Question about Hartke B900 90-Watt Bass Combo Amp
My hartke b900 doesnt have sound
During a jam session, I cranked the volume all the way up to compete with the guitarest and the sound cut out 15 min later. Once I arrived home to further inspect my unit, I noticed that the fuse was still intact. I pluged the head in and checked for voltage. Everything seamed to test positive except the line leading down to the speaker.
3 Suggested Answers
  • 5603 Answers
SOURCE: Hartke Ha2500 250watt Bass Amplifier Head sound
This sounds like the thermal protection is activating. Make sure the vents and heatsinks have FREE AIRFLOW. If the sound cycles on and off, it could be a failure of the heater in the one vacuum tube in the unit. The heater could cooll and reconnect and then heat and disconnect.
Posted on Nov 03, 2010
  • 5603 Answers
SOURCE: after playing a a few
Maybe you are running high volume that is heating up the electronics and the thermal cutouts are shutting it down to avoid damaging the amplifier? Recommend you get a sound meter and check the sound level as you MAY be exceeding the safe level for hearing loss... I happen to know several near-deaf musicians who now cannot hear what they play. Search google for the safe levels. Back to the problem... Make sure you do use the compressor to PROTECT the speakers in this unit. Read the user's manual AND do NOT boost the bass with the EQ. Read the manual about this hazard to the speakers. It is LIKELY you are driving the amp to the point that a thermal cutout is tripping and then it has to cool down before allowing the amp to restart. The cool down time of 1-2 minutes would indicate this. Also make sure that the guitar cannot "hear" the amp or it MAY be sustaining regeneration causing excess power to sustain notes that you might not be aware of. Replacing speakers that are blown is expensive. You should avoid sound levels exceeding 95 DB when measured 6 foot in front of this. Look up the exposure limits of time for this level on google under SPL exposure limits. You can replace speakers and amps, but ears are not transplantable yet. With a deaf husband, he will be able to tolerate nagging to the max... think about the long term of deafness... it is no joke.
Posted on Sep 03, 2011
Hartke vx115 lost significant volume
If you've tried different heads with the same result, the most likely problem is a blown speaker. Check it with an ohm meter, and if it's blown, you can either replace it or get it re-coned.
Apr 24, 2015 | Hartke VX115 - 1 x 15 Bass Guitar Cabinet...
The amp cut off and is not coming back on
Sounds like you burned out the sub channel usually due to having a sub the draws more watts than the system can push, effectively blowing a capacitor or node within the internal motherboard of the AMP.
Oct 09, 2013 | Hartke Refurbished B Series B150 15 Watt...
No sound coming out for my hartke amps?
Are the internal speakers properly connected via the rear-mounted 1/4 inch "Speaker Output" jack? If so and still no sound, try connecting a separate external speaker (floor monitor, pa cabinet) for a "low volume" test.
The OM says the internal speakers are 4 ohm so it's unlikely that a wiring problem with speaker connections would cause all four to stop working. With AC power disconnected from outlet check for an internal speaker protection fuse BUT be careful. Charged capacitors can hold a charge for weeks!!!
Oct 25, 2012 | Hartke VX3500 Bass Guitar Combo Amplifier
After playing a a few small gigs my husbands Hartke vx3500 bass amp cuts out with the sound BUT the head seems to stay lit up, dont have problems when a low volume but during a gig has randomly cut out for...
It has something loose on the board or where the speaker wires connect. Combo amps are really bad about doing this. The vibrations from the speakers loosen the components on the board.
Sep 03, 2011 | Hartke VX3500 Bass Guitar Combo Amplifier
I bought a Fender Frontman 212R back in March of this year. It worked brilliantly for almost six months, until July 26th, when during a jam session, the audio randomly cut out. Upon inspection, it appeared...
Try using your guitar cord to plug in and out of the headphone jack several times while unit is on. There is a circuit that disconnects the speaker when using headphones and the circuit is activated when something is plugged into the headphone jack. This "switch" can get dirty and cause the can get dirty and cause the problem you describe.
Aug 26, 2011 | Fender FM212 Solid State Electric Guitar...
Hartke Ha2500 250watt Bass Amplifier Head sound cuts off(not turns off)after a little while comes back on
Oct 28, 2010 | Hartke Ha2500 250watt Bass Amplifier Head
After driving for 15 min stalls. when i go to start it cranks but doesnt start. after one min of sitting starts right up.repeats every half hour
Sounds like you need to replace the ignition coil,they heat up and go open but when allowed to cool they make contact and then the engine will start.
Dec 02, 2009 | 1995 Jeep Grand Cherokee
Bass module
You dont have to crank up the volume to hear the bass man. It sounds like you have a bad connection some where. check all your connections and also if the wires are shinning and not dull at the connection point. having carbon or dust there will not help.
Apr 10, 2008 | Bose Acoustimass 15 System
Hartke B900 90-Watt Bass Combo Amp Logo
18 people viewed this question
Top Hartke Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Hartke Audio Player and Recorder Expert? Answer questions, earn points and help others
