on when you get it off is a good idea, so you can work on it. Remove the old wick, taking care to see how the fabric band on the cloth wick is positioned on the bottom edge of the wick carrier band. Install the new wick at the same level as the old one on the carrier and set it aside. Make sure you clean the tower, especially all the black carbon buildup around the center and near the top. I use a wire brush on a cordless drill to buff the stuff off, works great. Remove the old kerosene from the tank and clean the tank best you can, then put the new wick inside the carrier, down on the tower, being careful to get the bottom portion of the wick down into the tank area, (it should be quite loose down there once you get the rest of the carrier on the tower. Make sure the whole apparatus sets down evenly and fairly easily on the bottom tank part and screw it down with the four wing nuts. I use a paper cup to pour clear, K1 kerosene onto the new wick all the way around the tower, then make sure it moves easily up and down with the height adjuster knob and while it's in a down position, pour some more kero in on it. You can pour several cups of kero on the new wick and then when it's working up and down well, turn it up and lite it before you put the whole thing all back together. It's best to do this outside as sometimes you can get smoking, if you don't get the flame spreader cage on quickly enough. Once it's on and the flames come up and look good, then turn it off, let it all cool off and you can put it back together. Remember, don't use anything but absolutely clean, clear, K1 Kerosene in the unit and burn it completely dry at least once a week, if you use it a lot. It's called dry burning, and it's a wick cleaning function. If you do this, the wick can last years and years.
Posted on Apr 04, 2010
  • 30 Answers
SOURCE: Changing Wick in Kerosene Heater
http://www.ghpgroupinc.com/heaters/manuals.aspx
Here is the complany website..parent group name is GHP group..crazy they don't link DynaGlow more easily in a web search
Posted on Nov 06, 2010
  • 582 Answers
SOURCE: I am trying to change
http://www.sengokula.com/manuel.htm.
GO TO THIS LINK AND FIND THE ONE THAT IS USED FOR YOUR HEATER AND DOWN LOAD
Posted on Feb 05, 2011
Air force heater instructions
http://www.phpdistribution.com/
Up at the top is a manuals button. It will tell ya all ya need to know.1x5b
Aug 17, 2014 | Reddy HEATER R115 115,000-BTU PORTABLE...
Manual for kerosene heater hmn 110
goggle internet search thought I saw one on there
Dec 12, 2013 | Sengoku LA TLD Heatmate Radiant Kerosene...
I just bought a spc k125 and was wondering if i can burn diesel fuelin it or just kerosene
I looked in the manual-- and under operating instructions it says:
Use only Kerosene or #1 fuel oil. Never use gasoline,
naphtha, paint thinner, alcohol or other fuels of any kind.
What would you say Diesel fuel is?
Mack B
Jan 15, 2011 | All-Pro Forced Air Kerosene Space Heater...
Need to know how to replace the wick
The first thing you need to determine is the correct model number of your heater. Once you've done that, go to the GHP Group Inc, website listing the heater manuals and locate the appropriate manual for your heater model and click on the link for your heater.
After you've selected the appropriate manual, you can either download it to your computer or print it out. Inside the manual you'll find the instructions on how to replace the wick. The kerosene heater manual I reviewed listed an incorrect phone number to call to order a replacement wick. I suggest you use the new GHP Group's number to order your replacement wick: (877) 447-4768.
If you have a different Dyna-Glo heater than a kerosene one, you should still be able to locate the appropriate manual on the GHP Group's heater website.
Hopefully, you'll have your heater up and working again in no time.
Jan 12, 2011 | Dyna-Glo (PPH16-LP) Utility Heater
Replacing the wick for an Everglow PT-E16 kerosene heater
@gggg698
That was close enough to get the job done, thanks, but not exactly correct for this model.
Nov 10, 2010 | Heating & Cooling
Heating & Cooling Logo
217 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
