Question about VeriFone new vx670 gprs wireless machine No smart card
Commsvr entry password - VeriFone new vx670 gprs wireless machine No smart card
How do i unlock my palm t/x
If you forget your password and your handheld is unlocked, use the password hint feature to try to remember the password. If this does not help, or if you do not have a password hint, you can use Security to delete the password; however, your handheld deletes all entries marked as private. You should perform a HotSync operation before you delete the password, because the HotSync process backs up all entries, whether or not they are marked private. Then you can follow these steps to restore your private entries:
  1. Perform a HotSync operation to back up your records, including those marked Private.
  2. Tap the Applications button to open the Applications Launcher.
  3. Tap the Security icon to display the Security screen.
  4. Tap 'Forgotten Password' to display the Delete Password dialog box.
  5. Tap Yes to delete the passwords and all records marked Private.
Jul 07, 2014 | Cell Phones
Tip
How to Restore a Password Keeper(Using Your Blackberry Phone)?
<span>Blackberry has manufactured Research in Motion (RIM) desktop manager to help restore all Password Keeper entries when your Blackberry gets wiped out and your Password Keeper is down. There are two different ways to restore your Password Keeper.</span> <span><br /></span> <span> <span>Instructions</span> <ol> <li><span>Turn your Blackberry on, if not already activated.</span></li> <li><span></span><span><span>Open Password Keeper.</span></span></li> <li><span><span></span></span><span><span>Enter your password. Password Keeper restoration may not work if the password is too complicated, too long, or has too many different characters.</span></span></li> <li><span><span></span></span><span><span>Press Menu.</span></span></li> <li><span><span></span></span><span><span>Select Options.</span></span></li> <li><span><span></span></span><span><span>Turn off Wireless Synchronization option. Your Password Keeper entries will be restored.</span></span></li> <li><span><span></span></span><span><span>Turn back on the Wireless Synchronization option to bring back your Blackberry to normal.</span></span></li></ol></span>
on Mar 12, 2011 | Cell Phones
Hard d bios password
to change the password, do this:
1. go to into "setup" from the boot up entry (turn on comp, then press F2 or F12, depending on your OS; look for them in the bottom left corner; if you don't press it before the OS loads, you'll need to restart and do it again)
2. Once in setup, you'll see a menu bar - for each item on the bar (i.e., File, Edit etc) select F9 and select yes when prompted to save changes. Do this for each. Then go to the Menu Bar Option that will allow you to change the password. It will ask you for the old password - do not enter anything - simply hit enter - then hit enter for the new password entry, as well as the "confirm" password entry (if applicable, should be).
Then, go to exit, and "exit saving changes". The OS will automatically reload. If and when you are prompted to enter a password for the OS, hit enter. You should be brought to the OS (windows) desktop.
If this does not work, please let me know.
Jan 23, 2012 | Computers & Internet
RAM CHKSUM ERROR ON VX610 TERMINAL I : commsvr. out Any Idea what is the issue. When I press F4 it say system error call customer service
Maybe you have a corrupted softpay system, call you credir processor to reload it. An secondly your GPRS/Radio board maybe bad too. Call (775)358-2922 look for randy maybe we can help. thanks
Nov 12, 2011 | VeriFone VX 610 Credit Card Terminal...
Lockedout before user acct. password window entry
so is your password blank?? or have you changed it to something you cant rememeber? did you create a restore disk (no one really does this so will be surprised if you have) you can try a password change boot disk (search online for this) but can't guarantee this method.
May 07, 2010 | Acer Computers & Internet
Need to reprogram a vx 570 but don't have password, I believe it was programmed thru NorthAmerican Bancard. 1 alpha,alpha 66831 works on first entry but not for the 2nd password entry. Does anyone have a...
Try calling their support number. I had a non-standard terminal config password on an omni 3200. I called the processor's support line and they were able to give me the password.
Nov 24, 2009 | VeriFone OMNI 3200 (P092-101-10) Printer
Have Z22 Palm handheld organiser, switched to preferences, security and tried to enter private entries, did not remember correct password and now handheld is switched on and completely locked. Cannot...
If you can’t remember the password, you can delete it from your handheld. Deleting a forgotten password also deletes all entries marked as private.
Here is the procedure to delete the password.
Be sure to synchronize your handheld with your computer before and after this procedure, so you can restore any private entries that were deleted along with the password.
1 Open Security:
a. Go to the Home screen, and then select Prefs .
b. Select Security.
2 Open the Incorrect Password dialog box:
a. Select the Password box.
b. Enter any password, and then select OK.
4 Delete the forgotten password: a. Select OK on the screen informing you that your password is incorrect.
a. Select Lost Password.
b. Select Yes.
4 Synchronize your handheld with your computer to restore any private entries that were deleted.
You will need to have a backup saved if you want to recover private entries.
Jul 23, 2009 | Computers & Internet
Dont know what it is
Turn off smart password entry
You can turn off smart password entry to reduce the chance that someone might guess your BlackBerry® device password or smart card
password based on the smart password filter that your device applies to password fields.
1. In the device options, click Security Options.
214
2. Click General Settings.
3. Set the Smart Password Entry field to Disabled.
4. Press the Menu key.
5. Click Save.
For your information .........
If you use two-factor authentication and your BlackBerry® device password or smart card password is numeric, you might be able to use
smart password entry in some password fields. When smart password entry is turned on, your device is designed to remember the format
of a password that you type in a password field. When you type the password again, your device applies a smart password filter to the
password field. If the password is numeric, a 123 indicator appears beside the password field and you do not have to press the Alt key to
type numbers. If the password is alphanumeric, an ABC indicator appears beside the password field.
Smart password entry prerequisites
• Verify that the correct smart card driver and smart card reader driver are installed on your BlackBerry® device.
• Verify that two-factor authentication is turned on
Jun 04, 2008 | RIM BlackBerry Pearl 8100
External hard drive and vista
Need the latest VISTA drivers ... I'm still lookin' for them on Toshiba's site. It's a nightmare!!
Apr 14, 2008 | Fantom Titanium Hard Drive
VeriFone new vx670 gprs wireless machine No smart card Logo
Top VeriFone Computers & Internet Experts
lolthepcman
Are you a VeriFone Computer and Internet Expert? Answer questions, earn points and help others
