Why won't reset button work on Dimplex OFC2009Ti radiator
Radiator turning itself off and reset button won't. Light stays on only if I Hold the the tiny reset button down manually.
3 Suggested Answers
freetek
  • 5568 Answers
SOURCE: my oil filled radiator trips the mains after a few
Try changing circuits (plug into one not protected by the same breaker.)
While the heater element can fail in your heater, I have had to replace several breakers after only a few years use after they became overly sensitive.
Posted on May 24, 2010
SOURCE: Dimplex OFC2009TI programmer not working
yeah i now have this problem did you find a solution?
Posted on Dec 12, 2010
Turns itself off and then won't stay on
Do the self check.
If you unplugged the set, plug it back, turn it on and allow to fail.
Press both the Menu and Input (input may be labeled device) buttons on the front of the set and Hold both for at least 5 seconds and release both.
Power light will begin to blink a two digit error code like 2 blinks, 2 blinks, pause and repeat it for a total of 5 times.
Let me know what error you find and I tell you the meaning and a possible answer.
Dec 21, 2012 | Mitsubishi WS-65807 65" Rear Projection...
I have a 2001grand cherekee listed that won't stay
there can be a nuber of things. you could be losing spark. that would be ignition coil pack or spark plugs. you could be losing fuel pressure . the jeeps are known for bad fuel pumps. and the crank position sensor . this is my link to my garagehttps://www.facebook.com/TedsRepairs
Nov 12, 2012 | Cars & Trucks
My low coolant light stays on on my 02 impala but the coolant is full how do I reset it?
The coolant level sensor is located on the passenger side of the radiator, just below the bottom of the battery. If the light comes on, you'll need to fill the plastic coolant tank. But you also need to remove the radiator cap and fill the radiator itself. Only open the radiator when the engine is cold. If the radiator is full, and you are positive it's full, then the sensor needs to be replaced.
Feb 22, 2012 | 2002 Chevrolet Impala
2005 mustang is overheating and shutting off. Turned the key and it won't stay on. I noticed that the fan might not be turning on. How do I troubleshoot? I put water in the radiator and didn't...
It could be a leak, check your radiator for any leaks, also check upper and lower radiator hoses, water pump, etc. But you said the fan doesn't kick on even when it's reading "hot". So I would look into that more. route the wires and locate the plug, make sure it's plugged in, or reseat the cable by unplugging, and replugging it back in. You could also unplug the negative cable on the battery terminal for a few seconds in attempt to reset the ECU (computer).
Oct 21, 2011 | 2005 Ford Mustang
How to set timer
Here is a link to an Owner's Manual for a Dimplex Model that is similar to yours. They all function just about the same way.You can downbload & print the manual if you so desire.
http://www.dimplex.co.uk/assets/product_instructions/Dimplex_Oil_filled_Column_Radiators_UK-Issue_0_H27a.pdf
Hope this helps you.
Jun 23, 2011 | Dimplex OFC2000 Oil Filled Radiator Heater
MY ROF2ETI HAS STOPPED WORKING RECENTLY THE POWER INDICATOR LIGHT ISN'T ON, CHECKED FUSE OK IT'S ONLY 8MONTHS OLD, ANY HELP APPRECIATED.
If it's not too late, I have just repaired one of these. The time switch circuitry has failed.
I can repair this unit. Call Nic on 01202 814081 (Bournemouth)
Jun 14, 2011 | Dimplex OFC2000 Oil Filled Radiator Heater
Car only starts if i hot jump the alternator...nothing electrical works on inside of car, i.e. power windows,power locks,dash lamp, no tail lights, no brake lights, no fan for the radiator etc...i changed...
Hello and welcome to FixYa!
If the battery light is on, I strongly suggest that you have the battery charged. It can be an indication of a weak battery or a faulty alternator. If the battery light still on after charging then the problem will surely be on the alternator itself. If that's the case the alternator should be replaced to resolve the problem.
If the battery won't hold charge even on a new alternator then the problem will be on the battery itself. It surely is in the end of it's service life and replacement will be necessary.
You may try to reset it to by removing the positive battery connector, letting it sit for at least 5mins. then reconnect it again. This will reset the system and can get the battery light off.
Hope this helps and thank you for using FixYa! Have a good one!
Jun 05, 2011 | 1993 Toyota Camry V6
We have a new OFC2400TIF heater. We have set a program which worked for a day. Now the heater will not work on either manual or auto. The display lights are all on, the screen indicates that the heater is...
The heater may need to reset itself. Turn the Master ON/OFF Switch to OFF and unplug the heater from the wall outlet. Wait 12 - 15 minutes and plug the heater back in. Turn the Master ON/OFF Switch to ON and set the controls as you normally would. Hopefully, that 12 - 15 minute timeout allowed the heater to reset itself. If this continues to occur, contact Dimplex Technical Service at
888-346-7539.
Hope this helps you to further troubleshoot and solve the problem.
Apr 24, 2011 | Dimplex OFC2000 Oil Filled Radiator Heater
Jan 26, 2010 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
