Question about Bissell 1425 Little Green ProHeat Handheld Steam Vacuum
Bissell 1425 Little Green Proheat Trigger Problem
A small part in the trigger assembly (spring) is rusted and broken. Bissell does not sell this part to consumers, sad but true. Where do I find this part? I've looked EVERYWHERE on the Internet.
Thank you,
Nigel
  • 1 more comment
  • dmbirchmd Jan 24, 2009
    Thank you for the answer. I was afraid someone would say that. This part is a small spring that might cost a quarter. I toss this machine before I pay someone $50.00 to fix what I could fix in 10 seconds IF I COULD FIND THE PART.
    Until Bissell begins to make parts that are known to be deluged with water out of stainless steel, I'd suggest that others buy something other than Bissell. I've had several of their steam cleaners, and usually it's the cheap plastic parts that break, but to put a steel part in a trigger on handle assembly on a machine that squirts water is nuts.
    Thank you kindly for your speedy answer.
    Best,
    Nigel
    Well, I looked at essco.com, but it hardly sells parts for steam cleaners. Oh, well, thanx.
  • Anonymous Mar 17, 2009
    Thank you, Veronica. Great suggestion. Unfortunately, my spring was so bad that it broke when I was twisting it, so, again, unfortunately, I need a new spring. Not badly enough to pay $50.00, or probably even more to a service center. A service center isn't needed to fix this simple part. Bissell needs to make these parts out of stainless so that people don't have this problem.
    Thank you again,
    Nigel
I doused the spring with lubricant and twisted it back and forth until it loosened up. I used my husband's Paslode lubricant that he has for his Paslode tools. It's nice and thick and "clingy."
Posted on Mar 17, 2009
  • 66 Answers
Hello Nigel sorry to say but you may have to take the machine to a repair shop you can try a website essco.com but you have to have an account you can try . hope this helps
Posted on Jan 24, 2009
  • 3 Answers
You can get a brand new hose assembly with trigger handle for $10.99 plus shipping. You can find it on-line, part # B-2035019 Bissell
Posted on Mar 12, 2010
Replacing hose on a little green
Call the Bissell Consumer Care at 1-800-237-7691 they should have a cheat sheet to guide you through it.
Feb 10, 2015 | Bissell 1425-1 Little Green ProHeat...
Get Bissell little green pro heat to spray?
These units are known to clog, the water left in from the last use can harden right where the water sprays out. Try using a pin or needle to clean away the harden water. See also if the spay trigger can come apart for a thorough cleaning.
Sep 27, 2014 | Bissell 1425-1 Little Green ProHeat...
Will not spray
There are a handful of places that the mechanism can get blocked. The easiest test is to remove the brush attachment and pull the trigger. If it sprays fine, then the blockage is in the small length of tubing in the brush attachment. The most likely place is in the small plastic piece at the very end of the attachment. You should be able to see the small plastic piece where the tubing ends, this is a common place for a blockage. You can usually use a piece of thin wire to clear the blockage.
Nov 28, 2010 | Bissell 1425 Little Green ProHeat Handheld...
Won't spray, only dribbles
There are a handful of places that the mechanism can get blocked. The easiest test is to remove the brush attachment and pull the trigger. If it sprays fine, then the blockage is in the small length of tubing in the brush attachment. The most likely place is in the small plastic piece at the very end of the attachment. You should be able to see a small plastic piece where the tubing ends, this is a common place for a blockage. You can usually use a piece of thin wire to clear the blockage.
Nov 12, 2010 | Bissell 1425 Little Green ProHeat Handheld...
Lost instructions
Try google.com, ask for manual for Bissell 1425 Little Green ProHeat Handheld. Sometimes they can send you a new manual.
Nov 01, 2010 | Bissell 1425 Little Green ProHeat Handheld...
How to use Bissell "Little Green" Proheat
BISSELL User’s Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User’s Guides and enter the model number of your unit.
User Guide will be displayed as a PDF file.
Aug 25, 2010 | Bissell 1425 Little Green ProHeat Handheld...
I lost the instructions for your little green machine
You can find instructions for your Bissell 1425 Little Green ProHeat at www.bissell.com and then go under products by category and then scoll down to where it says Deep Cleaners. Then click on compact cleaners and it will take you over to where your version is and on the left hand side click on the model Little Green ProHeat. when that opens up on the right hand side look to where it says downloads and you will see where it says User Guide and its in (PDF) format.
Sep 26, 2009 | Bissell 1425 Little Green ProHeat Handheld...
I NEED THE MANUAL FOR THE BISSELL LITTLE GREEN PROHEAT TURBOBRUSH MODEL NUMBER 1425-1
BISSELL User's Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User's Guides and enter the model number of your unit.
Sep 18, 2009 | Bissell 1425-1 Little Green ProHeat...
Bissell 1425 Little Green ProHeat Handheld Steam Vacuum Logo
414 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
