Question about Kenmore Elite Stainless Steel 24" BuiltIn Dishwasher with TurboZone Rotating Spray Jets 13103
Kenmore elite dishwasher "check float" message
jsrock516
  • 5911 Answers
SOURCE: Kenmore Elite Dishwasher Problem
The dishwasher should have a thermal fuse mounted to the control board behind the operator console4.gif. It is a small silver colored device4.gif attached to a white plactic bracket. In some model dishwashers the wrong gage wiring was used causing the wires to heat up and trip the thermal fuse. There was no apparent risk of fire or anything like that, but the thermal fuses didn't tolerate the heat differential too well. A fix for the problem was to purchase a thermal fuse replacement kit (found at most appliance repair stores) that had thicker wires. The part number for the thermal fuse kit is 959376 and the price is $16.85. You can find it at repairclinic.com. Order on line and have the part shipped directly to you. Now...to access the control board perform the following:
1. Turn off the main breaker to the dishwasher. This is important. Even though the dishwasher is not running, the control board still has live voltages present.
2. Open dishwasher door and remove the top screws that hold the console in place. You shouldn't have to remove the lower screws unless you plan on removing the entire door panel.
3. The control panel should pull off from the front enough to where you can access the control board. There is a thermal fuse mounted on the board with two wire leads going to it. The fuse is silver in color and mounted to a plastic bracket which is mounted to the control board.
4. Cut the wires on the old fuse and splice the new fuse kit to it. Leave plenty of wire to accommodate. There will be instructions included with your replacement kit. Ensure you follow the direction thoroughly and tighten the wire lug screws securely.
NOTE: Do not attempt to reuse the existing wires by simply unplugging the old fuse and replacing it with the new one (been there). The fuse will eventually blow again. Follow the instructions provided and you can't go wrong.
If you have any further quesitons, or if you run into trouble during your repairs, let me know. Good luck to you.
PS If you do not wish to order on line, take the part number I provided you to any major appliance repair shop4.gif and they SHOULD have the part available. This is a known problem and a common fail item.
Posted on Dec 15, 2007
SOURCE: kenmore elite dishwasher stopped in middle of cycle
My Smeg (never buying brand again) dishwasher UKSTX1 has error message e9 not covered in manual
Posted on Jan 26, 2009
  • 188 Answers
SOURCE: kENMORE ELITE DISHWATER panel went blank but there
Check the continuity of the thermal fuse. It's clipped onto the electronic control inside the console.
Let me know if you need more help.
Posted on Mar 12, 2009
  • 10865 Answers
SOURCE: kenmore elite dishwasher does not dry
one of the buttons on the door will give u heat, just push that button
Posted on Apr 19, 2009
erpaalai
  • 999 Answers
SOURCE: leaking Kenmore Elite at the right front of dishwasher
Sorry to hear of your plight. My advice is to ask for a new machine under the lemon law since they cannot get it fixed. You can also try calling Whirlpool who is the manufacturer but they are likely to tell you to work with Sears. They were out under warranty and it has not remained fixed so the warranty should carry through since you called for service while still in warranty. I feel for the tech because it is frustrating to have a problem that you cannot find a cure for be the tech should also have escalated it to the tech support line for resolution. (I was a Sears tech for 21 years)
Posted on Sep 15, 2009
Dishwasher not getting enough water
I'm not familiar with your model of dishwasher but there are some things you can check.
Check for buildup on the float and make sure it moves up and down freely. Look for things that can obstruct your pump, like hair. Make sure your outlet hose is not plugged up. Make sure your inlet hose isn't clogged with sand and grit.
Most likely your float isn't working right. Good luck
Mar 12, 2014 | Kenmore Elite Stainless Steel 24" BuiltIn...
Kenmore elite dishwasher stops in mid cycle green clean light flashes 8 times pauses and then flashes one more time
Float Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle. see the diagram
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace timer/electronic control.
May 23, 2013 | Kenmore Dishwashers
Float in dishwasher not recognizing water level
Hi. The float sensor is just a fail safe device to prevent the DW from overflowing. I would first check the incoming water pressure and also check the input water valve to make sure that the screen is not clogged. Try running it without the water pre-heat feature also. BTW, it should be connected to the Hot water line.Temp. sensors will cause erratic problems in this case. Hope this helps.
Sep 29, 2017 | Kenmore 24 in. Elite Built-In Dishwasher...
I have a kenmore elite model# 665.16263402 and it just wont work i have tried changing the soliniode but nothing. it acts like it will start but then only run for 3-5secs and shut off
try checking your float switch, the first thing any dishwasher tries to do is pump out whatever water may be in the tub,
if it is shutting off your looking for why
make sure the float switch is not hung up look by the water soloniod to make sure it is sitting on the switch correctly
Oct 22, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
Leaking Kenmore Elite at the right front of dishwasher
Sep 14, 2009 | Kenmore 15129 Built-in Dishwasher
Kenmore elite giant tub white will not fill with water
found out that the problem was the float was stuck. Onceloosened the dishwasher worked fine. thanks Greg
Mar 18, 2009 | Kenmore 15912 Built-in Dishwasher
KENMORE ELITE DISHWATER panel went blank but there
Mar 12, 2009 | Kenmore Dishwashers
Kenmore Elite Dishwasher - leaks from Overfill Protection Float
I had the same problem, but mine leaked every time. I have a kenmore ultra wash dishwasher no. 665.15762. I took the bottom rotating sprayer off and found that the plastic piece under the sprayer had a few loose screws and the rubber gasket, under that piece, had blown out at the corner facing the overfill protection float. I took out all the screws and re-mounted the gasket in place and put all the screws back and tightened them. It solved the problem. I hope that this helps others.
Nov 11, 2008 | Asko 24 in. D3250 Built-in Dishwasher
Kenmore Elite Stainless Steel 24" BuiltIn Dishwasher with TurboZone Rotating Spray Jets 13103 Logo
275 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
