Question about Bernina Sewing Machines
Bernina 1080 cuts thread in reverse
Bernina 1080 is just fine when stitching forward but cuts the top thread in reverse. How can this be solved?
Hi, is the top tension too tight? as this is often the problem. Try loosening it
Hope this helps,
Sally
Posted on Jan 24, 2013
  • 21 Answers
SOURCE: Bernina 1630 problem
Your feed dogs sound like they are getting stuck,chec whether they are on the down position,and also make sure that you have cleaned any lint that builds up in the bobbin area, if all fails it will have to go into the technician,
Posted on Sep 21, 2008
  • 3 Answers
SOURCE: Bernina Bernette 600 Deco embroidery machine
It could be that there is a loose piece of thread, or some fluff which is obstructing the tension gauge. Try blowing around the theading area (or even run the hoover pipe near it to see if you can **** it out). I cleared mine by folding a piece of non fluffy material and rubbing gently between the tension dial and machine.
Good luck
Posted on May 22, 2008
  • 8 Answers
sounds like ur bobbin needs to be tighten, when loose the bobbon does not stop and you get more thred then needed hope this helps... Velz...
Posted on Jul 18, 2009
  • 103 Answers
SOURCE: I have a Bernina 950 Industrial bottom stitch loose and pulls out
tighten top thread tension.
Posted on Nov 03, 2009
  • 1116 Answers
SOURCE: bernina artista 180 keeps warning to check top thread
Refer to your manual for maintenance and clean the machine as indicated. A sensor may be blocked by lint.
If this continues, the machine will need to be serviced by an authorized Bernina repair tech.
Posted on Mar 25, 2010
How do i alter the stitch lengthbon Bernina 1080
The bottom dial on the right of your machine is the stitch length selector. The dial at the top right is the stitch width selector.
Dec 05, 2015 | Bernina Sewing Machines
Will not sew continuestly when im embrodering when i press the reverse button
It is completely normal for a Bernina 180 and other Bernina models to stitch just a few stitches and stop after first pushing the reversing button. The reason for this is so you can cut off the extra piece of top thread so it does not get caught up in the embroidery design. After you cut off that extra piece of thread, press the reversing button (hold it in till the machine starts) then it will continue with the design. Assuming you do not have a problem (a message would come up on the screen) or you are out of bobbin thread, the machine will continue to embroider till either the design is finished or it stops because you need to change the upper thread to the next color. Each time you start to embroider it will stitch about 3 or so stitched and stop. Cut off the extra thread and press the reversing button again to continue.
If this is not the problem you are having then you need to describe your problem better, in more detail.
This should help! Bill
May 26, 2015 | Bernina Artista 180
Sews backwards..when I press the reverse button it sews forwards
Sounds like you have the timing precisely reversed. Time to try again.
Sep 10, 2012 | Singer CE-100 Futura Computerized Sewing...
Why won't my Bernina Activa 140 sew the blind hem stitch?
Are you absolutley sure you're not getting a problem with stitch formation on, for example, wide zig-zag. Check again, using a different colour top and bottom and make sure that the stitch is being formed properly with only the top colour on top and bottom colour on the bottom. It sounds as though the bottom loop is not being picked-up by the hook properly. Make sure you've thoroughly cleaned-out any fluff under the stitch-plate and remove the hook/shuttle and give the hook race a good clean and give it a single drop of oil, even if you've got the lightweight part-plastic hook/shuttle fitted.
Nov 19, 2011 | Bernina Activa 140
Bernina 1080 while sewing normal stitch, stitch
What stitch to you have selected for it to do? Please check to see if it is set for straight stitch only.
Linda at Relics
www.sewing-machine-manuals.com
Jul 05, 2011 | Bernina Sewing Machines
My bernina patchwork 140 will not sew in reverse when I press the reverse button has the button gone bad the button hole won't sew ithe back stitch either?
Some machines will not do any of their automatic forwards and backwards movement type stitches in reverse, are you trying to reverse in straight stitch or a more complex stitch.
The Activa is a late model quality machine, do you have a Bernina dealer locally you could ring up and ask or take it to?
Mar 10, 2011 | Bernina Activa 140
Bernina 1008 - tension problems
Make sure the presser foot bar is UP before you thread the machine, otherwise the thread doesn't connect propertly with the tension discs. Top thread should reel-off in clockwise direction.
Jan 02, 2009 | Bernina 1008
Sep 01, 2008 | Bernina Bernette Deco 600
Thread tension problem when sewing on heavy fabrics
Sometimes when I need to use heavy thread for top stitching to reinforce a seam that has come undone, I will use the heavy thread on the top and regular thread on the bottom. I haven't tried it the other way around for hemming but I would think it would work. I do not currently have a Bernina.
Jan 15, 2008 | Bernina Artista 180
Sewing Machines Logo
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
