Question about Philips 37PF7320A 37 in. HD-Ready LCD Television
TV won't power on, repeating doulbe red light blink
I'm trying to fix a 37PF7320A/37 TV for a friend who says it may have been exposed to overvoltage during a lightning storm while in standbye.  I've replaced the small signal board and the lcd supply pannel board which had some burnt up punched through diodes in it.  Now the green LED will come on for a moment, followed by a relay click and then protection mode seems to start.  I get 2 blinks of the red led which repeat indefinitly. According the service manual blink codes, this could be error #2 (I2C bus 2 blocked) but I'm not sure since the manual say the LED should blink at 3Hz and not 2 blinks.  I'm thinking of replacing the audio board next.  Any help is greatly appreciated.
  • fpertl Feb 04, 2009
    I replaced the audio board, but that did not fix the problem. Any Philips technicians out there?
  • 98 Answers
Question Television is not working, screen is black, blinking red led.
Answer Television is probably malfunctioning due to electrostatic discharge. Try resetting the television by unplugging it from the power outlet for 10 seconds.
  1. Make sure that the power cable on the display and the VGA cable with trailing audio cables are connected correctly (use the originally supplied VGA cable.) between 'MONITOR' of the TV and 'VGA1' of the display.
  2. Make sure that the display is switched on.
Posted on Jan 24, 2009
Tv will not come on. Red light blinking on bottom left front. Red light blinks 7 times
I have the model Philips 37PF7320A/37 won't turn on and MOST articles on the Internet say it's the Capacitors capictors capictors..I checked all of them. My tv just blinked red lights, had the clicking sound at first power on, but then goes black. No sound. No picture. Nothing. Just blinking red lights.
MINE WAS RESISTOR no. 3318 , a 100 OHM RESISTOR ON POWER SUPPLY BOARD.
I BOUGHT REPLACEMENT FOR .99 CENTS SOLDER IT, AND EVERYTHING WORKED!!!
THAT WAS ALL IT TOOK.
JUST A SUGGESTION..
1. CHECK FOR BULGING CAPACITORS (90 PERCENT OF THE PROBLEM)
2. THEN CHECK FOR RESISTORS WITH MULTIMETER ( FALLS INTO THE OTHER 10 PERCENT OF THE PROBLEM.)
TELL ME IF THAT HELPS..normanw1@yahoo.comj
Nov 01, 2011 | Philips 42PF7320A 42 in. Plasma HDTV
Philip tv no picture no sound
JUST A SUGGESTION..
Oct 30, 2011 | Philips 52PFL7422D/37 TV
Philips tv model number 50PFP5332D 37 wont power up
JUST A SUGGESTION..
Oct 30, 2011 | Philips 50PFP5332D 50 in. Plasma...
Screen goes black but still sound
JUST A SUGGESTION..
Oct 23, 2011 | Philips 37PF7320A 37 in. HD-Ready LCD...
My Phillips flat screed TV model # 37PF7320A 37 won't turn on. When I press the power button the indicator light blinks 1 long red then 4 short. I tried to change both of the fuses but I couldn't find...
Common short the cover cap over the video & sound boards short out if you remove it the cap only (shield metal) it usually will fix this i have the same tv it works like new
May 11, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips LCD TV - Red blinking lights
I would check the capacitors on the power pack for failed or blown ones. doing this work will require soldering skills
FYI
Mar 21, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
No picture or sound just six red blinking lights
Use your warranty in a hurry before it expires. Your TV when into protection mode to prevent further damage. Most TVs have a 1 year warranty. Good Luck.
Jan 24, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Blinking Red Lights
Sound like an error code 14 (Audio supply) is beeing blinked...
You probably would want a qualified technician to take a look at it.
Jan 16, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips 37PF7320A 37 in. HD-Ready LCD Television Logo
631 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
