SOURCE: bonnet release in grill broke renault megane scenic
when you say the bonnet has been pushed in do you mean like in a traffic accident if this is the case then is your grill damaged,the reason i say this is the only way you are going to open your bonnet is through your grill so a replacement grill will be needed.if you take this course of action,take a torch and look up under the bonnet you will se the bonnet realease at the very front of your bonnet it will have the bonnet realease cable attached you might need help at this stage,get a friend to push down on your bonnet,put your hand in and push or pull the lever until it releases as this works on a hook system and with the damage it might need a pretty stronge screwdriver to force it always remember the radiator is very easly damaged and very costly to replace .Hope this will help you get your bonnet open .adrian
SOURCE: Renault Megane Scenic
my warning light comes on saying "check emissions" and the manual tells me to go to my Renault dealer immediately. What is wrong? Can we drive the car normally for any distance
SOURCE: 2004 181: Engine Will Not Idle Renault Scenic 2005 1600...
renault scenic 1600 -- year 2004 -- runs ok but will not idle checked throttle pedal resistances all ok any sugestions?
ideally a picture showing the where the fuel line goes etc
renault megane scenic 1.4 expression 2004 model
done it
what type of diagram do you need ?
rinault megane 2004 hatch
