Question about Nintendo Video Game Consoles & Games
Balance board wont connect to exerbeat
Wii exer beat wont recognise my balanceboard tho it works fine on wii fit did connect it once after few trys but not since
SOURCE: Jillian Michaels won't allow Wii Balance Board for weigh in
Actually, I had the same problem and discovered that you have to have the wii remote in your hand and that you must push the A button once you're on the board. Otherwise it just keeps telling you that you're moving too much.
Posted on Jun 01, 2009
SOURCE: balance board on wii fit doesn't turn on? power light flashes
All i had to do was SYNCHRO the board by pressing the synchro button on the wii balance board were the battries go, the power LED will blink (note once the power LED has started blinking, stop pressing the synchro button)
THen you need to press the synchro button on the wii console, while the wii balance board's power LED is blinking
Posted on Oct 18, 2009
  • 69 Answers
SOURCE: wii fit board wont sync
get a new board or get it fixed,
try different batteries
dont put any unessessary weight on it
dont stomp on it or jump
be gentle with it
get a new peice so no re-scyn
make sure its not too close too the wii
Posted on Oct 30, 2009
  • 47 Answers
http://www.nintendo.com/consumer/systems/wii/en_na/ts/balanceBoard.jsp#sync
this link should help you link the wii fit board
Posted on Jan 27, 2010
  • 6 Answers
SOURCE: My Wii Fit balance board is not working. I've
might be someoneelse's
Posted on Jan 21, 2011
How to connect wii fit board to the wii
Important Note!
Do Not use "One-Time Mode" sync.
Syncing can be completed only if a compatible game disc is running in the console.The Wii Balance Board may need to be synced to each compatible game individually.Some games may require you to go into a specific screen to sync the Wii Balance Board.These sync settings will be saved even after the console is turned off.
1. Insert a Wii Balance Board compatible game disc in the Wii console.
2. Use the Wii Remote to select the Disc Channel from the Wii Menu, then select "Start" to begin the game.3. Open the SD Card slot cover on the front of the Wii console.4. Remove the Battery Cover on the bottom of the Wii Balance Board.
5. Press and release the SYNC button on the Wii Balance Board. The Power LED on the board will start blinking.
6. Press and release the SYNC button on the console while the Power LED on the board is still blinking.
7. The Power LED will stop blinking and light steadily once the synchronization is complete.8. Replace the battery cover and return the board to the normal operating position.
Nov 16, 2011 | Nintendo Wii Fit for Wii
My wii fit was working perfectly fine when i purchased it, then about a month or so later the wi fit game didnt recognise the balance board, so when it said please turn the power button on and i did, it no...
When you power on the wii fit board, does the light flash continuously? If so, you will need to sync your board with your wii again. You can get instructions on how to do so here: http://www.nintendo.com/consumer/systems/wii/en_na/ts/balanceBoard.jsp
Mar 22, 2011 | Nintendo Wii Fit - Balance Board + Game...
Wii fit wont turn on, switch wont stay in
The switch on a Wii balance board is not one that stays in, it is not a spring loaded toggle switch. Also it will only stay on if you are in a game that uses it (like Fit, or a select few others). This is a battery save feature. If you are not logged in to a game that uses it the balance board senses that it is useless and turns off after a couple of seconds. This is true even if you have a game that uses it in the Wii but you are in the menu.
Nov 01, 2010 | Nintendo Wii Fit - Balance Board + Game...
Wii Fit board won't work. It's not the batteries
Try resyncing it or doing it for the first time if you have not. make sure you are using a game that is compatible with it.
Here is a link to alot of information about the wii fit board.
Apr 18, 2010 | Nintendo Wii Fit for Wii
My wii balance board wont stay on
First thing to do is install fresh batteries.If the Wii Balance Board is still experiencing power problems after trying new batteries and ensuring that they are inserted correctly, please call 1-800-255-3700 for assistance
Apr 07, 2010 | Nintendo Wii Fit - Balance Board + Game...
Wii fit board wont sync
Jan 17, 2010 | Video Game Consoles & Games
I got a brand new wii fit balance board and i syncd it, put in the batteries that came with it, (new batteries) put on a cover, and its working fine. about 2 weeks later it was bought, I was playing a game...
According to the Nintendo support site, here's what to do.
Your movements are not being correctly detected
  1. Make sure that the Wii Balance Board is placed properly in front of the TV: The blue power light should be facing away from the TV. If the Wii Balance Board is facing the wrong way, your movements will be reversed.
  2. Check the battery life of the batteries in the Wii Balance Board. If the battery level is low, try a fresh set of batteries.
  3. Check to make sure nothing is pressing against the bottom of the Wii Balance Board. If you do find anything pressing against the bottom (such as carpet), try using the foot extensions.
If the Wii Balance Board is still not correctly detecting your movement, please call 1-800-255-3700 for assistance.
Here's the link if you want to see for yourself
http://www.nintendo.com/consumer/systems/wii/en_na/ts/balanceBoard.jsp#movement
Jun 08, 2009 | Video Game Consoles & Games
Feb 08, 2009 | Majesco Jillian Michaels Fitness Ultimatum...
Canot use Wii fit balance board
Ensure batteries are fresh. Ensure that Wii Fit (or other Balance Board game) is started up completely before pressing the power button.
Jan 04, 2009 | Nintendo Wii Fit for Wii
Video Game Consoles & Games Logo
29 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
