Question about Samsung Office Equipment & Supplies
I have a samsung scx-340sw how do enable the wireless it has a wps buttin but i cannot see it when i search on my laptop for available wireless devices
WPS from what I thought waas word perfect Does anyone have suggestions?
Posted on Apr 05, 2014
Why did the router ID change when I linked it via the Wps button to the DSTV wifi gadget ?
Here's and excerpt from the Netgear WNR2000 user manual explaining that this is normal behavior for Netgear routers that support WPS..:
  • Keep Existing Wireless Settings. This check box is automatically selected after WPS is enabled to prevent unwanted settings changes, and is also selected if you have already specified wireless security settings or your SSID without using WPS. When this check box is not selected, adding a new wireless client using the push button or the Add WPS Client screen (see "Push Button Configuration" on page 2-14) changes the router's SSID and security passphrase. You might need to clear it if you are using certain registrars, such as for a Windows Vista PC, to configure the router through WPS.
Even if your router is not a WNR2000, it is likely that the configuration interface pretty much the same so you might be helped by looking at Chapter 2 page 17 in the WNR2000 manual here..:
Or else, go to Netgear support (NETGEAR Support Welcome), select Wi-Fi routers and download/display the user manual pdf and search it for "disable router's pin" or "keep existing wireless settings" and verify/change the setting so the router doesn't make changes when you use the WPS button.
May 20, 2016 | NetGear Computers & Internet
What is WPS button?
The WPS is abbreviation for Wi-Fi Protected Setup. This function should you help to set up strong wireless network password (so called "shared secret") by very easy way.
For most of users is very hard to create, remember and assign complex long password to Wi-Fi router and client devices e.g. smart phones, laptops, printers.
Short and simple (non-complex) password is weak and can be broken by hackers. You can set strong password using WPS buttons. No device management access is required.
Procedure description
Press WPS button on both devices you wish connect each other. (Router, wireless printer...)Wait until password is set automatically and devices are connected.There exists second procedure in WPS standard. It is similar to described one, but PIN number is required in addition.
Security warning!!!
Enabled WPS function is very high security risk. The WPS sets strong password, but offers another security hole to hackers. The WPS standard is affected by well known vulnerability and therefore is insecure. It is recommended to DISABLE WPS ON ALL DEVICES. Go to device setup and disable the WPS completely.
Jan 28, 2016 | Computers & Internet
Usb printer status is not available while connecting the cable of printer to the laptop windows xp
Have you installed the printer driver and software for the unit. If not, download from manufacturers website at support.
You can then enable USB/wireless, which ever is your preference.
Dec 03, 2015 | Samsung SCX-4521F Toner Drum Cartridge...
Why won't it connect to wifi wireless laptop?
Dear
You can press WPS switch of the printer for a long time more than 10 secs. and search the wifi device in your laptop.
Before that its assumed that you have done the driver installed on your lap top using usb cable. If not, you may do the driver installtion using usb cable for 1st time and then disconnect the usb cable and install the driver by choosing wifi. before click next the wps switch of the printer to be pressed about 10 secs.)
Or you can follow the link to down load the driver and user manual.
Thanks.
Printer Support SAMSUNG India
Mar 14, 2015 | Samsung Xpress M2835DW Replaces M2625D /...
Hoe do we install Samsung Printer SCX-3405FW
Dear
pl. install the printer software first on the computer connecting the usb cable. after successful installation do disconnect the usb cable and reinstall the driver by choosing wireless, do press WPS key of the printer during installation.
Thanks.
Feb 27, 2015 | Samsung Office Equipment & Supplies
Where is the wps button on a N 1 Belkin route?
Using Wi-Fi Protected Setup
WPS uses WPA2 (described below) for encryption. It does not
provide additional security, but rather, standardizes the method for
securing your wireless network. You may use either the Push Button
Configuration (PBC) method or PIN method to allow a device access to your wireless network. Conceptually, the two methods work as follows:
PBC: Push and hold the WPS button located on the back of your
Router for three seconds. Then initiate the WPS procedure on the client device within two minutes. Refer to your client's documentation on this procedure. Pushing the PBC button will automatically enable WPS. The client has now been securely added to your wireless network.
PIN: The client device has a PIN number (either four or eight digits)
that is associated with WPS. Enable WPS through the GUI shown
below. Enter the client's PIN into the Router's internal registrar
(accessed through this GUI). The client will be automatically enrolled
into your wireless network within two minutes.
Oct 04, 2014 | Belkin (F5D8231-4) Wireless Router...
To adapt N300 Wireless Adapter, I need to press the WPS button on wireless router or gateway. Unable to locate WPS button.
The reason you may wish to press a WPS button is to connect to a WiFi network. The WPS button will be on the router, not on your computer. If no WPS button on the router you will need to enter the WEP/WPA password to connect to the router.
Nov 14, 2013 | Samsung Computers & Internet
Where is wps on Belkin n1 vision?
Before you will be able to use this function, you will have to log into your router and enable WPS push button in the security settings.
PBC: Push and hold the WPS button located on the back of your N1
Vision for three seconds. Then, initiate the WPS procedure on the client device within two minutes. Refer to your client's documentation on this procedure. Pushing the PBC button will automatically enable WP
Aug 21, 2013 | Linksys WRT160N Wireless Router
I am having trouble downloading My wireless Printer-CanonPixmaMX892 to my laptop!
Yes. It is a feature on the router and wireless enabled device. You can't use wireless without a router. I got a Belkin n750, and it has WPS. Basically, you activate WPS on device and push the WPS button on router, and wait a minute for it to configure.
Not to sell the Belkin, it one the easiest and user friendly routers i've seen. That is solely based on answering these questions. GL
Oct 17, 2012 | Computers & Internet
Im trying to set security on belkin n router
Hi...if your router has WPS capability, such as a special button to set up wireless security, then to use it your client computer/device must also be WPS enabled.
If it is, there are usually two options to configure WPS security: the push button method, or the PIN number. The push button method usually requires that you press the WPS button on the router, then within a set time, press the equivalent button on the computer (eg laptop, or whatever device it is). The PIN number method requires a PIN to be entered into the client computer. The PIN can sometimes be found on a sticker on the router.
Your manual should help with the details, but see this page for some more info.
http://kbserver.netgear.com/kb_web_files/n101691.asp
If you don't have a WPS enabled computer or don't want to use it, you can set up security manually. Please come back to Fixya if you'd like help with this.
Dec 29, 2008 | Belkin Wireless Pre-N (F5D8230-4) Router...
97 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
