Question about Bravetti Quad Blade Food Processor
The top lid has a plastic round piece that connects to a rubber
Gasket on the out side of the lid...the spindle that holds the blade in place sit right under this round plastic piece...thanks, doug.
    President:
  • 3,433 Answers
Doug; Type in Bravetti in the search bar and you can find resources to find the gasket. good luck
Posted on Oct 30, 2009
The lid of my EP91 quad blade is broken
Hi Rosa
Depending on the severity of the broken lid....
I fix a lot of plastic items with either super glue or 2 part epoxy resin.
Then for reinforcement at the edges. I take a 2cm (aprox) piece of thin wire. Like a staple. Then heat it with the soldering iron. sliding back and forth until the wire is embedded into the plastic. even slightly covered over.
This often makes a cracked piece of plastic quite strong.
It may not look great but it might hold you over till you find a replacement
Good Luck
Here are some ideas....
Repairing plastic parts
How to Fix Broken or Cracked Plastic or Weld Plastic
Mar 16, 2016 | Euro-Pro EP91 Quad-Blade Food Processor
The extension post in my magimix 4200 is stuck on the motor shaft seems like It's welded on can anyone help
How to Change a Magimix Food processor plastic spindle.
This is meant as a guide only BBS ltd takes no responsibility for any damage done. We always advise that this should be done by a Magimix approved service agent.
The spindle is the part that sticks out of the motor this drives the blades, knifes, discs and cones for the food processor, this part may become worn after time or use.
Cover the main body with a cloth so as not to damage the look of the food processing machine.
Place two blocks of wood about 10cms either side of spindle cover. Then place two flat screwdrivers Horizontal either side of Magimix food processor spindle
Push down on handle of screwdrivers apply even pressure (keeping eyes well away from the spindle cover, they can fly off fast sometimes.)
The spindle will rise.
This will leave the metal centre shaft, Replace with a spindle cover bought from
www.magimix-spares.co.uk. Make sure you choose correct model, usually named on front of machine, or phone 01252 727755 for help.
When replacing, make sure that the New Food processor spindle is lined up and slide the spindle onto the centre shaft. Make sure this goes all the way down by gently tapping with a hammer.
All blades and attachments should be checked before placing back onto spindle cover, if the inside is damaged, this could damage the spindle cover again, any blade, dough blade , disc support that is marked should be replaced.
BBS Limited is the approved and dedicated supplier of Magimix parts & accessories for all Magimix products.
Please telephone +44 (0) 1252 727755 or fax +44 (0) 1252 727766 for help or advice. All images and text are Copyright (c) 2008 BBS Limited.
Magimix Spares Parts from BBS Ltd
Apr 03, 2014 | Food Processors
I need just the lid. dlc-194tx. please help
There is a small plastic piece on the lids 1-196 that slides into a slot in theback of the processer and is s safety interlock. unless your new lid will fit into that it will nto work. I know because i bought the wrong lid after the exact plastic piece broke on my original and I could not get the new one to work... right now my "work around" is to put both lids on.. the newer one does have the piece but its it the wrong place and I have to hold them while I use the processor.. sorry
Jan 30, 2011 | Cuisinart DLC-1 Mini-Prep Food Processor
My braun 3210 food processor will not work with the large bowl and sharp blade. Will work with the blender/chopper but large bowl the on/off switch cannot be moved. All of the contacts seem lined up - very...
I had a similar problem. Part of the lid had a small piece of plastic chipped away. It was the part of the lid that rotates and locks into the machine base. If the lid is missing a small piece of plastic on where it connects to the base, the machine will not switch on. You can compare the lid for the food processor to the mixing lid and see if the piece that juts into the base is broken at all. If it is order a new lid. There are several online places that still carry them; or try a local parts store.
Aug 20, 2009 | Braun Food Processors
My mini cuisinart stopped working
Place the gearbox on top of the blender/food processor
Place the work bowl over the spindle, with the handle facing the front of the machine - make sure the tabs lock into place.
Place the stem adapter on top of the spindle, then the blade.
Place the lid on top of the bowl, with the feed tube facing the back of the food processor. Then the pusher into the feed tube.
Here is the link to the user manual with visuals (p.6 is most helpful):
http://www.cuisinart.com/share/man/10_man.pdf
Mar 23, 2009 | Cuisinart BFP-703 SmartPower Duet Food...
Instructions for the food processor of my Cuisinart Duet
Here is the link to the user manual with visuals 9p.6 is most helpful):
-Tha Mp3 Doctor
Plastic piece broken on lid
Cuisinart has the part - you can order it from Cuisinart's website - www.cuisinart.com or call them directly at 1-800-726-0290
Feb 11, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
Magimix sytem cuisine
Jul 02, 2008 | Magimix 5100 Cuisine Systeme Food...
Stuck dough blade
On the DLC 7 Pro cuisinart the blade was removed by removing
the plastic bottom. Make sure the unit is unplugged. Remove the four rubber pads on the bottom. This was the hardest part because the pads are glued so securely that the inner rubber surface tears as it's removed. I used two flat blade screwdrivers and worked carefully, back and forth. Using a #2 philips, remove the four screws. Place the unit on its side and while inserting a screwdriver between a spoke and the motor frame gently turn the blade counter clockwise. Be careful not to put pressure against the cooling fins. Very little pressure was needed and the blade came right out. I might have been able to hold the shaft from turning without removing the bottom, by going through the vent slots in the bottom, but I was concerned with cracking the plastic. To replace the rubber pads I matched the design of the torn rubber pad with the shape (design) of the surface glued rubber and used thin two-sided tape.
Dec 27, 2007 | Cuisinart DLC-5 Food Processor
Bravetti Quad Blade Food Processor Logo
66 people viewed this question
Top Bravetti Food Processors Experts
Greg Cann
Greg Cann
Lawrence Oravetz
Are you a Bravetti Food Processor Expert? Answer questions, earn points and help others
