Question about Rc2 JLX OverDrive
Need new tire - Rc2 JLX OverDrive
Wrong tire size?
P designates a tire for a passenger car, 225 is the width of the tire in mm, 75 is the ratio of sidewall height to the width (eg thesidewalls are 225*0.75=168.75 mm tall), R is the type of tire (radial), and 16 is the diameter of the tire in inches. Customizing the tires gives you different performance results.
If you want your car to act according to how the manufacturer specified, go back to the stock tires. However, your current tires have a larger diameter than the stock, which means your rims are also larger than stock; you would probably have to replace the rims as well, which can be expensive.
I would stick with your new sizes. Different sized tires will not harm your vehicle in any way. I would also recommend going to a store that offers lifetime warranties like Les Schwab; they are invested in insuring that that everything is fitting correctly so they don't have to refund you anything.
Feb 14, 2014 | 2001 Jeep Grand Cherokee
Rims. well i was wondering if i will need a tire balance and tire rotation for a new set of rims
If you have 3o-35,000 miles on your car, you may be due for new tires. Tires will ware out, you may have hit a few pot holes,or had a few flats. Manufacturers usually warrenty tires for new cars for about the same mileage I stated above. If your tires are waring well possibly you only need a wheel balancing. Take your car to a tire dealer in your area , and have them check for you. GOOD LUCK.
Sep 25, 2011 | 2009 Hyundai Accent
I took my 2007 Hyundai Accent to the local dealer for an oil change and to also rotate & balance tires...well, I do have the need for new tires, one is in really bad shape but they wanted to charge me...
Because they want you to spend the money there.
There is plenty of tires that will fit one type of wheel, that has nothing to do with your engine light whatsoever.
Now, you might need to do some maintenance to your suspension in order to get it aligned so that your new tires dont get worn out prematturely.
Take it to a respectable tire shop in your town, forget the dealership.
Aug 23, 2011 | Hyundai Accent Cars & Trucks
Tie rods on front wheels need replacing, also need 2 new front tires. Can I have the front tires installed and then put the new tie rods on at home?
Depends on how far your drive is to home, if the tie rods are that bad to make the tires wear then i would only drive it a short distance. Tie rods control inward and outward positions of tire if looking at front of vehicle called (Toe) . When driving strat and a tie rod is damaged or defective and tires ares point in or out all your doing is dragging the tire down the road.
Mar 25, 2011 | 1995 Lincoln Continental
I do not have winter tires and I am wondering what is the best winter tire for 525XI. I have Continental all season and the winter performance terrible.
Of coarse,All Season Tires, are not for snow
You need a couple of new wheels, and dedicate them to
2 snows, of your choice.
Look at tire rack.com, just for the tire tests,
then look locally for treads you like
There are better tires than continental
When you need 4 new tires look at Cooper
Dec 15, 2010 | 2007 BMW 525xi Sedan
My tire blow up and all wires cut on half
You need a new tire. Go to a shop and buy a new tire cause you can't repair that. Also make sure you buy them in pairs. If it's on the front, buy two new front tires or back, two new back tires. Check on the side of the tire and check periodically to make sure the pressure is good. It says on the side what it should be, good luck!
Jan 16, 2010 | 2000 Toyota Avalon
Cupping tires Will I need shocks or just new tires?
A little more information would be good. However, start with the basics and work your way in as far as you need:
  • If you have not been rotating tires about every 6000 miles you can get cupping
  • If your current tires are cupped they have to be replaced to rid your self of any potential symptoms
  • The alignment should be checked if you have been rotating
  • When the alignment is done, the struts should be checked for leaks and/or wear
Oct 05, 2009 | 2004 Pontiac GTO
Tire pressure
Seance the car manufactures most likely did not produce the tires that are on the vehicle they will only give there recommendations as to the correct tire pressure. Always look around the perimeter of the tire and it will tell you the proper pressure for that tire. hope this helps. Good luck.
May 30, 2009 | 2004 Chevrolet Malibu
Tire leaks air slowly
did they replace the valve when the tire was replaced?
you could have the tire re-seated with some "bead sealer" if it is a minor leak at the rim
otherweise you would probobly need a new rim
May 26, 2009 | 2001 Oldsmobile Silhouette
13" tires on a 89 chevy sprint with 12" tires
you will need new rims but if they do it correctly (i.e. change the aspect ratio of the tire to counter act the rim size increase) this will not effect the speedometer.
Nov 28, 2008 | 1988 Chevrolet Sprint
Rc2 JLX OverDrive Logo
16 people viewed this question
Top Rc2 Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Rc2 Toy Expert? Answer questions, earn points and help others
