Question about D-Link DSS-16+ (dsdldss16p) 16x10/100 Mbps Networking Switch
D-Link DSS 16+ Unable to get IP address
D-LINK DSS 16+ connected to multiple DHCP servers (Cisco, Netgear, Linksys) will not pass a DCHP address. Cycled power on the switch (NO-GO), used several ports (NO-GO), used straight thru, and cross-over CAT5/5 on different ports (NO-GO). D-Link keeps providing a 169.254.X.X IP address to client computer. Any thoughts?
2 Suggested Answers
  • 82 Answers
SOURCE: Unable to get IP address
The D-link DSS switch should require nothing special to pass along IP addresses. You may want to power off your computer, switch and router, and then power up after 30 seconds. It could be that when you were testing, the computer pulled an IP address from the router and if you moved to the switch without renewing the IP, there was a conflict. Powering down and repowering should do the trick.
Posted on Jun 18, 2011
How to connect my self and make my IP address ?
you can set your laptop up to detect ip address automatically in its network settings. if you had provided the operating system it would have helped to narrow down how to do this. If you had told us how you plan to connect to the router this also would have been helpful. Are you connecting via blue cat5 ethernet cable or via wireless. If it is wireless your laptop should detect the wireless network and you can ask it to connect to it. If the wireless link is encrypted you need to log into the router via ethernet cable and look for the securirty settings on the wireless and find out what the encryption code is. Usually the router will use what is called an internal IP address range. the subnet is usually class c being 255.255.255.0 and the ip address default gateway IP address is usually either 10.0.0.1 or 198.168.0.1 and this can be put into the browser to log into the router. When you set the laptop to automatically obtain the IP address the Wireless Router has a DHCP server that manages the leases of IP addresses to computers connected to it. However if you are connecting the Wireless Router into an existing network with another router you will need to set the IP address to the next IP address eg 10.0.0.1 on existing router make second router 10.0.0.2> if you have a DCHP server on the wireless turn it off if you have a DCHP server on the existing router otherwise you have confusion as to which DHCP server to listen too on your network.Make sure the DHCP router does not allocate at least the first 10 addresses eg 10.0.0.1 to 10.0.0.10 to allow for the routers and printers on your network that may need dedicated IP addresses (Static IP addresses)
Feb 07, 2015 | D-Link dlinkgo Wireless N 150 Router...
How do i split out multiple static ip's
You need to attach a DHCP-server to the hub/switch, and configure that DHCP-server to "reserve" a specific IP-address for the MAC-address for the network adapter inside each of the computers that is to receive a "static" IP-address.
For a DHCP-server, you can connect a "cross-over" Ethernet cable from one of the switch-ports to one of the LAN-ports on any "home" wired router. That "home/SOHO" router will become the DHCP-server for all the computers connected to the switch.
Nov 19, 2012 | Linksys Computers & Internet
I have installed a antamedia dhcp server, but it does not give out ip addresses. please guide me on how to set this up. i have awindows machine connected to a linksys router 10.0.0.1 and the computer int...
Make sure DHCP is off on the Linksys router first, set the IP of the router inside the scope of your DHCP server's scope (set it as the gateway so if your using 192.168.1.X, set it to 192.168.1.1). After that, remove static IP settings on your desktop (except the one using DCHP, set that to 192.168.1.10)
Mar 01, 2011 | Antamedia DHCP Server
We have a DHCP problem with our thin client HP T5540, the network interface can't get an ip address fom the DHCP server for 30 seconds so it can't connect to citrix xen serverver for virtualization...
First of all check the configuration of the unit if it's AUTOMATIC IP/DHCP, if all OK you can test by configuring a static IP (use an unused IP in the server's DHCP table) than check the connectivity (ping something), if that works you have a server rule/DHCP or DNS problem
if it's still not working check the cabeling and connectors for connectivity (with a good cable tester) or an other (working) computer.
Oct 22, 2010 | HP t5540 VIA Eden 1GHz Thin Client...
Apr 13, 2010 | D-Link DSS-16+ (dsdldss16p) 16x10/100 Mbps...
How do I connect with my WGPS606 if there is no setup cd and the default ip does not work? My router has encryption and the WGPS needs the info.
you need to set your print server for dhcp, you need to log in and verify the settings OR just set it back to default because dhcp is default. gl
Nov 06, 2009 | NetGear WGPS606 (WGPS606NAR) Print Server
Desktop prints fine but laptop will not print going through dlink 1260 print server either wired or wireless. I should say I have a linksys router that my desktop is hardwired to, but the Dlink server is...
as no one has answered this I will give it a go .
Check or download the latest printer driver for whatever operating system the laptop is running.
Could be a dhcp server clash from the wi fi print server and the link sys router . Check there are two DCHP servers and if there are deactivate on and use the other .
check the ip addresses in use on the laptop and on the desktop and the printer. make sure subnet mask are all the same but ip addresses are unique but within the network range. eg 198.168.0.2 - 198.168.0.254 and subnet mask 255.255.255.0
or 10.0.0.2 - 10.0.0.254
check the ip address for print server is different to the ip address for the router and make sure DCHP range does not clash with router assigned ip addresses .
Dec 26, 2017 | Toshiba Satellite A205-S5831 Notebook
Wireless connection, but no internet
Verified that the Internet connection is working good
- Now if your connected to the wireless network but unable to access a website try this:
- Open the control panel
- Open the network connection
- Right click on wireless networks (Choose properties)
- Choose Internet protocol then click properties
- Assign DNS Server address (Preferred DNS: 4.2.2.2, Alternate DNS: 4.2.2.3)
- Leave the DCHP as obtain IP address
Mar 04, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Ip address for clients using autonomous cisco 1130ag witout dchp
the cisco1130ag will provide ip addresses and serve as a DHCP server for your laptops...
You still need an IP address for your 1130ag so either your ISP provides you a static ip that you can put in the 1130 or if your ISP provides dhcp then you should be able to plug and play with your 1130ag
Jan 15, 2009 | Cisco Aironet 1131AG 802.11a, 802.11g/b...
D-Link DSS-16+ (dsdldss16p) 16x10/100 Mbps Networking Switch Logo
78 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
