Question about Car Audio & Video
I need a manual for a valor heater model 395 - Car Audio & Video
Valor nevada deluxe 2 gas wall heater instructions
We have two Valor Nevada2 Deluxe outside wall mounted natural gas fire heaters ( with flues ). After years of use, they require being replaced. We want similar. Please recommend the best type.
Thank you."
Jan 06, 2012 | Heating & Cooling
Valor Dream Mk2 gas fire. Can anyone tell me where I can find the instructions for arranging the layout of the fake coals.
Here's a link to Valor. Click on the Downloads tab, find your model number and you can download the Owners Manual and print it. Or contact Customer Service.
http://www.valorfireplaces.com/?gclid=CIeSzM736acCFSM95QodUx0raA
Hope this helps you. Please be kind enough to take a moment and rate my response to you.
Thanks and have a good day.
Mar 25, 2011 | Heating & Cooling
The flame effect on my valor 846 electric fire is not coming on, i think it is an led that is not lighting up. how do you change the led and where can i get one. thanks Gerald
The LED is on a circuit board located inside the fire. The board itself needs to be replaced.
The part would be available from valor spares under your warranty.
The number for valor spares can be found at Valor fires
Dec 26, 2010 | Stoves Heating & Cooling
Bought valor homeflame super off a friend gas fitter won't fit until he gets istruction maual
google valor you should be able to get manual off there site you will need model number
May 02, 2010 | Heating & Cooling
Rebot continuos
It is possible that the CPU fan is spinning too slow which allows the CPU to over heat and restarts you're system. (A safety feature for all MB's). Or the CPU fan has built up too much dust. Try cleaning the CPU fan with canned air and a clean paint brush. Try to free the dust from the under side of the fan blades with the paint brush. You can also add a case fan or two. This will supply more fresh air and help keep the MB and CPU cooler. If you're MB is five years old or older it is a good idea to replace the thermal past between the heatsink assembly and the CPU. If you decide to replace the thermal past spend a little more and replace the heat sink assembly too. Socket 423 replacement; http://www.directron.com/cck7015.html#caption
Mike
Apr 19, 2010 | MSI MS-6339 Motherboard
Valor blenheim gas fire correct coal settings
Hi go to www,valor.co.uk you and request manuals on line with the coal seting in
Mar 08, 2010 | Goodman GMS90703BXA Heater
Instalation manual for valor flamenco unigas 111 balanced flue wall mount gas fire
hi there, did you mange to find a copy of the instructions for the valor flamenco unigas ii at all?? i need to replace the ignitor so would like to see a copy..
cheers
sharron
Mar 08, 2009 | Heating & Cooling
Car Audio & Video Logo
15 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
