Question about Apex Digital GB55HD09W 55" Rear Projection Television
Green picture apex digital gb55hd09 55-inch
The picture is showing but mostly green
4 Suggested Answers
  • 11 Answers
SOURCE: Apex dt250 digital convertor-- light stays red and
If you're electronics savy, as in replacing capacitors, open it up.. that's your problem.. one or two of the caps on the power board has gone bad.. most likely a 470uf 25v, which can be replaced with a 470uf 35v found at Radio shack for about $1.29. You can tell if it's bad if the top is cracked open & leaking or just domed out instead of being flat.
Posted on Aug 10, 2010
techman007
  • 1112 Answers
SOURCE: flat screen 40" apex digital
Hi:
Check the power supply for faulty capacitors, there are usually two or three of them that go bad. You can tell the bad ones because they become puffy on their tops. The most common value of capacitors used for the inverter board to light the back lights are 3300uf rated at 35 volts. Replace with same value and voltage ratings.
Posted on Mar 04, 2011
SD Tech
  • 14553 Answers
SOURCE: No picture or sound just blue pwr light on apex 40 inch LCD what's going on?
first place to begin is if able test voltages in and out of the power board inside the set---if not able to do that consider having a shop look at it.
If you get it open:
Posted on Aug 27, 2012
SOUND ISSUES
pl put ur cable in audio jack simbol is green n white
May 26, 2014 | Apex Digital APEX LD3288
Is my apex tv AT2702 high def??
According to apex its not and does not have a digital tuner the only way this can be high def would be 720P meaning 720 lines progressive scan.
Your aspec Ratio is 4:3 this indeed is a standard TV without a digital tuner so you will need a digital setop box or a digital tuner.
High DEF is not considered digital its conidered how many lines are displayed on the TV. For example 720p, 1080p .
  • Silver, 27-inch monaural television; 29.6 x 23.2 x 18.7 inches (W x H x D)
  • Front-panel audio/video input accommodates a camcorder, VCR, or gaming console
  • 3 rear AV inputs (including 1 S-video input), 1 RF antenna input
  • Channel scan, channel recall, closed-caption display
  • Offers V-Chip parental control, sleep timer, auto-off, and a full-function remote control
Technical Details
  • Brand Name: Apex
  • Model: AT2702
  • Display Technology: CRT
  • Display Size: 27 inches
  • Image Aspect Ratio: 4:3
  • Speakers Included: 2 speakers
  • Height: 18.7 inches
  • Width: 29.5 inches
  • Depth: 23.2 inches
  • Weight: 88.2 pounds
Jan 27, 2011 | Apex Digital AT2702 27" TV
My 40" apex tv does
dude replace either power supply board or backlight inverter board, get them on shopjimmy for under $100.00 dollars both.
Dec 31, 2010 | Apex Digital AVL3076 30 in. HD-Ready LCD...
Apex dt250 digital convertor-- light stays red and will not turn green and display shows--- is there a reset procedure
Jun 30, 2010 | Apex Digital HT-150 System
52 rear projection
Your APEX tv has a convergence problem which is fairly common.
Check with www.TvRepairKits.com. they may have a kit for your model.
May 13, 2009 | Apex Digital GB4308 43" Rear Projection...
Apex tv
should be inside the back cover on the left hand side toward the rear of the television
Feb 18, 2009 | Apex Digital AT3208S 32" TV
No picture or sound?
hi i have a 42 inch plasma samsung tv i have picture and no sound
Nov 03, 2008 | Televison & Video
Apex gb5108
Your Convergence is off. Go through the menue to the CONVERGENCE and follow the on screen instructions.
Start with the RED gun and align each cross point starting with the upper left corner.
You will be pulling the red to match the green.
If the television shuts down during this process, it will reset the convergence and you can try again.
After you get the red gun perfectly aligned with the green, start with the blue.
follow the on screen directs and don't forget to store.
Use the remote for these adjustments.
I hope that this helps..
Jan 06, 2008 | Apex Digital GB5108 51" Rear Projection...
Saturation of unrealistic color
It is definite CCD chip problem. If you are within warranty period, send it back quick. They probably replace with other unit because the parts are not available for the product. Good luck.
Mar 13, 2007 | Apex Digital 4330z Digital Camera
Apex Digital GB55HD09W 55" Rear Projection Television Logo
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
