Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool frountloader washmachine door locked
L have clothes in the machine and cannot get them out door is locked please someone help if know thanks.
    President:
  • 1,214 Answers
Has the washer finished it's cycle?
Reply and I will try to help more.
Posted on Jan 24, 2009
Door locked and unable to unlock to remove clothes. I notice that someone else had the same problem in August 2008. I do not know what a star tool is. Please help, I need to get my clothes out. Heck of a...
if you have a wet dry shop vac you can use it to remove the water from the unit.
Attach the vac to the end of the drain hose and remove the water once the water is removed then you will unplug the unit for a few seconds plug it back in and you should be able to unlock the door.
If that works then you will need to check the drain pump and hoses for any obstructions that may be restricting the flow of water.
Jan 01, 2011 | Whirlpool Duet GHW9150P Front Load Washer
On My Whirlpool Duet Model# GHW9150PW A setting kicked on that
Press any of the buttons on the control panel to see if the buttons are operational or check to see if the "Control Locked" indicator light is lit. If the control panel is operational, you may mistakenly lock the door.
Press and hold the "End of Cycle Signal" button for approximately three seconds until the "Control Locked" indicator light shuts off.
May 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer doesn't unlock the door at the
Hi There
I have found this for you to read. it's door unlock error. Hope this helpful and let me know how it goes.
F/dU Door Unlock Error
A Door Unlock Error occurs if the door cannot be unlocked. It will try to unlock the door 6 times before displaying the error.
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Thank you for writing to fix ya.
Best Regards Richard
Dec 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My husband is trying to fix the washing machine, and we have DL F code, i know is something to do the the door, but he checked the door and I think that is not the problem!!!!We have a Whirlpool GHW9200lQ...
Mine did the same thing. The plastic part that locks the door is bad. My brother repaired mine instead of calling someone the part was 54.00, and it took him 15 minutes to fix. You could be looking at more than that if you call someone out. The front comes off easy.
May 11, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Philips Whirlpool 400 AWG 370 door is locked
take the kick panel off and reach up the right side where the door lock is. there is a release pull down that releases the door.
Jan 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet 9200 Washer door lock issue
no thiis is normal operation, it is considered a child safety feature. in case a sleeping child should happen to be in machine, the short 2 sec blast of cold water will wake them and give them a chance to exit before the machine starts washing.. all whirlpool frontloaders do this, thats how it waas explained to us at factory training.
Dec 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Door locked & nothing happens Whirlpool duet wfw8300sw01
hi there,
sounds like the machine has no power at all.
there was no need to break the lock.
unplug the machine
take off the console
check connections from the touchpad to the CCU board
make sure nothing is corroded, burned, bent or pinched
unplug and replug the wiring harness
plug the machine back in and try it again.
let me know if this works.
Sep 26, 2008 | Whirlpool Duet GHW9150P Front Load Washer
We just had a flood in our basement and our Whirlpool Duet Sport HE front load washer is displaying F28 which I know means something electrical. Is there any way I can disengage the electronics to get the...
Unplug the machine. Remove the bottom access panel (three torx screws along the bottom). Reach up under the area where the door lock is and feel for a round door release mechanism. Pull down and the door will unlock
Jun 08, 2008 | Whirlpool Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
37 people viewed this question
Dan Webster
Dan Webster
Sal De
