Question about Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint WM51 Washing Machine keeps tripping the electric
Any ideas what the fault might be? I plugged the machine in and before I opened the door it tripped again.
  • shell17 Feb 08, 2009
    Problem solved, it was one of the springs in the top of the machine that holds the drum in place, it has snapped and was earthing.
  • Kris Seymour May 11, 2010
    Could you give some more information? Had you used it? Or just about to use it? ETC more info would be good as i can tell you what you need to do......
I had this problem; it was the motor arthing out on the body. It took a repair man half an hour to sort and it cost me £35. Hope this helps. Domo.
Posted on Feb 08, 2009
2 Suggested Answers
  • 135 Answers
SOURCE: Hotpoint WM51 Washing Machine keeps tripping the electric
Ok that rules out the heating element. There are a number of possible causes so bear with me while i go through them.
Can you open the door? If so leave it open then turn on the machine. Does it trip?
Posted on Jan 23, 2009
Washing machine keeps tripping electric when the door locks
Washing machine tripping or fusing electrics
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jun 26, 2013 - A Washing machine tripping or fusing electrics is a fault you can't really deal with unless ... If washer has tripped the RCD or fused the plug but now won't work properly. ... Here's an article on Washing Machine Door Will Not Open ... If youkeep resetting it without fixing the cause of the tripping it can blow ...
6 common washing machine problems and how to solve them
www.appliancesonlineblog.com.au/.../6-common-washing-machine-prob...
Feb 10, 2014 - As mentioned earlier, front loader doors lock during the cycle to prevent the water from ... The washing machine keeps tripping the power!
Maytag ,Whirlpool Washer Diagnostic - Breaker tripped and ...
? 7:00
https://www.youtube.com/watch?v=dx2vCzO8828
Jun 13, 2013 - Uploaded by ApplianceVideo.com
Yeah, keep it ... Maytag ,Whirlpool Washer Diagnostic - Breaker tripped and will not always run - .... TROUBLESHOOTING Top Loading Washing Machines in ... Maytag Neptune Door Locked but No Spin - R11 is not burnt ...
Washing Machine keeps tripping the electrics -
Dec 29, 2015 | Washing Machines
Wmf540 hotpoint washing machine
This video will show you how to open your Wmf540 hotpoint washing machine door that is stuck shut
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 08, 2013 | Hotpoint Washing Machines
Hotpoint WMA33 washer- The machine was in a final spin after a 95 degree wash when the power to the house was tripped by the washing machine, since then the machine will not start, all the lights come on...
Possible the surge would have made some changes in the main processor memory or damaged the processor. You can shut down the washer and remove the plug for few hours. press down all the panel buttons to drain all residual voltage on the board.
If the same fault repeats then it is possible there are errors on the board.
Jul 25, 2012 | Hotpoint Washing Machines
I have a Hotpoint washing machine model wm51 and the machine fills with water but stops and will not go into a wash cycle
could be heater fault listen to it if it works it should sound like a kettle warming
up it takes a while
Mar 02, 2010 | Washing Machines
Hotpoint 9537 washing machine tripping electric
You have a problem with Live feed shorting to earth on a main component. You need to switch off machine and seek a qualified electrician ASAP
Sep 03, 2009 | Washing Machines
Jan 23, 2009 | Hotpoint First Edition FEW12 Front Load...
Hotpoint Aquarius WD64 - Tripping the electric?!
something is going down to earth, start by unplugging the motor and retesting, if it doesn't trip them check the motor carbons etc, if it trips then check the heater element for contact down to earth, replace if needed etc, then check the outlet pump the same way if i have helped rate me please ps when working on machine remove from power supply
Oct 03, 2007 | Hotpoint Aquarius WD63 Front Load...
Kenmore elite front loader washing machine
has the fuse blown, if so replace this to ge the machine up and working to start with, set to drain only if you have the option, if the machine empties then the door may open, if its set to spin and the electric trips then there is a motor fault,, not much information given but now you have somewhere to start from
Sep 23, 2007 | Hotpoint WD52 Front Load Washer / Dryer
Hotpoint Aquarius WMA42 Front Load Washer Logo
382 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
