Question about Kodak ESP 5250 All-in-One Printer
Code 7300 when setting up network settings I get this error come up, The owner said she reset the factory settings and the wireless printer hasnt worked since
2 Suggested Answers
Josue Pongco
  • 154 Answers
SOURCE: Printer Error "Failed to detect paper edge,.
Try upgrading your Firmware go to to this web www.kodak.com/go/5300downloads and look for firmware and download it, make sure that the printer is connected and turn on while downloading the firmware. thanks
Posted on Aug 12, 2009
How to delete previous owner WiFi data and security code
Resetting the Printer to Factory Default
Settings
Resetting the printer to factory default settings can be useful when
you are troubleshooting with the printer.
CAUTION Resetting factory defaults clears the page buffer, removes downloaded
fonts and macros, and returns all print menu settings to factory defaults.
To reset the printer to factory default settings
1 Press MENU until RESETS MENU displays.
2 Press ITEM until RESTORE FACTORY SETTINGS displays.
3 Press SELECT until the following message appears:
RESTORING
FACTORY SETTINGS
This message displays until the printer has completed the
initialization
Mar 26, 2015 | HP LaserJet 4500 Printer
How to delete former owners wireless data on HP 4500 - G510n wireless printer.
Settings
RESTORING
FACTORY SETTINGS
initialization
Mar 26, 2015 | HP Office Jet 4500 G510n
KODAK PRINTER ERROR
You might Google the printer name and the error message. Just a guess, but if there is no "reset" button, you might try unplugging it for a couple of minutes and it should reset itself to factory default settings. You will loose any settings and any work in progress. If you have an owner's manual, I would check there to find how to solve the problem. You also might want to enter the "menu" if there is one, and discover whether you can solve the problem there. Usually the owner's manual has error codes listed and solutions. If you don't have an owner's manual, you might be able to find one at the printer manufacturer's website in the support section. Good luck.
Nov 11, 2013 | Eastman Kodak Company PRINTER INK...
How to reset it lexmark S605
To reset the printer back to its factory settings, on the control panel of your printer, press on the Wrench icon > Use Factory Defaults > Yes.
Jun 23, 2012 | Lexmark Interact S605 Wireless All-in-One...
Printer not connecting to computer - orange wifi light stays on
You may need to reset the printer's wireless network settings. On the printer operator panel, press Settings button > Network Setup > Wireless Setup > Reset Network Adapter to Factory Defaults.
Relaunch the Lexmark Wireless Setup Utility. If you have a firewall enabled, make sure to allow full access to all Lexmark software and printer communication processes in the program rules/permissions for your firewall.
Also, place your printer where it receives excellent wireless signal quality and away from other electronic devices which can cause wireless interferences (e.g. cordless phones, microwave ovens, baby monitors, garage door openers, and other wireless electronics).
Jun 17, 2011 | Lexmark X6570 InkJet Printer
My printer is connected to another wireless network which is not the same as my laptop how do i connect it to the right one?
I`ll guess You`ll have to connect your PC to the printer with the use of a usb cable.
Then run the Lexmark software (Lexmark printer home) or similar (don`t know what you are using?)... Go to "settings"; and choose wireless setup utility. You`ll have to manually set the SSID (the wanted wireless network) and the WIFI password for this network. Hope this will help.
May 23, 2011 | Lexmark X4650 InkJet Printer
After the power went out and came back up the wireless printer is orange and i reinstalled all the drivers on all the laptops, but it wont communicate with the printer lexmark x4650
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Frequently, issues are caused simply by a break in the signal sent from PC to printer or vice versa. Unplugging and re-plugging the printer allows the small amount of on-board memory on the printer to be cleared, with the result that the PC recognizes the machine properly. Programs continuing to run in the background of the operating system (OS) can cause the signal to be lost. Rebooting the PC ends all programs that may be running and makes a 'clean' start, allowing the signal to be detected.
If connection is still not established, try to print the network settings page to determine if your printer is still registered in your wireless network. 1. Press Setup (pattlnk_632008_2048-x4650stup.jpg) on the printer operator panel. 2. Press the right or left arrow button until Network Setup is displayed, and then press(pattlnk_632008_2052-x4650ok.jpg). 3. Press pattlnk_632008_2052-x4650ok.jpg at Print Setup Page. 4. Press pattlnk_632008_2052-x4650ok.jpg when prompted to Load Paper. 5. Press pattlnk_632008_2052-x4650ok.jpg. The network settings page will now print.
Check the SSID and the IP address on the settings page. If info shows that your printer is no longer registered, you may need to reset the wireless network settings of the printer.
Follow steps 1 & 2 above, 3. Press the right or left arrow button until Reset Network Adapter Defaults is displayed, and then press pattlnk_632008_2052-x4650ok.jpg. 4. Press the right or left arrow button to display Yes, and then press pattlnk_632008_2052-x4650ok.jpg. 5. Observe the message"Clearing Wireless Settings". The WiFi light will momentarily turn off then lights up solid orange. You can now launch Wireless Configuration Utility or Wireless Setup Assistant (Macintosh) to reconfigure your printer to connect to your network.
Sources: How to Print the Network Settings Page on X4600 Series All-In-Ones (AIOs) & How to Restore the Network Settings on the X4650 AIO to the Original Factory Defaults.
May 11, 2011 | Lexmark X4650 InkJet Printer
I have a green Wi-Fi indication of the from of the printer, but it won't print. it says... Lexmark 3600-4600 series 3A82A0_P1
Try to unplug then replug the printer into the power source to reset it. This usually fixes minor communication issues. If problem continues, try to print the wireless network settings to check if your printer is still connected to the same network as your computer(s). Follow the steps in this article: How to Print the Network Settings Page on X4600 Series All-In-Ones (AIOs). If not in the same network, you may need to reset the printer. Follow the steps on how to reset the printer wireless network settings: How to Restore the Network Settings on the X4650 AIO to the Original Factory Defaults. To reconfigure printer back to your wireless network, refer to this article: How to Install the X4600 Series on Wi-Fi Network - Infrastructure Mode.
Apr 20, 2011 | Lexmark X4690 Wireless InkJet Printer
Canon PIxma MP620 Error 6C10 - Please help!
I got the same code on my ip3600, and stumbled across a quick fix which may work for yours.
1. Turn power off
2. Open cover as if you're going to change a cartridge
3. Turn power on
4. When printhead is in position to change cartridge, close the cover
That's all I did, and it seemed to work.
Mar 09, 2009 | Canon PIXMA MP620 All-In-One InkJet...
Lexmark 4800 series reset printer to factory wireless settings
i have a lexmark printer its plugged in but dont have a icon to make it print
Oct 07, 2008 | Office Equipment & Supplies
Kodak ESP 5250 All-in-One Printer Logo
311 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
