Question about Yamakawa DVD-238 DVD Player
Black TV screen when turning player on. Remote also stopped working.
This must be my mistake in setting unit up by choosing wrong option. TV screen is black now and cannot enter the setup any longer to correct the problem. No response when pressing any key, including power key on remote. Please give me a code sequence to unlock it.
Hjghjghj
Posted on Aug 29, 2008
Press scan bottom on your remote
Posted on Jan 06, 2008
SOURCE:
Cannot see the screen Philips DVP5990 DVD player. Setting problem
You may have probably turned on Closed Caption on your TV. Unhook the DVD player to find out if it disappears. If it disappears then Closed Caption is on on your TV. Turn off Closed Caption. If cannot find how, give me the brand and model of your TV.
Oct 30, 2009 | Philips DVP5990 DVD Player
Rca model# d52w135d screen won't turn on
Are you saying that the screen goes black after the DVD player stops working?
Jan 10, 2008 | RCA D52W135D 52 in. TV/DVD Combo
Black box in middle of screen
maybe you have turn on the text option on your unit. this option falls under the closed caption try turning it off.
Aug 01, 2009 | Televison & Video
If you enter set up mode and do the wrong thing can you retrieve
Hi there!
With the CH DVD300 powered on,you might want to try pushing the stop button on the unit itself for about 20 seconds. That should reset the DVD player to default settings. It worked on mine.
Mar 28, 2009 | Cyberhome CH-DVD 300 DVD Player
I can only record and play back in black and white.
siri,
for the black and white screen output of your DVD and VCR.
1) for DVD player: using remote control locate "setup" button and click.a dialogue box should appear indicating " audio setup" video setup" etc.....
2) select and scroll to "video setup". in video setup there should be an option to choose "AUTO" "PAL" or "NTSC"
3) choose "auto" then check if any change in screen color.
for VCR, locate a switch or button indicating "PAL" "Auto""PAL SECAM" "NTSC". same with the dvd choose and select "auto"
note: if you still have the manual for both VCR and DVD check the instruction with regards to video color setting.
cheers,
mark
Jan 15, 2009 | Philips Magnavox DVD/VCR Dual Player
Automatically plays a dvd
choose the activity;  go to settings choose options find the option "play on enter" Choose "do not send play"
Jan 10, 2009 | Logitech Harmony One Advanced Universal...
Sound, but no picture
If you have a progressive scan button on the remote, it might change it back. Try all the video related buttons on the remote with the DVD player on.
Oct 19, 2008 | Cyberhome CH-DVD 300 DVD Player
I get a double black-and-white image when the TV is running through the VCR
I had this same problem once. Go on your dvd menu and go to settings and hit "reset default settings". That worked for me. Hope this helps.
Aug 31, 2008 | Panasonic DMR-ES40V DVD-Video Recorder
Black box appears in TV screen
The problem with the black box happened to me. I had pushed the subtitle button on my remote by mistake. Interestingly enough, as soon as I pushed the SUBTITLE key again, on the remote, the black boxes disappeared.
It also says CC which means closed captioned-- So the bottom on my remote is Subtitle, and then on the subtitle button is cc...
I hope this helps
Jun 04, 2008 | JVC AV-32260 32" TV
Black and white picture
turn off you dvd player... them click on "setup" button on your remote control! them click right botton to appear "tv sys" them click "enter"... choose your tv system, PAL or NTSC.
Jan 15, 2008 | Pioneer DV-360-S DVD Player
Televison & Video Logo
132 people viewed this question
Top Yamakawa Televison & Video Experts
Marvin
Marvin
Are you a Yamakawa Televison and Video Expert? Answer questions, earn points and help others
