Dell Latitude C610 PC Notebook
Problem for Dell Latitude C610 PC Notebook
Dell Latitude c610 wont turn on
By laurieann_7 on Jul 11, 2007
I have a latitude, The last time I was using it, it shut off automatically. When I tried to turn it back on, all the of the lights (the capslock, numlock, power, battery Exc.) come on but the computer shut back off. I called Dell to see if they could tell me over the phone what it was, but they were no help. Any suggestions would be greatly appreciated. Thank you
Best Solution
posted on Aug 12, 2007
Very Helpful)
femster
Rank: Guru
Rating: 85%, 71 votes
the moniter is not connected to the laptop base
if u open the bottom you will find i couple of wire going 2 a rectange white thing plug that into the white base
Was this helpful?
Yes
No
Solution #2
posted on Jul 11, 2007
Somewhat Helpful)
CompuGuy44
Rank: Wiz
Rating: 82%, 965 votes
It could be one of two things, Memory or system board. Try and switch the memory chips around. If you have one memory chip, try the other slot. If you have two chips, try just one chip. If you don't have any luck with that, replace the memory chip. If no luck with that, you'll need a new system board. EBAY would be your best bet to get one.
Was this helpful?
Yes
No
Solution #3
Not Helpful)
CanDo
Rank: Wiz
Rating: 82%, 181 votes
Pull the hard drive out and use an adaptor and hook up your hard drive to a desk top computer . Run a virus scan on it with the latest protection. run spyware and adware scan too. Defrag it and check it for errors. After that put it back into your laptop and reboot.
Still doesn't work which out the memory and check to see if the processor cooling fan is working. If you hard drive doesn't work when you hook it up to desktop you know it is bad.
Make sure you hookit up right. You can get an adaptor on Ebay for a couple of bucks plus shipping.
Was this helpful?
Yes
No
Solution #4
posted on Aug 11, 2007
Not Helpful)
ebenezer
Rank: Master
Rating: 82%, 31 votes
hello
try removing the battery keep the ac adapter on and power again.
if it does not come on then you have a power problem.
try swapping the memory or replacing it.
another issuecould be temperature related.
if the system fan or the cpu fan is defective it can have an adverse effect onthe system board.
since your system shutdown by itself, your CPU could have been damaged or relatively your system board.
Was this helpful?
Yes
No
Popular Solutions for Dell Latitude C610 PC Notebook
Questions and Unsolved Problems for Dell Latitude C610 PC Notebook
Do you recommend Dell Latitude C610 PC Notebook?
Answer
Answer
Hello, I bought an AA1 D250-1585 netbook. When we try to start the Restore process is initiating but... (More)
Answer
no green lights will light up on the card itself
Answer
I have latitude dell c610, when I power it on it tell me it can see the hard drive and that the cd... (More)
Answer
When I attempt to boot up my Compaq laptop it says or to resume. But when I hit either of these keys... (More)
Answer
latitude c 610, cooler not start
Describe your PC Laptops problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptop Experts
Top Computer & Laptop Repairmen
in Augusta, ME
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
