Question about Home
Wenko toilet seat fitting instructions
Are the brackets right 'LEFT HANDED
5 Suggested Answers
  • 43 Answers
SOURCE: unable to fit a toilet seat
do you mean a water seat? like where you would install a water line? or a a seat you actually sit on?
Posted on Nov 16, 2008
  • 10865 Answers
SOURCE: elongated toilet doesn't fit where a round toilet was installed
Hi. There are toilets designed to accept a round seat and there are other toilets designed to accept an elongated seat. The primary difference is that the round seat fits a round bowl and the elongated seat fits an elongated bowl.
I recommend that you return the elongated seat and exchange it for a round toilet seat. good luck
Posted on Jan 31, 2009
co7196
  • 3433 Answers
SOURCE: i have a kohler toilet that needed a new seat.
Now isn't that a trick. Epoxy! The bolts,now studs, must be quite short. Well, glad you got it resolveve. I hope your house has more than one restroom..That epoxy will need a day or two toset up properly. :) Thank you for the reply. We all learn from each other.
Posted on Nov 15, 2009
SOURCE: I have the porcher veneto
I too have the same toilet seat that needs replaced. Porcher just told me there is NO replacement seat that can be used and they no longer make nor have stock of this toilet seat. I have a local company looking into the problem and will get back to me. For now I am going to take detailed measurements of hinge placement and length/width etc, and take a tape measure to every home imporvement store in the area. Anyone with any other suggestion would be greatly appreciated.
Posted on Jul 15, 2011
I need a toilet seat replacement of Porcher Veneto Toilet. The part number is 70030-00-001 and I'm told by Porcher is no longer available. They say no other seat fits. Any ideas? Where to find
I had the same issue and basically called every single american standard distributor I could find. I finally found one! They had the gold hinges but I didnt care, it fits and works fine. Make sure you know the part number. I had a good salesperson that knew to look for any color hinge so I had a seat
Jan 08, 2013 | Porcher Toilet Seat Veneto 70030.071
Installing range rover evoque dog guard VPL VS0082
You have a job on your hands. Remove rear plastic boot protector then unscrew the chrome bolts into the floor. Next remove side panels and ensure you disconnect light on right and 12v socket on left.
The side panel metal brackets are a breeze, but to fit the lower brackets one left and right and one central require you to unscrew the seat brackets into the chassis. I cant see how they can be got at nor can I remove the rear seat uprights to access them so, ive just bothered with the upper brackets. Doesnt move and took me half the time :)
Jun 03, 2012 | Land Rover Evoque Cars & Trucks
The hinge part of the toilet seat installed alright---but once the seat was connected to the tank, i tried to open the lid and it just fell off---the quiet close "dowels" for lack of a better...
Hi, Please don't take this the wrong way but did you install the hinges the right way? I fit bathroom suites for a living and have done this a few times wrong by putting the left hinge on the right side and vice verser. Sometimes the instructions are not very clear in explaining which side is left on the seat, as a result even though the toilet seat is closed, the springs are set backwards and are in fact in the up position. Double check the instructions once more, and just have a look on the hinges and seat because sometimes they have a small 'L' sticker on the hinge and an 'L' sticker on the seat and lid to correspond which hinge goes on which side. Hope this is of help to you.
Jan 11, 2011 | Kohler Toilet Seat - Elongated Front Quiet...
Our toilet is 127mmsfrom the wall to the centre of the s fitting and most toilets are 140mm, how can we fit a new toilet pleaase, also the water pipe is on the left hand side and toilets i have loked at...
Toilets water pipes can come on either side majority are on the left side when facing toilet.A longer water supply line can be used for the water connection if the toilet has it on the opposite side.A plumbing supply house and some good hardware stores will carry a close rough toilet that can set 50 mms closer to the wall than a standard toilet. Generally toilets are measured from the wall to the center of the drain in the floor which standard is 304.8 mm so a close rough would fit with a drain 254 mms from the wall
Jun 22, 2010 | Plumbing
Can you help re fitting cedo rue toilet seat
Had same problem, this website has the instructions:
http://www.haro-sanitary.com/technical_intelligence_ENG_HTML.htm
Dec 08, 2009 | Home
Cedo Rue Toilet Seat Soft Close White EAN: 4016959076115 Just bought this - fixing instruction diagrams are unreadable. Can anyone help? Does anyone know if the manufacturer has a web site?
Just bought a Cedo Rue soft close toilet seat. Can't make any sense out of the useless instructions and what to do with all the bits. It also included an alum key which I can't see a use for. Can you please help
Nov 29, 2009 | Duravit Home
One of the softclose buffers on the Subway toilet seat has pulled
Each soft close 'Barrel' is handed - one left - one right. (One is grey - the other white).
Most soft close errors occur because the seat hinges come loose. When this happen, the barrels slightly pull-out of the seat. (There are silver discs on the barrels - These should be tight against the seat).
Once the barrels become loose the first thing that happens is the top cover won't soft close - but the seat still does.
To rectify - puch both barrels tighly into fitting and tighten the hinges. (See below).
To tighen the seat hinges you need to get a flat headed screwdriver underneath the chrome round hinge cover - and 'flick off'. Underneath is a X head screw which id also hexagonal. You can either tighen both by spanner - or screw driver. (sometimes these can be tricky - but it will come off).
If both cover AND seat do not soft close AND the barrel silver discs are firmly located against the seat - the barrel has probably broken.
If so - spare parts can be obtained here:
http://bathroomstudio.co.uk/villeroy-boch-spares/cat_131.html
Jun 15, 2009 | Villeroy & Boch 9955 S1 Subway Toilet Seat...
Elongated toilet doesn't fit where a round toilet was installed
Jan 31, 2009 | Kohler - Toilet - One-piece - Gabrielle -...
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
