Question about Bosch AquaStar 2400ES-NG
Unit overheated due to fan malfunction.
The ventilation fan started making a huge amount of noise.  I unplugged fan to see if unit would work without fan. It overheated and shut off.  Is there a restart button?  The pilot light works but the gas will not come on.
Also, is there an easy way to fix the motor/fan component without buying the entire replacement ventilation unit?
  • 50 Answers
Again EA or EC error codes? To unplug the fan you really have small hands. Fan is a unit not just motor, explosion proof and costs over $330.
If that was a popping or staccato noise it wasn't the fan but the gas valve. Sounds like water penetration which condemns the gas valve a $237 part which FYI DIY you can't replace unless you're a Tech.
What's with your warranty?
The pilot in an electronic Bosch doesn't exist, it's lite by a spark . igniter.
This is a Gas Appliance which requires a RSA to service.
If water penetration then change your termination box to drop dead by Z-Vent. We change dozens of these (GV's) a year due to this crappy box. These units work best when Direct Vented.
Posted on Mar 03, 2009
Lound vibration when running
Check gas control valve.
Good luck,
Marty
Feb 18, 2013 | Rinnai Water Heaters
I have a Bradford White water heater (model# MITW50L6LN10) that started making noise yesterday. Tonight when the family got home we started a bath for the kids and surprise surprise no hot water left in...
Probably cheaper to fix existing water heater.
The problem might be the power vent, or the power vent might be short cycling because the gas control valve is bad, or vacuum switch has gone bad.
Call Bradford White and get their recommendation for your specific model.
http://www.bradfordwhite.com/contact.asp
http://www.bradfordwhite.com/supportserv.asp
http://www.bradfordwhite.com/findaserial.asp
Bradford White is very good brand of water heater
Rheem, Richmond, GE are good.
I prefer the AO Smith, American, State, Reliance, Craftmaster. Kenmore, Whirlpool brand since air intake screen is located on bottom of unit and can be inspected and cleaned without removing burner.
Feb 09, 2013 | Water Heaters
Fan makes noise
check to make sure fan blade is tight on motor shaft.KILL POWER TO UNIT FIRST
Sep 10, 2012 | Water Heaters
Had three 50-gal American Standard water heaters installed Dec. 2009 Two upstairs in attic, one downstairs at ground level. Attic location used because heaters being replaced were up there. Upstairs...
Plumber is right.
Problem is not amount of air in attic. Problem is how hot the air is.
Oxygen molecules separate apart in very hot air and pilot light goes out since there is not enough oxygen density to support combustion.
http://waterheatertimer.org/images/Water-heater-in-attic-800.jpg
http://waterheatertimer.org/pdf/Attic-Ventilation-and-Pilot-Outage-in-Gas%20Water-Heaters.pdf
More ventilation is needed.
Plumber is not ventilating expert, and not responsible for attic ventilation that builder failed to install. Plumber should do a survey of location before installation to make sure gasoline vapors are not stored nearby, but summer attic ventilation is gray area until more general-public folks become aware of problem. Hotter summers temperatures will spread that information.
Hire local home center to install roof vents AND soffit vents.
Note: You also need soffit vents.
Remember a vent on the roof is like sucking air out of a coke bottle. The roof vent is no good unless air can also enter the attic from another vent located in the soffit.
Another solution is electric water heater for very hot locations.
Or install solar-assisted water heater.
http://www.hotwater.com/products/residential/cirrex_solar.html
Jul 28, 2011 | American Standard 40 G Natural Gas Water...
Water heater cod e 9 c 1 no hot water david 775 626 2111
E9 is overheat sensor, and C1 is fan rotation too slow.
It sounds like the unit is shutting down to prevent overheating because fan is not working, but there could be additional causes including PC board failure, or electrical problem.
Before calling service technician, open following links for Bosch troubleshooting resources:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
http://waterheatertimer.org/pdf/Bosch-C1-C6-C7_error_code_troubleshooting.pdf
Apr 14, 2011 | Bosch Water Heaters
I have a Rinnai model R53-i-1. When hot is called for, heater turns on and produces a low to loud vibrating noise. It seems to change with water flow use at tap. I called Rinnai, got the name of local guy,...
A low to loud vibrating noise is an indication of an Air /Fuel imbalance . When you flow more water , does the noise become louder ? if so , have a service technician check for pproper incoming gas supply . The requirements are located on the left hand side of the Rinnai unit . There will be a minimum/maximum specification.
Another issue could be the burners being "dirty" and needing to be cleaned .
Also investigate the venting and make sure all joints are sealed properly and the venting is sloped correctly . If you have your installation manual , please refer to the venting section in regards to usage of a condensate collector . This can be a cause of noise .
There is a clear vinyl hose running from the bottom of the heat exchanger to the front of the gas valve . Please inspect this hose for any moisture or signs of staining . This can lead to issues with the gas valve . It must be determined where the moisture is coming from (See previous comment about Condensate collector !) .
The cold water solenoid valve usually has nothing to do with this type of noise .
As far as yourself being able to repair the unit ? I have no idea of your experience but a qualified licensed service technician should be used as this is a gas fired appliance and as such is subject to huge liabilities when being repaired .
Have them call Rinnai Tech Support while on site for any assistance needed.
You shouldn't have to "put upo " with any noise issues . The Rinnai ujnits run at 49 decibals (about the same level as a conversation .
Good Luck !
Jan 30, 2011 | Rinnai Water Heaters
My Noritz 6.9 flashes a 90 code. I was told by Noritz that this code relates to air flow.. and that the unit needs to be cleaned/serviced. Is this something I can do myself? If so, how do I do it? If...
I recently started getting an error 90 on my N69-M unit. I finally got a hold of someone at Noritz tech support and they state this error is a general combustion/exhaust/air flow error. Here is what they suggested to look at.
Gas Pressure – The unit has a minimum flow rate for the incoming gas and if the system is gas starved, then you have some sort of obstruction or restriction. If this is a new install and you are getting an error 90, this is likely your problem but if this is an existing install that suddenly started getting this error, unless someone was monkeying around with any values you might have in-line, this probably isn’t your problem.
Air Flow – This is a ventilation issues caused by the build-up of dust, lint, etc that chokes the flow of cool air to the unit and causes the burner to overheat. If your unit runs for a while and then pops an error 90, this is probably your problem. They told me they get a lot of these errors when the unit is installed in close proximity to a clothes dryer, which makes sense. To resolve this, remove the front panel and blow out the intake holes and slots (I tried to shop-vac mine before blowing them out and I was amazed at how much the vacuum didn’t remove). After removing the cover, the first thing you should see is a system board that is covered by a black dust shield. The board is held to the unit by 3 screws (one on the top left and two at the bottom). Remove the screws and let the board dangle by the wires plugged in it. You should now be staring at the fan assembly. They suggested that I either remove the whole unit and clean it out or use compressed air to blow it out. I went with the compressed air route because getting the fan assembly out requires removing and eventually reinstalling 2 relatively small screws way in the back of the unit that you have no real easy way to get to. Blow/clean the fan out and then blow out everything else inside the unit. Reassemble and you are good to go, provided this is your problem.
Exhaust – You might see an error 90 if the exhaust can’t freely flow. Two things can cause an exhaust issue to throw this error. One is that the flapper valve on the outlet of the system sometimes gets stuck closed. This should be easy enough to fix. The other is an obstruction in your exhaust ducting or using too small of a diameter duct to exhaust the unit.
Hope this was somewhat helpful and prevents you from having to wait on hold forever for Noritz support or having to pay someone to fix your problem.
Nov 14, 2009 | Noritz 6.9 Gallon Residential Direct Vent...
I have the same issue - random hot water
You have a bad igniter, and the sensing switch is shutting the fan off because the igniter is not functioning properly.
The average cost is about $150 for the part.
Aug 12, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Baxi 80 overheating on hot water circuit
thermostat on the gas valve needs to be replaced,, which you will probly have to change the hole gas vale ,, check on the parts and labor and if it is over 6 years old wheigh the diffrence between it and a new unit good luck
Jun 10, 2009 | Water Heaters
Rheem 40 gal power vent gas water heater shows code 42
you plugged it in and the fan started or you unplugged it and the fan started,,the fan will come on first before the unit will inginte to take out the excess gas, if it didn't lite then the ignitor might not be working there are 2 swithces on the unit one on the fan and one by the gas valve make sure they are both on and make sure the gas it also turned on.
May 30, 2009 | Water Heaters
Bosch AquaStar 2400ES-NG  Logo
205 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
john h
Paul Nielson
Paul Nielson
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
