Question about GE HO98023 Computer Speakers
What are the power supply requirements for GE H098023 speakers?
    Problem Solver:
Start out at 9 volts, 1amp
Posted on Jan 16, 2010
IS SONY SPEAKER VGP SP1 INPUT CONNECTION DIFFERENT FROM VGP SP2 SPEAKER CONNECTION
There may be many different power supplies that will work for your speaker system, but they must comply with the following:
1. The output voltage of the power supply should be correct as what the speaker system requires. (seems like 12 V in your case)
2. The specified maximum current output of the power supply should always be a higher value than the Amperage spec of the speaker system.
3. The output wires or pins of the plug on the power supply should correspond to the (+) and (-) on the power input of the speaker system.
A multimeter will come in handy to determine a power supply's output voltage and polarity.
Jan 25, 2016 | Sony Computers & Internet
What type of power supply is required for this speaker system? If available, how much can I expect to spend for the power supply? I have the speakers but no power supply.
Check the power-connector on the speaker for the rating:
* AC versus DC
* 4.5 versus 5 versus 9 versus 12 versus 18 volts
* 0.5 versus 1.0 versus 1.5 amps
* pole-negative-ring-positive versus pole-positive-ring-negative
Try the local "Thrift Stores", once you have the specifications. You may get the correct suppy for less than $5.
Apr 20, 2011 | Harman Kardon HK595 Computer Speakers
I brought pair of Dell A215 speakers w/o power source. I tried several power supply cords that fit the outlet. They won't work. Do I need to buy a SPECIFIC power supply cord? Is there such a thing as a...
Don't just randomly plug power supply's in; check and see what it needs.
It should be printed somewhere on the device how many DC volts it needs.
If it needs 9volts, get a 9volt power supply.
If you don't have a power supply the same size as it needs, order one off of Amazon, or eBay.
-Forest
Feb 27, 2011 | Dell A215 Computer Speakers
I dont know how to set it up. I put the green cord in the computer..but theres one black cord and i dont know what to do with it.
There should be ONE stereo miniplug to be connected to the headphones output of the computer, and one power supply plug to be connected to the AC adapter. These speakers do need a power supply, since they have an internal amplifier.
Dec 26, 2009 | GE HO98010 Computer Speakers
I lost my GE Ultrasonic 2.1 Speaker power adapter and i need need ones but i dont know what to buy, the voltage it requires..6 or 9 volts?
at most electrical stores you can buy a universal power adaptors with a selection of socents to fit most connections. and which has a selector on it for various voltages settings.
take one of the little connectors and see which one fits. then checking the polarity on your device set the polarity the same when plugging the connector into the power supply cable. adjust voltage as needed.
Warning: when connecting a variable power adaptor alway connect on the lowest voltage setting and work up as too high voltage can distroy your appliance.
Nov 13, 2009 | GE Ultrasonic 2.1 Speaker
Ac adapter for my GE speaker system
This is an old type of PC speaker system. Can it be powered by batteries. How many batteries needed??
Multiply the number of batteries by 1.5 volts and you
get the voltage rating of your needed adapter. You can also take a look at the back of these GE speakers. Maybe you can find the voltage rating.
You may also consider buying a new set of PC speaker that can be plug direct to your power outlet.
You can buy it at a cost slightly higher than your
needed adapter.
Nov 11, 2009 | Computers & Internet
What power supply is required. The rear input
No. It is not recommended to use this power supply, since it outputs only 12 watts of power, whereas the required power to run your speakers is 26 watts.
You will have to use a power supply which outputs 13 VDC, with at least 2A.
May 16, 2009 | Altec Lansing ACS 90 Computer Speakers
Lost my power supply
Having some trouble finding any info online about them. Did they have a large power pack that plugged into the wall? If so, there might be some information either right around where they plugged in (im assuming on the sub) or possibly on the product info sticker on the speaker. Make sure if its a round plug in that you look for the tip information (whether if is a positive tip or negative). You might be better off buying a new set, depending on the price of a new adapter, compared to the price of a new set. Let me know if this helps.
May 11, 2009 | GE HO98015 Computer Speakers
POWER SUPPLY REQUIRED
you don't a new power supply for that speaker because they all have in the package with the power supply adapter ..all have to do is to plug the adapter to ac power outlet your speaker is gonna be function...
Dec 14, 2007 | Creative Labs Inspire T7900 Computer...
RE: "Packard-Bell speaker power requirements"
I have a power source that cam with similar speakers that is labeled Packard Bell Plug In Class 2 Power supply Model @ 012-10-1000-07 Input: 120VAC 60 hz 25W Output 9VDC 1A BPCS #:  146139 Maybe this will help
Aug 12, 2007 | Packard Bell (160248-01) Computer Speakers
GE HO98023 Computer Speakers Logo
136 people viewed this question
Top GE Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
SHARCNET-USA
SHARCNET-USA
Jim Goldsmith
Jim Goldsmith
Are you a GE Audio Player and Recorder Expert? Answer questions, earn points and help others
