Question about Mitsubishi WS-65315 65" Rear Projection HDTV-Ready Television
HD channels run off the edges
The picture, most noticable on the HD news and sports channels, slightly runs off the edge. For example on ESPN news you can not see the first letter of the words listed at the left and the last letter of the words listed at the right.
  • 121 Answers
That solution is likely to be found in the cable or satellite box set up menu. Make sure that the output video format (4:3, letterbox, etc.) matches the TV
Posted on Feb 25, 2009
Watching a football game picture is very unclear
The noise reduction option will cause a blur on fast movement. Also, you probably already know this, but a standard definition broadcast will look very blurry on an HD TV, so make sure the channel you're watching is actually an HD channel.
Oh, wow, I just noticed that this is from October. Oh well, maybe you're still having problems.
Oct 18, 2009 | LG 50PS60 50 in. Plasma HDTV
Looking for hd channel
To get an hd picture you have to use a digital input and this cannot be done by simply turning it to a channel. You need to hook up your HD receiver (box) to your tv using either an HDMI or a Component which will be a cable that looks similar to an rca but there are three of them and the colors are bed blue and green. If there is a red, blue and green on the back of the cable box and the tv hook them together with a component cable and then find the input on your tv that correlates to the compnent connections and then even after all of this you need to be tuned into a channel that is offered in high definition and if you have cable like I do the high definition channel will be a seperate channel from the regular one. Comcast in my area puts the HD's from channels 400-500. For example my espn HD is channel 403 but just regular espn non HD is on channel 27 in my area.
Sep 16, 2009 | Philips Magnavox 51MP392H Rear Projection...
How to adjust pitcher size
Try this setting and see if it helps: Menu>Picture>Advance Picture Settings>Scan Velocity Modulation (Check mark it) Then the TV will try to auto adjust it's picture size to the source you are using. I noticed it most on ESPN News HD. If you are using a HD cable box, you might be able to use the cable box settings to change the picture size. Sometimes the box is on "Zoom" and it takes the top of heads off.
May 25, 2009 | RCA R52WH76 Television
Almost fixed!
see my last post to you regarding the converegence resistors
Jun 15, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Samsung DLP HL-P5674W Screen is stretched at the top and bottom...
did you ever find out the problem , mine is doing the same thing,
please email if you can help
thank you so much
Mar 05, 2008 | Samsung DLP HL-P5663W 56" TV
All edges are cut off in 1080i display mode
I have the same problem and have not been able to fix it either- i think it has to do with the glare screen on these TV blocking some of the viewable area.
Oct 27, 2007 | Mitsubishi WS-55805 55" Rear Projection...
Image size too large, cannot see all of sports scores scrolling on the bottom
hey voiolentce. if you press the # button on the cablebox remote control you can fine tune the zoom by those 20 pixels you want. you are most likely set at zoom 1 currently. thats where i was when i had this same problem and it took me days to figure out that all i needed to do was press the damn # button. i couldnt see any of the scores on espn sports games and its been driving me crazy. hope this helps!
Sep 10, 2007 | RCA R52WM24 52" HDTV Projection Television
Screen is distorted on the top and bottom
Loose connection on convergence board, you could tapp and should go back to normal, find loose conn. and solder back.
Sep 09, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Sylvania 6427GFG geometry problem
Your fault is called the North South Geometry and the centre is not amplified as much as the outsides.
This is an adjustment easily carried out by a competent tv engineer.
I would call the company the warranty is with and ask them for a service call under warranty to sort the picture geometry out.
Jun 29, 2017 | Sylvania 6427FB 27" TV
The picture is round
No my freind, im afraid that you have bad waveshaper capacitors in the vertical sweep circuit in your TV set. This is not an adjustment. you should have a pro assist you with the repair of this set as it is dangerous because of the high voltage inside these sets.
Sep 24, 2006 | Sony KV-27S42 27" TV
Mitsubishi WS-65315 65" Rear Projection HDTV-Ready Television Logo
131 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
