Question about Kirby Ultimate G Bagged Upright Vacuum
Is barely sucking up anything
I just noticed that my Ultimate G sounds different and isn't sucking nearly half as well as it did before. Anyone know of things I should check?
Re: Is barely sucking up anything - Kirby Ultimate G Bagged Upright Vacuum Vacuums
Take it service centre
Posted on Jul 14, 2007
  • 159 Answers
I dont fix vacumes but I would say if you took the vacume apart you will find that it has a blockage. Clean it out and it should work fine.
Posted on Jul 12, 2007
0 characters
3 Points
Need to know if a part I found after I disassembled. And reassembled my shark professional liftaway navigator vacuum is critical . It's a white rubber gasket of some kind, half moon shaped
The gasket sounds like one between the motor housing and a detachable dirt cup. You didn't include a model number so it's hard to get into specifics, but if it is this gasket I'm speaking to - suction power will suffer and or dirt / dust will leak out. If a different gasket - it may not be noticeable to you that anything is wrong - but gaskets are usually critical components that are used to fill gaps that might otherwise allow dirt, water, dust etc. into spaces where it shouldn't.
Apr 17, 2015 | Shark Vacuums
The bottom of the vacum isn't sucking
My dyson animal seems to have a blockage in the base it makes I sucking noise then pops the sucks ion threw the wand is fine
Oct 22, 2012 | Dyson DC28 Animal Bagless Upright Vacuum
Our Dyson sucked something up last week (not sure WHAT) and now the telescoping hose won't ****. Well, it sucks but just BARELY . I took the hose apart and can't see anything, but it makes a weird noise...
Well if the hose is completly clear the blockage is either before that or after that the brush roller should come out to clean the tube as you know also comes out make sure all are clear right up to the collector
Jul 17, 2010 | Dyson DC14 All floors Bagless Upright...
Dyson DC14 won't **** from hose but works fine otherwise
There is probably a clog in the U-bend on the back of the unit at the bottom. Removed with a twist of a plastic screw by a coin or screw driver. If not in the U-bend check in the hose/wand.
Nov 28, 2008 | Dyson DC14 Animal Bagless Upright Cyclonic...
Kirby Ultimate G will not suck with main brush head attachment
You may need a new belt, it may have stretched enough so it isn't turning the brush roll anymore.
Mar 08, 2008 | Kirby Ultimate G Bagged Upright Vacuum
I had the same issue. I also noticed a different sound when it was turned on. I checked over it and noticed the red float door has a small screen which was clogged. I removed the block and its working again...hope this helps someone =)
Feb 12, 2008 | Vacuums
Ultimate G Shampoo System
Follow these instructions next time you hook up the shampooer.
As for the bead, you need to lift the nozzle of the power head up and ver the bead to pick it up. The nozzle makes a great suction seal with the carpet and that's why it's pushing it. If you tried that, make sure that the green light on you nozzle is lighting up. If not, you either need to change the belt or make sure you hasve it on properly. For help with this, here's another guide...
Aug 26, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Ultimate G Bagged Upright Vacuum Logo
119 people viewed this question
Top Kirby Vacuums Experts
Mike Cairns
Mike Cairns
Roger Potts
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
