Question about Air Tools & Compressors
Looking for a user manual for a tradeair nail gun model 9034
    Top Expert:
  • 34,733 Answers
Try Googling (tradeair)(9034)(manual) without parens.
Posted on Sep 18, 2017
  • 18 Answers
SOURCE: oiling my nail gun
You simply put a couple of drops of pneumatic oil in the air chuck on the handle every time you're going to use it, and then hook up the hose.
Posted on Nov 15, 2008
  • 1383 Answers
SOURCE: i need a repair manual
Your nailer, although very good, is rapidly becoming obsolete as many parts are no longer available. When these guns were first made available, a sales rep. demonstrated repair techniques and did not provide repair manual. Owners manual for many models are available at duofast.com www.toolpartsdirect.com has parts lists and many parts available. If you are having a specific problem please post it; maybe I can help. Good Luck
Posted on Jan 11, 2009
  • 65 Answers
SOURCE: air never stops coming out of gun nail,and gun doesn't sink nails
strip and clean the gun ,you will find that replaceing the seals will help no end
best of look ian
Posted on Mar 24, 2009
  • 1383 Answers
SOURCE: feeding nails
Your nailer shares design features with Milwaukee and Ridgid. All three brands experience the same issue. Lets go thru a series of simple tests to determine the problem. First and most simple test, manually load the nails and fire the gun untill miss-fire. Upon mis-fire disconnect air, open latch and check if the driver is all the way up into the cylinder or is partially down blocking next nail. If driver is down blocking next nail, replace the driver oring and retest. If driver is up all the way, remove nails, reconnect airline, leave latch open and fire gun against rubber (old tire or coiled up waterhose/airhose) this time holding the gun down and keeping the trigger depressed. In this position, the driver will remain down and feeder will remain retracted. With feeder retracted and screwdriver in hand carefully check the spring tension on the feeder (should be rather firm tension on spring and the feeder must retract with good force). If no tension or weak, replace feed spring. When you finally release the trigger, the driver will retract and the feeder should return with good force. If feeder does not return with force, replace orings and spring behind feed piston. If all tests are ok, remove head, check lower bumper in gun for cracks or missing pieces. Replace as necessary. Lube all orings with silicone lube available at Lowes in the plumbing department. (Danco brand) Good luck on your repair and email your questions.
Posted on May 06, 2009
  • 21 Answers
SOURCE: Why does my porter cable nail gun FN250B shoot
check the magazine bolts are tight and that the magazine is snug aginst the nose. also be sure you are using 16 gage brads and not 18 gage
Posted on Feb 14, 2010
Tip
Paslode Cordless Nailer Problems
<p><b><i>Paslode cordless nailers</i></b> are a very common tool used by many professionals and do it yourselfers. These <b>nail guns are a great tool</b> when they work correctly, but can drive you nuts when they do not work as they should. When answering problems that people have on <a href="http://www.fixya.com/"><b>www.Fixya.com</b></a> I come across many questions about these nail guns and why they do not work.<br /> <p><br /> <p>If you are having problems with your <b>Paslode nail gun</b> the first thing you need to do is get the <b>Paslode manual</b> out of the box and checkout how to <b>clean the nail gun</b>. One of the most common causes for these <b>nail guns to have problems</b> is because of a<b> lack of maintenance</b>. If you do not have the <b>manual for your Paslode nailer</b> you can download one here. <a href="http://www.paslode.com/owners-manuals.html">www.paslode.com/owners-manuals.html</a><br /> <p>They have all of the current models and also <b>discontinued model Paslode manuals</b> there.<br /> <p><br /> <p>The manual will also contain <b>troubleshooting information</b> also. The <b>troubleshooting guide</b> can often help you to find the problem with your tool. Do not do the common man thing and be too proud to <b>get out the directions and READ them.</b> There are many tips and helps contained in them that will save you a ton of aggravation later.<br /> <p><br /> <p>Now, there are a few things that I have found out through my experiences with this nail gun that are not in the manual. <br /> <p><br /> <p>First, When the manual tells you that the tool needs to be <b>cleaned and lubed regularly</b> it means that you NEED to do that. Most problems are because of a<b> lack of cleaning and lubing the tool</b>.<br /> <p><br /> <p>Besides that, <b>gas cylinders</b> are a problem sometimes even if they are new. If you just replaced the gas cylinder and the <b>nail gun will not work</b>, try another one. Also, sometimes the end that goes on the gas cylinders will not snap on correctly or completely. You sometimes can still get the cylinder into the gun but it will not work because the top is not attached completely or correctly.<br /> <p><br /> <p>Check that the <b>nails do not get jammed in the magazine</b> and then not push up to the front of the gun. No nails, no work. Paper from the nails can sometimes cause them to bind up and not slide front. Make sure to always use nails that are only for the<b> Paslode nail gun</b>.<br /> <p><br /> <p>The firing pin can also be a problem. The <b>firing pin will bend</b> sometimes, but usually because of lack of the right nails or maintenance. Another problem that can happen is that the<b> o-rings around the firing pin</b> will break or crack. When this happens the gun may not fire or the pin will not return after it shoots a nail. If you are having these problems then check the o-rings both top and mid-pin to make sure they are in good shape. If they are chipped or cracked in anyway the gun will not work correctly.<br /> <p><br /> <p>The <b>battery contacts</b> on these nailers are also a problem. They can get dirt and dust in them or become bent. If they fail to make good contact they can cause the gun to have all types of problems. If you are having unexplained problems then<b> check the contacts of both the battery</b> and the gun. You can clean them with a soft cloth or sometimes with a pencil eraser.<br /> <p><br /> <p>The last but least likely problem is the<b> internal wiring in the nail gun</b>. Because of the violent nature of the gun firing the wiring takes a beating inside the nail gun.<b> Every time the gun fires</b> the vibration can cause the wires to move just a bit and eventually a wire can work loose. If all other things check out then look for wires that do not go anywhere. If there is a wire floating around that has no home then you have found your problem. After adjusting the end of the wire so it is tighter, reconnect the wire and you will be working again.<br /> <p><br /> <p>As you can see there are many things that can go wrong with these nail guns. Because of this there also are many things that you can find online that will help you. <b>E-how.com</b> has some tips that will help. <b>You-tube</b> also has some videos that will show you how to clean and troubleshoot these nail guns. Doing a simple online search will give you many places that can help you and also give you sites from which to buy parts if needed.<br /> <p><br /> <p>If you need parts for your nail gun, here is a good place to get those parts.<br /> <p><br /> <p><a href="http://itwconstructionparts.com/xcart/">http://itwconstructionparts.com/xcart/</a><br /> <p><br /> <p>
on Mar 06, 2011 | Tools & Hardware - Others
My makita nail gun was firing 3 nails at once. Now its not firing any and it appears to have come apart at the casing. Help!!!!
yep they do that
extreme care needed to take the gun apart
especially if the rail of nails seperate in the tool
or drum type dispenser if fitted
choose your model see if the user manual helps in repairing
http://powertool.manualsonline.com/manuals/mfg/makita/makita_nail_gun_product_list.html
May 10, 2016 | Makita Air Tools & Compressors
User manual for arrow powershot 5700 staple gun
Hello, there. Attached is the PowerShot 5700 manual. We could only upload in JPEG format, but if you would like the PDF version, please email us at customercare@arrowfastener.com. When you say "reassemble," do you mean the whole tool or the magazine part? We do not recommend disassembling the PowerShot 5700 completely.
Jun 24, 2015 | Arrow Tools & Hardware - Others
Rtm model 9034 framing manual nailer
Hi, If the tool doesn't have a depth of drive control (Found either by the trigger or, on the safety element) you can get around this by adjusting the air pressure from the compressor. Just make sure that you have plenty of scrap timber to experiment as, when the adjustment has been made, the line pressure is still as it was. Firing a nail to cycle the tool once will allow the new pressure to be the norm. (If this makes sense?)
Apr 06, 2014 | Air Tools & Compressors
Need instruction book for unimac nail gun model 9034
I take it that you have already searched online other places with not much luck, don't worry you will find it out there somewhere, the best place to start is with the manufacturer, they will have an website or contact information, you may need to call them. Try mixing up your search and use different search engines, often the resellers like stores and outlets have a contact for the manufacturer and they can find one for you. Try typing in (user manual library) then narrow down your search from there.
Good luck
Feb 06, 2014 | Overlay Nameplate Unimac
On the trigger of my Bostich Spiral load nail gun AND my Bostick trim nail gun air is leaking profusely from the trigger. Nail guns were not in use for about a year. When I first used them this weekend,...
A nail gun works on compressed air.
When you hook the air hose to the gun it fills a cylinder with air pressure.
When you pull the trigger. the cylinder pressure is released onto a firing pin that shoots the nail.
The air pressure line is also connected to the trigger and therefore the trigger has to be sealed.
When ever using a nail gun, you add a bit of gun oil in the back of the gun (not 3-in-1motor oil, it has to be non-detergent gun oil)
If you haven't used the gun in a while, it is best to oil up the gun and let the oil run down into the gun.
If you use anything but gun oil, the seals will give out.
Your trigger seal has given out. It is probably an 'O' ring. You can access it by taking it apart. Look for the O ring.
Bostich makes re-build kits for the different guns that you can buy on-line.
Back when I was in construction, there were several nail gun shops that sold and serviced nail guns, and sold nails to the contractors. I don't know if that business model is still active or if you have to send the guns to Bostich service center.
Oct 18, 2010 | Garden
Can i use any brand coil nailes in my nv 45ab2 coil nailer
Yes. Roofing nailers all use about the same size and spacing on coil nails. You will find that Harbor Freight is about 1/2 the price of Home Depot or Lowes for those nails.
-Jim
Oct 17, 2009 | Hitachi NV45AB2 Roofing Coil Nailer
Nail Gun Problem
Professional-grade varieties are automatic, and fire a nail directly upon pulling the trigger. A semi-automatic nail gun is more appropriate for beginners, since it requires a two step process: pull the trigger and then tap the barrel against the wood. This safety feature protects the user from accidentally firing a nail gun and injuring himself or others.
Aug 27, 2008 | Dewalt DW073KD 1/4 Inch At 100 Feet Manual...
How to Install Air Compressor and Nail Gun
Set up the pressure on the air compressor. First plug the air compressor in, then check the pressure. It should be between 90 and 110 pounds per square inch (PSI) for home use. If it is not in this range, turn the knob to the left to decrease the pressure and to the right to increase the pressure. Use the appropriate nail gun for the job. For example, to nail shoe molding to base boards, a standard finishing nail gun would be perfect. It holds any size nail between 5/8 inch and 2 inches. This nail gun could be used for many projects with great results. Check the gauge the nail gun takes before purchasing the nails for the gun. If you get the wrong gauge they will not fit in the gun. You can check this by looking at the information printed on the side of the nail gun next to the model number. You can also open the nail chamber for this information. Attach the nail gun to the air compressor. You can do this before or after you load the nails into the gun. Use the air compressor hose to attach to the bottom of the nail gun. It screws on much like the end of a hose. If you do not have the right size air hose, you can find one at your local hardware store.
Aug 27, 2008 | Mountain Air Blow Gun with Rubber Tip
Air Tools & Compressors Logo
853 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
