Question about Logitech X-230 Computer Speakers
My right speaker does not work
I bought a set of X-230 speakers but can't get any sound at all from the right-hand one. Is the problem in my sound card? I've been trying to update the driver for an ESS 1969 card, on a Windows XP system, but can't work out how to install the update from the unzipped files...?? Or could the right speaker possibly be faulty? The volume control and LED are both working fine, and the left and bass speakers sound great. But no SOUND... :( I'm so frustrated, I hope someone can help! :)
My left speaker didn't work, I described how I fixed it here: http://users.tpg.com.au/malydog/fixits/logitechx230.htm
Posted on Aug 14, 2007
    Genius:
  • 2,985 Answers
Swap left and right speaker This will prove either the speaker is dud or the amp channel is dud. one the speaker set. Now plug headphones in the line out of the computer. Got one side or both sides - this prove the sound card. Regarding the zipped downloads - double click onn the file - it should be self unsipping come back with results
Posted on Jul 11, 2007
SOURCE:
Hello, My logitech x-230 2.1 speaker system is not producing any sound. The power light comes on but no sound at all comes from any speaker. Also, it is not the computers fault because I have used it with...
If there is an ON/OFF switch at the back of your 2.1 speakers, then switch it on. Or is the VOLUME control set at 0? Turn it up a bit.
Or, are the left & right speakers properly hooked to the subwoofer unit?
Please check.
Jul 13, 2012 | Logitech X-230 Computer Speakers
I just bought a microsoft wireless keyboard 3000 and inserted the USB into the hub. But now when I play a youtube video the sound comes from the laptop instead of the external speakers like it used to. ...
First, you can try unplugging and replugging the speakers. If that doesn't work, right-click on the speaker icon in the taskbar (lower right-hand corner) and select "Playback Devices". When the window opens, you should see your internal and external speakers listed. (Maybe Internal Speakers and "Headphones") Just right-click the option that says corresponds to your speakers and select "Set as Default Device". Close your web browser and re-open it. This should fix the problem.
Aug 27, 2011 | Computers & Internet
I don't hear any sound from logitech x-230, after i have installed driver into my PC
check your green cable. did you mute sound? icon next to clock, lower right corner
May 28, 2011 | Logitech X-230 Computer Speakers
I bought logitec speakers but withought subwoofer is there any way i can connect them to the pc withough the subwoofer or no?
the speaker with the subwoofer may not work as the speaker needs a power supply to boost the sound from the PC.....even if you connect to the sound jack of PC using some adaptor it may not give out the required sound.....i mean it will need amplifyer, the job of the amplifyer is normaly done by the big box that comes along with the speakers (called subwoofer).....
Nov 08, 2010 | Logitech X-230 Computer Speakers
My right speaker does not work, but left does
tell me how to connect vose speakers to my desktop computor
May 03, 2009 | Logitech X-230 Computer Speakers
No sound
Sounds like you have missed the wire which connects them to your pc (or to each other)
Mar 21, 2008 | Logitech X-230 Computer Speakers
X-230 Speakers Hum
bad brain in it or u can try to see if its pused in all way cables in back dl latest sound card drivers
Jan 16, 2008 | Logitech X-230 Computer Speakers
One speaker works only
As long as the jack you are using fits snug into the port, they will be the right size. I am sure that they are the same size. As for the jack port, some can be finicky like that. It is more than likely your sound card that is at fault. You can check the connection on your card by removing it with the computer off and inspect it for a loose connection within the jack port and around it. Plug in the speakers slowly and see where it is not contacting. Some do it yourselfers can fix this by replacing the port or re soldering a bad connection
Nov 19, 2007 | Logitech X-230 Computer Speakers
No sound out of spekers... or sub.
check for the manual online, also make sure you have the driver for the speakers....
Nov 10, 2007 | Logitech X-230 Computer Speakers
Only the right speaker (and the subwoofer) works. The left one doesn't, but it is NOT faulty!
Go to Start/Programs/accessories/entertainment/volume control. And check the left channel as not be muted by ticking the mute box. Check also all other sources of channel control- via the sound card and the computer built in one.
Jul 24, 2007 | Logitech X-230 Computer Speakers
Logitech X-230 Computer Speakers Logo
1,529 people viewed this question
Top Logitech Audio Players & Recorders Experts
Ekse
Michial Gueffroy
Paul
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
