I checked The contenuaty of the element and Im getting resistance. Check voltage at element ends and theres none. I doesn't appear to have any relays to check. Dose this mean the Electronic control panel needs to be replaced?
This is what you do.with power off,disconnect the wire from one side of the broil element and isolate from ground but so can check with volt meter.now while isolate take your meter put one probe on the neutral [middle of cord where connects to range] and the other on one side of the element and then the side you have isolated.you will only get a 110 reading on the side that is working.the side that gives you no reading is the side you trace back........so if side that has no power leads back to clock[it must be the next switch,because if something before it you would check there first] and all setting are correct then yes its the clock.....take a look at your wiring diagram,there's one in that range.when you know the side that lost power look at the diagram and it will show you the previous place the power passed threw. hope that helps you understand whats going on if need more advise you can email thru FizYa God bless ,tom
I will try that. Thanks
