Question about Dryers
Whirlpool Imperial seventy dryer does not heat up
Day before yesterday, my Whirlpool Imperial seventy dryer was working fine. Today, it seems to have given up the ghost. It goes on, spins but no heat. I'm not sure if this is a gas dryer either. It is in an extreamly tight location and hard to see, though, I think I see a small copper gas line going into the bottom of it. Please advise
  • Anonymous Mar 31, 2014
    element cover remove
    President:
  • 1,214 Answers
If there is a copper line feeding gas to it, PULL THE DRYER WAY FROM THE WALL AND TURN THE GAS OFF AT THE VALVE IMMEDIATELY!
Natural gas and copper do not mix, and the copper line will corrode from the inside out.
Now, on to the problem, it's very likely the timer has failed IF it does not rotate all the way through the drying cycle. If it does, and the clothes do not heat up, then reply back what you are experiencing and I will give you move help.
Posted on Jan 24, 2009
My whirlpool imperial seventy won't start
Unplug unbit, remove screws in console and lift panel. remove connector from push to start switch anc check continuity.
Feb 16, 2013 | Whirlpool Dryers
Whirlpool Imperial gas dryer won't spin
It's a broken belt. Replace the tensioner assy also
Nov 03, 2009 | Whirlpool Dryers
Whirlpool Imperial Electric Dryer wont heat up
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jul 22, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
LER4634E WHIRLPOOL FRONTLOAD ELECTRIC DRYER WORKED GREAT
If you have a access to an AC voltmeter, measure the two slanted connections in the wall socket for ~220 volts. If near zero, measure at the load side of the dual breakers for the same voltage. If still at or near zero, one of the breakers has gone south. Replace the pair of breakers.
If you measured 220 volts as above, then the problem is within the dryer--probably a burned out heating element or open thermal fuse. Major tear-down to find and fix as the heating element is behind the drum.
Jul 17, 2009 | Whirlpool LER4634J Electric Dryer
My whirlpool imperial seventy dryer timer quit working when the heating element was replaced and now the dryer quit turning on at all, makes a clicking noise when you turn it on and that's all
I have the same dryer and it did the same thing to me. It ended up being the thermal switch and a frozen drum and belt due to excessive lint. Had to pay $190 to fix it, not sure if this is something that can be self repaired.
Jan 12, 2009 | Dryers
Whirlpool Imperial Electric Dryer won't start
I have a problem with my Whirlpool IMperial electric dryer, not a Duet gas dryer.
Jul 12, 2008 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryers Logo
353 people viewed this question
Top Dryers Experts
