Question about Dishwashers
Whirlpool ADP 5550 the start button continuously flashes twice and the rinse light is on. The pump starts but then stops and the lights keep flashing.
  • 1073 Answers
SOURCE: whirlpool adp 8540 - 7 flashes
replace the control board in the console
Posted on Apr 10, 2008
SOURCE: flashing light
I had this problem at home too, it turned out to be a kink in the water outlet pipe. I straightened out the kink in the pipe, put duct tale around it to strenghten it and the dishwasher has been working perfectly since.
Posted on Sep 22, 2008
SOURCE: my dishwasher model adp 941 won't start - start led flashes
exactly the same problem today with an AD9520
Don't know the cause but from reading other posts re dishwasher problems I tried holding start but on for 5 - 10 seconds and it seemed to clear the symptoms at least. It ran for a short while and stopped but the flashing had stopped and I could start a wash cycle which is now running!
Posted on Dec 14, 2008
  • 220 Answers
SOURCE: Whirlpool ADP 5500 dishwasher stops - light flashes 7 times.
It's a heating issue either a bad heater or bad sensor.
Posted on Sep 01, 2009
SOURCE: GREEN LIGHT KEEPS FLASHING ON MODEL ADP 951 STARTS
The same occurred with my dishwasher. I solved it by depressing the start button for 10 seconds. Worked for me...hope it works for others too.
Posted on Jan 20, 2010
Hotpoint whirlpool ADP 4502/5
It's trying to fill with water and there is debris in the pump assy. Please remove the debris and restart the unit.
Mar 11, 2014 | Dishwashers
Whirpool ADP 5550. Will only rinse. Does not
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Thank you for using fixya.
Sep 17, 2011 | Whirlpool Dishwashers
GREEN LIGHT KEEPS FLASHING ON MODEL ADP 951 STARTS FOR A FEW SECONDS THEN STOPS
Dec 04, 2009 | Whirlpool Dishwashers
Whirlpool adp 6600 will not function start light is just flashing
Whirlpool adp 6600 will not function start light is just flashing. Waht di I do?
Sep 17, 2009 | Whirlpool 24 in. ADP6940 Dishwasher
Dishwasher (Whirlpool ADP 952) not working
I have a whirlpool ADP 952 and the start button is flashing and it won't work
May 25, 2009 | Dishwashers
My dishwasher model adp 941 won't start - start led flashes
Dec 14, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher light flashes 7 times
although i dont have a lookup for your particular model number. if you remove the lower access panel you will find techsheet/troubleshooter. in it there will be section on "clen light blinking 7x" foplloe direction to put into test mode to clear the fault. belive its,,, heated dry/ sani rinse / heated dry/sani rinse. pushing htese buttons is what gets into test mode
Dec 11, 2008 | Whirlpool 24 in. ADP5962 Free-standing...
Start light flashing
start light on and no other action could mean that the door catch has gone faulty, test accordingly and replace if needed, no wash cycle will work if this item is faulty, the waste outlet pump may be the only part that will work on some models, this is a safety feature hope i have helped if so please rate me, work safe unplug when testing
Sep 21, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
Top Dishwashers Experts
Owen Barnes
