Question about Microwave Ovens
What are the dimensions of the GE JVM290 microwave?
What are the dimenisons for the GE microwave JVM163WB004?
Jaquetta, best that I can find from GE's website is the following
Width: 29 7/8"
Depth: 15 1/16"
Height: 16 15/32"
Hope this helps!
Jul 18, 2014 | GE Microwave Ovens
Jvm230wl I want to replace my over the range GE JVM230WL model but I'm not sure the exact dimensions. It appears to be a snug fit in the bracket so the measurements need to be manufacture specific. Also,...
GE Customer Service is here. They may be able to tell you if there is a "drop-in" replacement available for your model.
Otherwise, you'll have to take down the old bracket then mount another model in the space.
Jan 15, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
I need the dimensions of the GE Spacemaker XL Model JVM1653WH01
For dimensions look at the GE Appliance web site at: http://www.geappliances.com/ then search for JVM1653WH01
This will take you to the product information page for the JVM1653WH 1.6 Cubic Foot Over the Range Microwave Oven with weights and dimensions, installation instructions etc.
Oct 24, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Do you know the dimensions of the GE jvm230 over-the-range microwave oven?
Just measured mine as I'm looking to replace it.
30 inches Wide
15 inches high (front)
16.5 inches high (rear)
13.5 inches deep
Nov 18, 2010 | GE JE1540 Microwave Oven
New Microwave
Well one would presume you could simply measure the bracket and the microwave, and ask a retailer for the dimensions of units with similar dimensions.
They may also have this bracket and be able to compare the sizes before purchasing your new one.
Not knowing the dimensions of either the bracket itself or the microwave, this would be the only solution i can think of.
Jan 22, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
JVM290
The interlock switch is badly adjusted or worn.
Remove the case and adjust the switch.
Nov 04, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
85 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
