Lg washing machine f1403fd leaking
Leaking water from under neath
gwshaw71
  • 83 Answers
SOURCE: Water leaking under washing machine
check your water pump , and tub seal.
Posted on Dec 07, 2007
SOURCE: LG WM1814CW - Water/soap Leaking Under Washing Machine onto Floor
Here is the answer !!! My LG front loader has leaked once a year for the past 4 years. The rubber bellows (a part underneath the washer) cracks and causes the leak. DO NOT LET THEM TELL YOU THAT YOU ARE USING TOO MUCH DETERGENT ... THAT JUST AN EXCUSE !!! The part costs around $12. Here's the link ...
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx?R=1514&searchText=LG%20Washer
Posted on Oct 06, 2008
  • 5 Answers
SOURCE: speed queen
I'm sure you have already bought a new washer BUT......
The repair isn't as hard as you are lead to believe.
First I would check for leakage from the pump.
This is the Most common reason for water under the machine
The pump is a fairly straight forward repair that is a little different on each model of washer, but is usually easy to figure out.
If it is the seal/bearing then that is a more involved repair but not impossible for the average person who is mechanically inclined.
The front panel must come off, the the top panel, which is held by two screws in the corner. Lift the top back and disconnect the tub inlet hose. Push it out of the way. I wedge it into the top groove.
Pop off the water level switch hose on the back of the tub.
The tub module needs to come out. It is held upright by several springs. The number varies with the year.
A ready made spring hook can be found by removing and using one of the front springs. I use the one in the front to the left. It's the easiest. It's easier to catch the springs if you hold your hook facing up.
Disconnect the motor harness, leaving the capacitor attached to the harness. Pull it through the frame and out of the way.
Dis-connect the drain hose. there will be water in it so be prepared with towels. Place an old towel on the floor. Now lift the tub module up and out, setting it on the towel. This will keep grease. etc off the floor.
The tub top clips on. Gently pull the tabs out and lift two at a time, just until you break the seal, no more, till you have all of them loose.Remove and put aside. Take out the 4 tub bolts. Don't worry if you break them, the new kit comes with new bolts. The tub is usually stuck to the hub. Put a foot inside the tub and stomp down on one side. It will pop loose. Put tub aside after cleaning old gasket from bottom.
SPECIAL TOOL; you with need a 1 1/2" socket of shrt handled wrench to remove the large nut.
Once it is off there is a nylon lock unit in the grooves with the threads that looks like a crown, cut a slice in it and pull it off. There is a new one supplied.
Remove the hub. Sometimes a puller is needed, don't damage the shaft or threads.
Turn module over.
Remove the 6 bolts around the outside of the tub, the motor bolts on some models and the two holding the counter-balance to the tub.
Lift off the transmission assembly as a unit.
The seal kit has the instructions for your particular model.
If the bearing is a separate 3-bolt unit, replace it as well.
Never leave a bearing that has gotten wet from a leaking seal, or you WILL end up doing the job again in a few months because of a $15 bearing that should have been replaced the first time.
Re-assemble the washer in reverse order.
Spray WD-40, or other lube, on the cork gasket between the tub and hub before installing tub.
Don't forget the nylon lock unit.
If the pump looks like it has been leaking At All, Replace it Now.
When installing the springs, do the back ones first. Hold the hook facing down this time. Install the one you used for a tool last and in the front left side.
Let the washer set for an hour before use, or as directed in the seal instructions. The first cycle should be hot water, without a load .
Posted on Apr 27, 2009
  • 9 Answers
SOURCE: Leak from under the washer
tub seal has gone bad, will only get worse. Expensive fix,
Posted on Jul 02, 2009
mgprice
  • 744 Answers
SOURCE: greasy oil and water is leaking from under the washing machine?
Hello, the good news is the water is coming from the pump and is easily replaced, the bad news is if you are seeing a yellow oily substance your transmission has a leak and will go bad at some stage soon. The question here you need to ask yourself is do you want to spend $35 on a new pump when your going to need to buy a new washer? If so pull the machine out and puch it back so it leans against the wall umder it's own weight. wedge some thing underneath the washer so you can access the bottom without the washer falling on you. you will see the pump attached to the motor which is attached to the transmission. remove the 2 clips and 2 pipes from the pump, remove the pump and replace it, reassemble in reverse order, you should be able to see where the leak came from the pump at the point where the motor shaft connected to the pump. Also while you are under there look at the base of the transmission, you should see some oily residue where the transmission fluid is leaking. Hope this helps! if you have any other questions please feel free to comment again. Good Luck!! Mike
Posted on Jul 21, 2009
LG WM1355HW Washer will not start. No power at all. I've check all the power sources coming to the washer and there is power to it.
try this service manual:
http://www.manualslib.com/manual/687992/Lg-F1403fd-5.html?page=20#manual
Sep 07, 2016 | LG Washing Machines
Whirlpool wtw7300xw2 washer leaking from bottom
check for cracked pump hose/ loose hose, leaking pump, small tube up to water level control
if the water is grey or whitish then it could have water in the gear box from a failed shaft seal
Apr 03, 2016 | Whirlpool Washing Machines
Water under neath the machine, pump was wet, dried with a towel a ran a load. Ran well did not leak this time. Should I get it checked out?
probably not the pump but a crack in the convoluted hose from the tub to the pump, that opens up under certain tub operations
May 19, 2015 | Fisher and Paykel Washing Machines
It leaks
where does it leak from,could be drain hose, or pump or connections to and from drain hose and from pump,, look for rusted clamps under neath,,,or holes, also chek waterhose connections,when loking underneath chek for water spots on hoses and pump..
Oct 10, 2012 | Kenmore Elite Oasis 27052 Top Load Washer
Lg di dvr 9kg does not spin.ser no f1403fd[oe comes up in window,to stop program]what should i do.
Hi cheyrlsouthw,
OE error is Outlet Error. You will need to clean the Pump Filter, as it is most likely clogged by a foreign object. Check your Manual for instructions on how to do this.
Kind Regards
If you found this solution helpful, please rate accordingly :-)
May 18, 2011 | LG Washing Machines
I have just acquired a LG Incello Washing maching (7kg) WD80130C and I haven't been given a manual. Can you please send me one?
GO TO WWW.LG.COM/AU. CLICK PRODUCT SUPPORT LEFT HAND SIDE OF SCREEN.TYPE IN MODEL NUMBER WD-80130C . UNDER NEATH SEARCH BOX IN RED SHOULD COME UP WD-80130C WASHING MACHINE CLICK ON THIS. HALF WAY DOWN PAGE DOWN LOAD PDF FILE ENGLISH .
Feb 22, 2011 | LG Washing Machines
Washing machine pouring water out on final spin
The rubber pipe under the machine is usually parished......
Feb 28, 2009 | Maytag Neptune MAH5500B Front Load Washer
Lg washing machine 1289 fhd
The operating pressure is 4.5 - 116 psi.
Where is the leak?
Feb 08, 2008 | LG WD-1280FHD Front Load Washer
Washing Machines Logo
77 people viewed this question
Top Washing Machines Experts
